2016+ Toyota Tacoma OVTUNE 1.05 - Tune Development thread
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Sep 18, 2019 at 9:56 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    We're gonna need feedback once installed, please.
  2. Sep 18, 2019 at 10:00 AM
    ShouldItBeDoingThat
    ShouldItBeDoingThat Well-Known Member
    Scott
    The West
    18' MGM Tacoma TRD Sport OVTuned
    Eibach pro truck kit + Icon 1.5" progressive AAL 255/75/17 Continental Terrain Contact AT LED interior light kit. Derp: wheels, grill
    Will do... will be installed to stock exhaust and y pipe for now fyi.
    wahoobie likes this.
  3. Sep 18, 2019 at 10:03 AM
    Comb
    Comb Known Member
    Nice, I'm curious to know how the sounds changes as well, so that should be easy to hear with the stock exhaust.
  4. Sep 18, 2019 at 10:05 AM
    pkang0915
    pkang0915 Well-Known Member
    Bay Area, California
    2017 Tacoma DCLB OR (first time Taco owner)
    TOYTEC 2.5 kit, SPC UCA, N-fab side steps, TRD pro grille, FN FX PRO Wheels, BFG KO2S (265/70/17 C Rated), TRD Skid plate, Tyger Tonnue Cover, OVtune, Borla S type exhaust
    How are you getting this information? i'd like to do the same so I can send data to mat. Thanks
  5. Sep 18, 2019 at 10:06 AM
    aro
    aro Well-Known Member
    Orange County, CA
    2019 Off Road 4x4 DCLB AT
  6. Sep 18, 2019 at 10:12 AM
    pkang0915
  7. Sep 18, 2019 at 11:06 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    If possible, pay attention to WHEN it's misfiring when you send your feedback to Zendesk. For example, are the misfires generally happening when the engine is cold and warming or more prevalent when accelerating or coming to a stop? No need to post here, but know the detail around when they occur will be helpful to OVTune. For me, stock, I get 2-8 on a cold start in the morning, rarely more - except when it's really cold out. And subsequent starts with a warm engine rarely produce more than 2-3 misfires in a trip, and generally once up to operating temp I'll hardly ever see a misfire. All versions of the tune, for me, have resulting in a tad higher misfire count, but never anything on the verge of a code or any noticeable misfire feeling or loss of power.
    I keep holding out hoping someone will eventually figure out what causes the higher-than-average misfires on some trucks vs. others. And most don't know if it is or isn't until you do some logging since a single cylinder misfire sporadically isn't going to be noticed by the driver generally speaking. I know some trucks hardly ever misfire, and others can have a dozen misfires with no other known performance issues or codes thrown. Something is up there... hello Toyota :)
  8. Sep 18, 2019 at 11:11 AM
    PatricNV
    PatricNV Well-Known Member
    Patric
    Reno, NV
    2018 Cement TRD OR Access Cab
    OV Tune Skinny tires Trail Gear Sliders
    I think you are going to have a hard time with this. Half of us (me included) will want you to rev third to get into fourth at a good power point. The other half will cry about revving their engine too high. This story of my commute is really about this shift point.
    Slammer6 and SpeySquatch like this.
  9. Sep 18, 2019 at 11:12 AM
    aro
    Orange County, CA
    Thanks, I'll make notice of when it happens and will submit to zendesk.
  10. Sep 18, 2019 at 11:45 AM
    mexanese.502
    mexanese.502 Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    Dongle user here and been on latest 2.0. What is everyone using to monitor missfires?
    My truck was built on November 16, but not listed in the CPS TSB. I sometimes get the bumpy road feeling but after 55000 miles it may not be that sensor. No need to replace something that isn't the problem.
  11. Sep 18, 2019 at 11:50 AM
    bshammer0
    Brandon
    Nashville, TN
    Bumpy road is likely (in my experience) more torque converter slip than anything. Likely not a misfire if it's bumpy road feeling
  12. Sep 18, 2019 at 11:53 AM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    @OVTune
    It seems like the shift from 3rd to 4th might be just a difference of opinions, maybe the final release could have 2 different options, that way everyone is happy.
    Personally I don't notice it much and couldn't care less and suspect many feel the same silently.
    Spike91321 and awdvkd115 like this.
  13. Sep 18, 2019 at 11:56 AM
    Deucer01
    Deucer01 Well-Known Member
    Florida
    2017 TRD Sport 4x4 AC
    Got my notification too. Hope the new dump tube tune is released by the time we receive them.
    tater taco likes this.
  14. Sep 18, 2019 at 11:57 AM
    mexanese.502
    Kentucky
    OV Tuned
    Is that torque converter slip typical or part of the tune algorithm? It mostly happens if under low load, low RPM, high gear but hitting the gas to accelerate.
  15. Sep 18, 2019 at 12:13 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Has anybody else had problems with PCM flash recently? I tried twice to flash the latest tune but it couldn’t get past the “identification” step either time. Yes I’m flashing the correct tune/ECU ID, yes I have a dongle (giggity), no I haven’t done anything different than the last time
    SpeySquatch likes this.
  16. Sep 18, 2019 at 12:50 PM
    16taco-trd
    16taco-trd Active Member
    Submit a ticket because Mat needs to hear positive comments as well. If he only receives negative comments the things you like might get changed due to a vocal minority. I previously used a Pedal Commander with more aggressive tip-in, so I am happy with this currently beta tune as well. In the winter, I will just switch back to a base tune if roads are icy.
    El Chivo Norteño likes this.
  17. Sep 18, 2019 at 1:00 PM
    mZiggy
    mZiggy Well-Known Member
    Marc
    '17 Tacoma TRD Pro 6MT (OV tuned)
    @Ruggybuggy and I have/had this. The other day I got locked into the 21150 test file (no longer available, has been replaced by another test map). Nothing I tried worked until Ruggy told me about another time this had happened to him. I had to disconnect my battery and touch the terminals together for a couple minutes to discharge all capacitors and then reconnect, clear DTCs and then was able to flash out.
    Spike91321 and Anchovy like this.
  18. Sep 18, 2019 at 1:15 PM
    bshammer0
    Brandon
    Nashville, TN
    In my experience it's pretty typical though Mat has found ways to address the stumble previously through tuning. My truck does this stock to be clear so it is not something caused by the tune - perhaps its more noticeable b/c of the other changes in power that make you "feel" the momentary feeling of losing power but it still does it stock.
    For example, I can be on the stock calibration, climbing a mountain pass doing 65. Zero misfires, plenty of power to get up and over the mountain, but every few seconds I could feel an ever-so-slight bump feeling, and at the same time see my torque converter value flipping between locked and unlocked. No knock/detonation/misfires... just transmission / TC weirdness. Now that said, I've also run previous (very old and now obsolete) versions of the tune where keeping the TC locked TOO much actually makes it hard to climb. It's almost like the truck is designed to slip to prevent lugging or bogging under load but I'm no engineer nor do I claim to be an expert, but that seems to make logical sense to my lay-brain ;)
    Spike91321 likes this.
  19. Sep 18, 2019 at 1:33 PM
    Anchovy
    TRD Ferguson
    Touch the terminals together?
    And I’ve never cleared the DTCs since I’ve never had a reason to
    blkbelt42 likes this.
  20. Sep 18, 2019 at 1:40 PM
    Laloplus4
    Laloplus4 Well-Known Member
    Jose
    2007 white tacoma trd off road 2004 tacoma king cab short bed supercharged
    Trd pro grill , afe intake with scoop and throttle spacer
    Highly tempting ! :turtleride: tune = :burnrubber:
