2016+ Toyota Tacoma OVTUNE 1.05 - Tune Development thread
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Jun 20, 2019 at 2:11 AM
    blkbelt42
    blkbelt42 Well-Known Member
    2016 Black AT DCSB 4x4 TRD Sport
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Start TRD Pro Grille ECT always-on mod by MESO OV-Tuned - 1.03 ROAV Dash Cam 3" RC Lift
  2. Jun 20, 2019 at 5:22 AM
    2017 TRD Sport
    2017 TRD Sport Active Member
    David
    2017 TRD Sport
    456 gears. OV tune. Lift. 285/70/17 tires
    I have seen this asked several times but can’t find any definite answer. Will my truck throw any codes if I install the new dump tubes?
  3. Jun 20, 2019 at 5:44 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    16' Tacoma Sport 4x4 V6 DCSB AT Loaded
    OVTune 1.05, 265/70/R17 KO2s, misc mods
    Thank God. My truck still has it's good days and bad days. One day I'm smiling the next I'm aggravated. 1.05.1 93 Performance.
    HelloMyNameIs likes this.
  4. Jun 20, 2019 at 7:54 AM
    CementTaco2019
    CementTaco2019 Well-Known Member
    2019 TACO
    K&N Intake
    If they don’t have an adapter to pull the 02 sensor out to read less flow it’s going to throw a code. Or there would be a selection within the tune system to eliminate the sensor. These are essentially removing the Cat which in turn would always throw a code on a factory set up. Even if it didn’t throw a code of the inspection shop looks under the hood or under the truck they are going to reject it as soon as they see aftermarket down pipes with no converter.
  5. Jun 20, 2019 at 8:51 AM
    dabbinuguay
    dabbinuguay Well-Known Member
    Oregon
    2017 Tacoma TRD OR DCSB
    I'm sure this info has already been shared somewhere on pages 1124 - 1756, but couldn't find it in a search.
    Didn't want to run the flash manager on my work laptop, so instead of picking up a dedicated laptop on craigslist (will probably still do this), I'm trying to get flash manager up and running on my wife's old windows 7 (64bit) laptop.
    After installing the flash manager, I got an error when trying to start up.
    Error was super useful microsoft error, something like "Application cannot start because blah blah code 0xc000007b"
    Turns out I needed to update the visual c++ packages on this machine.
    Took me a while to figure this one out, because the flash manager install looks like it installs a c++ package, which I assumed was a dependency.
    I downloaded and installed them from here, and that apparently fixed the problem without a reboot.
    https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
    Hope that helps anyone who runs across the same problem.
    Is there a different thousand page thread I should have posted this in?
  6. Jun 20, 2019 at 8:53 AM
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    I vaguely recall seeing something about a handheld tuner in the works?? Was this true?
  7. Jun 20, 2019 at 9:03 AM
    dabbinuguay
    Oregon
    Of course, now that I get to the registration procedure, it sure seems like getting a newer laptop seems like a better solution.
    I get that proprietary code must be encrypted and secured, but man, just getting this thing setup is a process, and then it's not portable between laptops?
    No license key that can be activated on multiple laptops, even if it's tied to a single VIN?
    Sorry, that's pretty weak sauce. Hope you guys come up with a more practical solution in the future.
  8. Jun 20, 2019 at 9:08 AM
    Phich
    Phich Well-Known Member
    2017 TRD Off Road
    How does one reset learning values in PCMFlash?
  9. Jun 20, 2019 at 9:09 AM
    ihatemytruck
    ihatemytruck Professional dumbass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB.
    OV tuned
    Practical how? How many laptops do you need to have it on. The rest of us do just fine using 1 laptop. If you need to change to a new laptop, Mat will send you a new reg key (only a certain amount of times).
  10. Jun 20, 2019 at 9:38 AM
    tonered
    tonered tacorider
    tony
    Lynnwood, WA
    2017 ACLB Sport 6MT BR
    OVT 2.0 87 Test (Order Number 3809), Functional Skewp, 7r41lbr34k3r knob, Debadge, Dechrome, MeSo switch panel and V4s
    Sorry, but this is a piece of cake IMHO. I got a new computer and got a REG file for it quickly.
    In a market where mods are replicated shamelessly, it makes all the sense in the world and is pretty invisible after the first go around.
    BlazinBlueTaco and Shellshock like this.
  11. Jun 20, 2019 at 9:39 AM
    dabbinuguay
    Oregon
    So ....
    My work laptop is a no-go because of corporate anti-virus issues. My desktop is a no-go, because it's a desktop.
    My wife's laptop is an old windows 7 laptop. It will probably end up working, but I don't want to depend on it long term.
    Yes, I will buy a new laptop and be happy, I was just hoping to put it off a bit.
    Again, no big deal, but it delays getting the tune on the truck, so there's that...
