2016 Transmission T-SB-0077-16 Shift Feeling Enhancments (PDF)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Danielnc06, Jul 14, 2016.
  1. Jul 15, 2016 at 5:32 PM
    #181
    taco2020
    taco2020 Member
    16 ORLB 4x4
    Just had the TSB completed and here's what i'm noticing so far (only 6 miles)
    - Shift from P > D: slight improvement. Don't have to hold the brake down hard for the truck not to lurch, but does still bump a bit if i'm not holding the brake.
    - Previously, when at a stop (in gear) and easing on the gas, there was hesitation and a bump once the gear caught. This is no longer the case.
    - Shifting through gears seems much better. Previously, it would constantly shift to a higher gear and created a lag feeling. I would say its somewhere between ECT and where it was before.
    - Previously, when coming up to a stop, there was a hard down shift with a clunk into 2nd. Seems better but need to drive it more to figure this out as it wasn't always every time
    Overall, it does seem better particularly once on the go. I'll have a chance to try cruise control and some hills later. Going to still have someone check the ATF level (even though the dealer said they did a few days ago).
    9TRDTCO, Kilokato and 08sprsnke like this.
  2. Jul 15, 2016 at 5:36 PM
    #182
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    I can not get this to open after downloading can you post the TSB # please
  3. Jul 15, 2016 at 5:41 PM
    #183
    taco2020
    taco2020 Member
    16 ORLB 4x4
    It's in the name of the thread. TSB007716
    whopper[QUOTED] likes this.
  4. Jul 15, 2016 at 5:46 PM
    #184
    xSocotaco
    xSocotaco Member
    16 BLK DCLB TRDOR 4x4
    I took my truck into the dealer today and they told me the TSB is not released yet. Is there any way that could be true? Maybe released to some larger dealers and not others?
  5. Jul 15, 2016 at 5:48 PM
    #185
    taco2020
    taco2020 Member
    16 ORLB 4x4
    My service rep asked the head tech to find out. Said they usually hear about these from the customer and not Toyota. I've seen other posts in here from people that said it took a couple of calls before the dealer found the TSB.
  6. Jul 15, 2016 at 5:52 PM
    #186
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Might want to check fluid level... bettcha yer low..!!
  7. Jul 15, 2016 at 5:56 PM
    #187
    Sandbager
    Sandbager Active Member
    ALABAMA
    2016 Quicksand 4X4 TRD Sport Double Cab
    none
    I contacted my service representative this morning and he had loaded T-SB-0077-16 on the vehicle he was proved by the dealership to try and understand the different problems associated with the Tacoma. He indicated it corrected the issues with the ones identified. I took my truck in this morning and had the fix installed and now I can say it is 100 percent better. It actually changes gears as you would expect. I am finally happy with the trans issue. My other concerns are the brake vibration issue and the drive shaft vibration issue. I have been told there is a TSB in process of being developed for the drive shaft. The brake issue has not been addressed. Will have to wait and see what happens.
    ISAN_TACO, Kilokato, BGXtobe and 2 others like this.
  8. Jul 15, 2016 at 6:20 PM
    #188
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    Agree
  9. Jul 15, 2016 at 6:25 PM
    #189
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    If you're referring to the gear hunting problem on climbs then this TSB doesn't claim to remedy it. I'm referring to the continuous upshift/downshift loop that happens when it prematurely upshifts on a climb causing it to lose speed and then it immediately downshifts again and you get stuck in this loop. Seems like it'd be straightforward to improve the software by just turning off the Atkinson mode and the urge to upshift when the engine is under load.
    Even though the TSB doesn't state that it adresses the above issue, I wonder if it still might. This could be an overall tranny upgrade that masquerades as a fix to a minor issue.
    Kilokato likes this.
  10. Jul 15, 2016 at 6:35 PM
    #190
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    It says it replaced your ECU. Is this correct ???
  11. Jul 15, 2016 at 6:35 PM
    #191
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Surprise surprise! Mine’s on the list but no issues here. (Whew!) DZ5BN
    But as I’ve been saying when I first posted about this problem, nothing’s wrong with the transmission or ATF lvl, it’s in the software.
    I do hope you haven’t overfilled your transmission by now or introduced contaminants in the attempt to fill/check it as you may continue to have problems.
    Moreover, some small/minute number may still have problems as all makes/model have, but over all, everything’s gonna be alright and the ’16 will be revered as all the others when the '17 comes out.
    Enjoy your truck! (I hope) :/
    Cheers!
    2016Tacoman likes this.
  12. Jul 15, 2016 at 6:38 PM
    #192
    over60
    Muskoka, Ontario
    Note the TSB number .... "0077-10...." What the F... the dealer don't know shit..
    MTNHABITOVERLAND likes this.
  13. Jul 15, 2016 at 6:45 PM
    #193
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    I noticed pistol pete has a 2010 tacoma in his sig, maybe that is why the tsb ends in 10? Where as the 2016 tacomas tsb end in 16?
    Does pistol pete know this is for 3rd gen tacomas? 2016+?
    Unless he has a 2010 and a 2016 and just hasn't listed it.
  14. Jul 15, 2016 at 6:46 PM
    #194
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Honestly, I didn't pay that much attention because I was playing with my new remote start and was excited to try the tranny out on the road. I gave the TSB number from this thread (showed it from on my phone) to the accessories rep that set up my appointment. When I picked it up he said that they reflashed it.
  15. Jul 15, 2016 at 6:47 PM
    #195
    Pistol Pete
    Eric
    Oklahoma
    It says sold next to the 2010 ;)
  16. Jul 15, 2016 at 6:48 PM
    #196
    Johnny919
    Long Island, NY
    Well i guess you were due for an update then i guess lol. Atleast you had good results from it.
  17. Jul 15, 2016 at 6:49 PM
    #197
    Johnny919
    Long Island, NY
    Oh, i don't see that. Just says vehicle: 10 prerunner sr5 trd sport
    So you have a 2016 then? If that is the case, not sure why the tsb number is off then...maybe just entered it wrong?
  18. Jul 15, 2016 at 6:55 PM
    #198
    Pistol Pete
    Eric
    Oklahoma
    Probably just entered wrong :notsure: He definitely didn't say they replaced my ECU, that would be crazy with less than 500 miles on the truck.
    Johnny919[QUOTED] likes this.
  19. Jul 15, 2016 at 6:57 PM
    #199
    Johnny919
    Long Island, NY
    Ah gotcha. Well I am glad you got it fixed, sorry about the confusion!
  20. Jul 15, 2016 at 7:50 PM
    #200
    justguth
    justguth We beefin??
    2016 White TRD OR DC 4x4
    I saw that whole thing in my head and died laughing. Funny shit.
