2016+ Toyota Tacoma V6 ECU Tuning Alpha Release
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Feb 11, 2019 at 8:28 AM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    Well the past ETA's for the handhelds are....past. What's the plan?; wait until...when? If whatever they're waiting for isn't working, yes, absolutely go another direction.
  2. Feb 11, 2019 at 8:30 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    Maybe you should take your own advice and go another direction then?
    SK808 and ihatemytruck like this.
  3. Feb 11, 2019 at 8:32 AM
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    Yes boost!!!!!
    Also, what is the most recommended app for logging now? I see a lot of you guys mentioning techstream, Carista, obfusion. Where do I start?
  4. Feb 11, 2019 at 8:33 AM
    navin r
    So everyone should just silently wait? It's out of bounds to ask for an update? I'll keep asking until they either show up or TW bans me for asking.
  5. Feb 11, 2019 at 8:35 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Just got my truck back from body shop (2 weeks see my other thread) and it runs better on 87 1.05 because they had the battery disconnected for an extended period of time!
  6. Feb 11, 2019 at 8:49 AM
    BLUTRD
    BLUTRD Member
    Jesse
    Nazareth,PA
    2017 TRD OR
    3”level lift - front, 1” - rear. 285/70R17 BFG KO2’s,Fuel rims, Tyger sliders,MBRP catback, K&N intake, B&M shifter handle,old man emo center bearing drop spacer, clam shell busing up front,window vents,LED lights etc.....
    Correct, I have the tactrix driver. Tried that too then the copy and paste the key number wouldn’t work!
    Just following the instructions.....It’s not a real big deal just wanted to update and change a few things if I got it to work.
  7. Feb 11, 2019 at 8:52 AM
    Oscar I
    Oscar I That F-N-G
    North Utah
    DCSB OR Cav Blue
    Do you get a robo response for every email to them confirming receipt?
    I did for the first two I sent. Did not get one for the last.
  8. Feb 11, 2019 at 8:55 AM
    Oscar I
    Oscar I That F-N-G
    North Utah
    DCSB OR Cav Blue
    I use obd fusion. It's better than torque and uses a bluetooth adapter.
    If you want to not spend anymore money you can log with techstream but that requires the cable to be plugged in. I prefer the wireless bluetooth to my mounted tablet
  9. Feb 11, 2019 at 9:12 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Did you move MainMenu file to bin directory?
  10. Feb 11, 2019 at 9:16 AM
    L-SCHLEGS
    Nashville, TN
    2017 CEMENT TRD PRO
    Does it work with iPhone instead of tablet?
  11. Feb 11, 2019 at 9:26 AM
    Oscar I
    Oscar I That F-N-G
    North Utah
    DCSB OR Cav Blue
    There is a version that works on Apple but you're going to pay a lot more for the Bluetooth adapter . apple is a bunch of dicks
  12. Feb 11, 2019 at 9:27 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Apple doesn’t control the cost of aftermarket ads-ons :confused:
    TFly likes this.
  13. Feb 11, 2019 at 9:32 AM
    lapoltba
    lapoltba Well-Known Member
    '17 Sport ACLB V6/6MT OV-Tuned
    They do however control how the Bluetooth in their phones works. Recall they didn't even enable it until people complained enough. The hardware was there, they just refused to support it. Or maybe I'm thinking of the Ipod touch.....
  14. Feb 11, 2019 at 9:40 AM
    Anchovy
    TRD Ferguson
    Probably the touch
  15. Feb 11, 2019 at 9:46 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Tampa, FL
    2018 Super White TRD OR DCSB
    Just an FYI for the uninformed....
    iPhones and ODB Fusion only work with a WiFi ODB adapter. No Bluetooth. Of course, once you’re connected to the adapter, you can’t access Google Maps or stream over LTE, as your phone thinks you’re on WiFi.
  16. Feb 11, 2019 at 10:05 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    OBD Fusion on my iPhone works on Bluetooth LE
  17. Feb 11, 2019 at 10:12 AM
    HelloMyNameIs
    What adapter do you have?
  18. Feb 11, 2019 at 10:27 AM
    BLUTRD
    BLUTRD Member
    Jesse
    Nazareth,PA
    2017 TRD OR
    Yes I did! Tried a few other versions and get the same thing. Problem with the key number? Maybe win 10 issue?
  19. Feb 11, 2019 at 10:32 AM
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Veepeak OBDCheck BLE OBD2 Bluetooth Scanner Auto OBD II Diagnostic Scan Tool for iOS & Android, Bluetooth 4.0 Car Check Engine Light Code Reader Supports Torque, OBD Fusion app https://www.amazon.com/dp/B073XKQQQW/ref=cm_sw_r_cp_api_i_j-ByCbQNPQ9HH
    Rocinante75 and L-SCHLEGS like this.
  20. Feb 11, 2019 at 10:36 AM
    Oscar I
    Oscar I That F-N-G
    North Utah
    DCSB OR Cav Blue
    Awesome that it works but it is three times the price of a 1/4 just Android
