2016+ Toyota Tacoma V6 ECU Tuning Alpha Release
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Jan 11, 2019 at 3:17 PM
    lapoltba
    lapoltba Well-Known Member
    '17 Sport ACLB V6/6MT OV-Tuned
    None
    That almost sounds like a fuel pump issue...? In-tank fuel filter? I don't think we have a fuel filter outside the tank.
  2. Jan 11, 2019 at 3:23 PM
    MOC221_
    MOC221_ 3rd Gen GinGer StepchilD
    Frank
    2016 OR AC 6MT
    OVT 1.05 MA 91
    @DCSBMurph ,
    Those codes indicate both banks too lean. Is 1.05 your first tune flash?
    I only ask because you said you've had a CAI for a long time..
    DCSBMurph, Reypac24 and bshammer0 like this.
  3. Jan 11, 2019 at 4:51 PM
    SpeySquatch
    SpeySquatch Well-Known Member
    C.
    2016 TRD Off-Road DBLCB SB
    ADS Extended Travel 700# adjustable resi fronts, OME Med. Dakar pack. LightRacing UCA's C4-Fab Lo-Pro bumper, Smitty Syn 9500 winch 255/75 R17 Hankook Dynapro ATM, SoftTopper, BAMF kickout sliders
    So you like the first version (out of the 3) of 1.05.?
  4. Jan 11, 2019 at 4:56 PM
    LDS 77
    LDS 77 Active Member
    2016 taco trd OR
    I think it’s actually the second version. It was the mass email release for 04b04 just before New Years.
    I might try 1.05 87 to see if it’s better but it’s nice now so I don’t know
    SpeySquatch and tjpratt like this.
  5. Jan 11, 2019 at 5:06 PM
    DCSBMurph
    DCSBMurph Active Member
    Joe
    Maryland
    2017 DCSB Blazing Blue TRDOR
    HIDs, CAI, OVTuned
    Yes first time flashing this truck. Dont notice any driveability or idle issues when these codes appear on either occasion
    MOC221_ likes this.
  6. Jan 11, 2019 at 5:06 PM
    GoldenBrew
    GoldenBrew Over-Geared according to the "Math"
    Golden, Colorado
    2016 TRDOR DCSB V6 AT 4x4
    4.88's, OVTune 1.05 and other useful stuff
    This. many post on the CAI with this mod that have code (lean and or O2 sensor) due to K&N filter element oil fouling MAF. Get rid of the oiled filter and go back to the dry filter.
    PhogDog likes this.
  7. Jan 11, 2019 at 5:09 PM
    DCSBMurph
    Joe
    Maryland
    HIDs, CAI, OVTuned
    This intake uses a dry filter. Havent used an oiled filter on my last few vehicles
  8. Jan 11, 2019 at 5:16 PM
    GoldenBrew
    Golden, Colorado
    Well that sucks! who's CAI are you using? I run the @G Tek Fab stock air box mod and have never had issues before or after Tune.
  9. Jan 11, 2019 at 5:19 PM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    The endless ticket spree continues lol.
  10. Jan 11, 2019 at 5:25 PM
    DCSBMurph
    Joe
    Maryland
    HIDs, CAI, OVTuned
    K/N blackhawk
    MOC221_ likes this.
  11. Jan 11, 2019 at 5:30 PM
    GoldenBrew
    Golden, Colorado
    well only a few paths to take to isolate the issue. Start with clearing the codes - can be done via the Tune flash software. Check the MAF sensor connection and sensor for contamination - downstream from the air box. Check the O2 sensor connections on the exhaust. Hope you get it figured out.
    DCSBMurph and MOC221_ like this.
  12. Jan 11, 2019 at 5:34 PM
    chasenicholas93
    chasenicholas93 Well-Known Member
    Nicholas
    2017 Toyota Tacoma
    Just curious. Any stock trucks experiencing 2nd gear torque converter switching in and out with steady throttle? Also, 3rd gear short shifting to 4th? Have 1.05 91 tune.
    Egnaro, treimche and bshammer0 like this.
  13. Jan 11, 2019 at 5:42 PM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    3rd short shifting to 4th is intentional, unfortunately.
    I suggest using the ECT button til custom tunes.
  14. Jan 11, 2019 at 5:44 PM
    tjpratt
    Travis
    Aurora, Colorado
    I think I may also swap back to the original file. I'm the same truck as yours. 4" lift, 275's, armor, stock gears, shell, B04.
  15. Jan 11, 2019 at 5:48 PM
    MOC221_
    Frank
    2016 OR AC 6MT
    OVT 1.05 MA 91
    Well, after reading through the diagnostic procedure for those codes you get to a point where active tests can be done with techstream to see if the system remains lean in real time. If after forcing the use of direct injection and then Port injection, and the system is still lean on both, this is next:
    Keep in mind that one of the first things Mat did long ago was to lean this sucker out. Perhaps that IN ADDITION to your CAI is causing the codes to be set. Just a guess...
    taco 16, DCSBMurph and PhogDog like this.
  16. Jan 11, 2019 at 5:49 PM
    lapoltba
    None
    Seems like a custom tu e may be in order...
  17. Jan 11, 2019 at 6:44 PM
    DCSBMurph
    Joe
    Maryland
    HIDs, CAI, OVTuned
    Thank you guys for the quick replies. Definitely some things to think about. I dont believe it's a major issue because like I said I dont notice any driveability or idle issues. The hesitation and misfires went away as soon as I flashed and havent returned so that is a good thing.
    MOC221_ likes this.
  18. Jan 11, 2019 at 7:50 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    @OVTune, no problem with 87. When in town, drinks on me...
    2016trdtacoma likes this.
  19. Jan 11, 2019 at 8:00 PM
    SpeySquatch
    C.
    Judging by how blurry that pic is...yes, drinks in you lol.
    Just playin. Happy Friday!
    MOC221_, 2001 4x4, skyking3 and 7 others like this.
  20. Jan 11, 2019 at 8:04 PM
    Vlady
    Issy, WA
    Well, I need a new suspension now for my galloping Gertie.
    SpeySquatch likes this.
