2016 Toyota Tacoma takes on the Ike Gauntlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Johnny919, Jan 14, 2016.
  1. Jan 15, 2016 at 5:44 PM
    #41
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yeah right, only recently Civic got the engine with timing chain (2006+) and I don't know how much you know about Honda engines but probably this is not the example you want to bring it up.. :D
    http://www.civicforums.com/forums/1...06-2009-warranty-extension-engine-blocks.html
  2. Jan 15, 2016 at 6:08 PM
    #42
    Ang graz
    Ang graz Active Member
    2016 DCLB SR5 4x4 BRM
    And that would be 10 years now. Numbers don't lie. Face it, very car company has some kind of issues. So if the Tacoma is designed to run at high rpm to reach peak power under a load as it was in the video, why would they have it like that if failure is inevitable? Maybe Toyota should hire you and you can fix all their problems and tell them how to do it the right way. Apply at Honda too while you're at it
  3. Jan 15, 2016 at 7:32 PM
    #43
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    From the Duramax owners manual.
    My 4 stroke dirt bikes have timing chains and they last and I run the hell out of them. Timing chain rarely needs replaced. Usually I just do the piston and rings for peace of mind but they're still within tolerances.
    Ang graz[QUOTED] likes this.
  4. Jan 15, 2016 at 7:36 PM
    #44
    dwindeck
    dwindeck Member
    Really surprised at the drag race results. 2015 smokes the 2016. Not sure of the distance they were running...hell the first gen manual beats it, maybe due to lighter weight I guess
  5. Jan 15, 2016 at 7:40 PM
    #45
    Johnny919
    Johnny919 [OP] Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Out of all the midsize trucks...i've got to say i'd probably feel the most confident with the tacoma. I am curious however how the chevy will do. I wonder if they are going to do another run with the 3.6L v6 or just keep the stats from last year. They should do it again though since the whole point system has changed, not that it matters. Think it's pretty funny how they changed this whole point system starting with the new tacoma though.
    The diesel colorado or canyon would be interesting though...i'm sure the mpg will be better than the tacoma, but i'm guessing the time will be much worse. They are going to be towing with the new ridgeline as well, will be looking forward to that.
  6. Jan 15, 2016 at 7:43 PM
    #46
    Johnny919
    Long Island, NY
    Yep...i know the 3rd gen is about 200-300 pounds heavier than the 2nd, so the 1st gen is most definitely lighter. Also the 1st gen was a manual so that helps. I think maybe if they sport shifted the 2016 it may have won, but who knows.
  7. Jan 15, 2016 at 7:50 PM
    #47
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    The drag race doesn't surprise me in the least. Obviously the lighter car will win in most cases. 4.0 will naturally beat the 3.5L off the line but if they were to race to 90 mph I bet the 3.5 would win because it has the HP edge.
  8. Jan 15, 2016 at 8:01 PM
    #48
    Kevindust
    Kevindust Well-Known Member
    Kevin
    Ottawa, Canada, eh
    16 DCSB 6M 4x4 TRD Sport Upgrade BBM
    The 2016 seems to go a little sideways at the start of the run, or the driver is pointing less than straight. They didn't even have the decency to go to a drag strip/ or set up timing lights. This one-off video in cold weather testing is less than meaningless...(and I don't own a 2016 so I've got no stake in this.)
  9. Jan 15, 2016 at 8:05 PM
    #49
    Johnny919
    Long Island, NY
    Haha yeah I just noticed that, it looks like that happened during both races. I wonder if it was even a 0-60 run...seemed like it could have even been shorter than that.
  10. Jan 15, 2016 at 8:36 PM
    #50
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    It was shorter for sure.
    This is at a go kart track.
    We race supermoto there.
    That back straight where they do the drag race is just long enough for me to hit 85mph on the bike before I have to brake hard to make the corner
    Johnny919[OP] likes this.
  11. Jan 15, 2016 at 8:44 PM
    #51
    Johnny919
    Long Island, NY
    Ah, that's what I thought. What bike do you have or used? Let me guess, DRZ400SM - that seems to be the go to bike for super moto.
  12. Jan 15, 2016 at 9:34 PM
    #52
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I'm one of the biggest critics of the 3.5 but I have to say it towed good... Revving high like I new it would but it can do the job...
    In the 2015 test they had to slow down but the 2016 clearly out pulls it once it's revved up and better trans and gearing combo...
    The 4.0 seems to get up to speed better but the 3.5 seems to hold speed better.....
  13. Jan 16, 2016 at 12:39 AM
    #53
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    The 2016 has more HP than a single vvti 1GR yes, but it does not have a better trans. The 5-speed A750>>>>>>>>>>>>>>>>>AC60 trans from the 3rd gen 4/6cyl.
    I bet the trans temps were way up there during the climb.
  14. Jan 16, 2016 at 2:18 AM
    #54
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Just curious, why is the A750 better?
  15. Jan 16, 2016 at 6:37 AM
    #55
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Yep drz and crf450
    Johnny919[QUOTED][OP] likes this.
  16. Jan 16, 2016 at 6:49 AM
    #56
    Johnny919
    Long Island, NY
    Nice, was thinking about getting the drz before i got my cb919. Would be cool if honda made something from the factory to compete with the drz. They only got the crf250l and 650 dual sports.
  17. Jan 16, 2016 at 9:17 AM
    #57
    TacoJonn
    Jon
    Laramie, Wyoming
    Trans temp stayed in then normal range. That is where having the tow package is important. It has a transmission cooler.
  18. Jan 16, 2016 at 9:22 AM
    #58
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Where's the test with a manual?
    Kevindust likes this.
  19. Jan 16, 2016 at 3:41 PM
    #59
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    WOT test on the three lane stretch from Silverthorne uphill to the tunnel.
  20. Jan 16, 2016 at 6:10 PM
    #60
    TacoJonn
    Jon
    Laramie, Wyoming
    They really should do a test with the manual. I haven't seen an Ike Gauntlet test with a manual yet. Would be more of a test of the driver rather than the truck though. What I like about these tests is they don't try to fiddle with the paddle shifters. They let the truck figure it out.
    jonnyozero3 likes this.