    I will be keeping a laptop in the truck for a while, because I've read enough of this thread to see that some issues do pop up, and Murphy's law states that will happen to me in the Alvord desert.
    I'd like that laptop to be more dependable than my wife's old one. (Battery holds a charge for 10min)
    All that up to this point, is entirely solve-able, and I don't really have any issues with that.
    I need a new laptop, I get it, it's fine.
    My main beef ( or concern, or feedback), is the registration/activation process.
    I can't think of any software I use that has this type of registration and licensing process.
    Set it up halfway, send an "EMAIL?!?!?" with some codes, and receive an activation key 1-3 business days later.
    Maybe it's much faster than that, I'm just going by the instructions in PDF file.
    What if you run into an issue and you need to re-flash, or pull codes, or anything in a hurry, but the 1 laptop you have registered happens to be unavailable where you are?
    You can't borrow your buddy's laptop for a day just to get back up and running.
    I get that OV needs to make sure that tunes aren't shared/pirated, but it's 2019. Seems like this is the sort of software problem that has been solved already.
    Maybe there is some logical reason it must be this way.
    Sorry if I sound harsh, but i'm pretty excited to get this tune in.
  12. Jun 20, 2019 at 9:45 AM
    Shellshock
    Shellshock Guy who drives a lot
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    This isn't that bad. try licensing and activating enterprise software. this is nothing.
    blkbelt42 and tonered like this.
  13. Jun 20, 2019 at 9:48 AM
    tonered
    tonered tacorider
    tony
    Lynnwood, WA
    You are making a bit much about it. Use the Win7 machine until you upgrade. If needed, plug in to an extension cord or the bed outlet. I was in the same boat with our old laptop from 2009 that takes 10min+ to fully boot and launch Flash Manager. I'm stoked with the new, smaller machine. If I go on a trip, you bet that it will come along for other reasons.
    I have used plenty of software that locks to computers (dongles, NIC MAC address, and others). It is the way of software registration these days. Yes, there are more invisible means, but do you want to pay another $100 for more elegant licensing? Not me.
  14. Jun 20, 2019 at 9:48 AM
    lapoltba
    lapoltba Well-Known Member
    '17 Sport ACLB V6/6MT OV-Tuned
    I get what you are saying, but automated licensing schemes that are used by other software vendors are backed up by a ton of $$$$ in software development and support. Mat is doing this basically all the software development himself with another developer doing the flash software. I do use software that have some crazy licensing schemes/restrictions (ePlan, GE Proficy, Allen Bradley, Siemens, etc.). In the grand scheme of things, if you have a dedicated laptop, jumping through the hoops once isn't that bad. I personally prefer that Mat spend his efforts tuning than developing a more streamlined licensing method.
    ihatemytruck, dabbinuguay and tonered like this.
  15. Jun 20, 2019 at 9:51 AM
    SpeySquatch
    2016 TRD OR DCSB
    Since we are on the topic of laptops for the tune, I am thinking about buying a new one to get off my work Mac.
    I am a dongle guy (1st gen of OVTune)
    Any recommendations/isights on these? Think I will need a USB splitter/converter?
    I am looking at these for the price and for the fact I will ONLY use it for the tune:
    HP Stream Laptop PC 11.6" Intel N4000 4GB DDR4 SDRAM 32GB eMMC Includes Office 365 Personal for One Year
    https://www.amazon.com/Vivobook-Lig...eway&sprefix=windows+10+laptop,aps,200&sr=8-3
  16. Jun 20, 2019 at 9:54 AM
    tonered
    tonered tacorider
    tony
    Lynnwood, WA
    Edit: Doh! I linked up a Chromebook.
    I'd say that any of those options would be great?
    SpeySquatch likes this.
  17. Jun 20, 2019 at 9:54 AM
    dlo13
    dlo13 Well-Known Member
    Daniel
    SoCal
    2017 Barcelona Red Tacoma TRD Pro
    @OVTune
    I emailed y'all about running your tune with 5.29s and your response was that it works perfectly and there are no issues.
    I then had 2 people in the next 5 days message me on instagram, asking if I was running 5.29s with OVtune...
    They expressed issues with a "Speed governor" and shared that the OV team is aware of this.
    Can you provide some clarification here?
  18. Jun 20, 2019 at 9:54 AM
    lapoltba
    I'm still partial to the Lenovo T430 or T420 linked below. Those Celeron processors are painfully slow and with only 2g of ram you're gonna have a bad time. They will probably work, but it wont be fun. 32Gb SSD is also going to be tight on space to keep windows up to date.
    Hank Heel and SpeySquatch like this.
  19. Jun 20, 2019 at 9:56 AM
    lapoltba
    tonered likes this.
  20. Jun 20, 2019 at 9:57 AM
    tonered
    tonered tacorider
    tony
    Lynnwood, WA
    Oh yeah! I forgot about that.
    Sorry. Editing!
