2016 Transmission T-SB-0077-16 Shift Feeling Enhancments (PDF)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Danielnc06, Jul 14, 2016.
  1. Jul 19, 2016 at 4:48 AM
    #421
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Got mine done yesterday, and it seems to have helped. I'm looking forward to the changes it made No grief was given only they were not aware of the update yet it was found and done. However I know the writer from a 2000 corolla I owned that I battled with corporate on for a lemon law on after 3 new transmissions in 12000 miles I have had 7 new Toyotas. I have the SR edition with steel wheels this is not related but I found some wheels from a 2014 with tires on them only my TPMS sensors wouldn't swap wrong angle any suggestions on my 2016 they had rubber stems and no tpms.
  2. Jul 19, 2016 at 5:31 AM
    #422
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    Do they still need to replicate the issue even if the vin is on the tsb??
    I already left it with them and they couldnt replicate it. This morning was the worste. I counted 7 seconds of limbo between reverse and drive
    deergetr likes this.
  3. Jul 19, 2016 at 7:17 AM
    #423
    davidsp101
    davidsp101 Well-Known Member
    David
    Columbia, SC
    2017 TRD OR 4x4
    Anyone have luck with dealers in Columbia, SC? I'm taking mine to Jim Hudson today but I'd like to have a backup if possible.
  4. Jul 19, 2016 at 7:18 AM
    #424
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I'm driving to work on a route I know well with no traffic. I'm going to drive in D without going into s5 and see what happens...
    The door says 29. Most of us run them harder
    They told me they couldn't replicate it because they drove around the streets. But they did flash anyway because the VIN was in the group listed
    sorgon82[QUOTED] likes this.
  5. Jul 19, 2016 at 7:25 AM
    #425
    Cavedog
    Cavedog Well-Known Member
    Eric
    Southern Minnesota
    2016 MGM AC Sport 4x4
    It's important to get your tread flat with the road. It wont' happen with 48psi, especially in the rear. You'll get better mileage but your tires will wear the middle bald with 90% tread left on the shoulders lol. I suggest doing a chalk test:
    Edit: Just to clarify, the chalk test will show you if you are quite a bit off of where you should be with tire pressure. Keep in mind the sidewall pressure listed on the tire is the MAX the tire can hold, not the normal operating pressure. From the scale I put my truck on it says my truck is around 4800lb, with me in it (access cab). If the sidewall rating is 51psi and the tire rating (for your off-road stock tires) is 2484lb per tire (I got this from tirerack, with goodyear adventure kevlar 265/70R16, correct me if I'm wrong) then we should calculate as follows:
    tire max load x 4 = 2484 x 4 = 9936lb max vehicle weight
    tire load % = 4800/9936 = 48%
    recommended tire pressure = 51psi x 0.48 = 24.5psi
    This is probably skewed since the front is much heavier than the rear. Also, you'll get better ride quality and steering response with a little more pressure so I'd recommend 28-32psi.
  6. Jul 19, 2016 at 7:26 AM
    #426
    bryanjoh
    bryanjoh Well-Known Member
    Bryan
    Calgary
    2016 DCLB TRD Sport
    I'm going in to drop mine off Wednesday night in Calgary as well (Stampede Toyota) and was a little worried that the "Market: USA" thing may bite me in the ass even though my VIN is included. I was previously in for fluid check a couple months ago and that service form specifically stated "delay from R to D", so I'm hoping that may help me out in convincing them this is a real thing.
    They did my fluid check with no complaints, so I'm hoping they will be on board with this as well.
    Herniator likes this.
  7. Jul 19, 2016 at 7:51 AM
    #427
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    You'll be fine like that at 48lbs if the sidewall says 51. I've run all mine like that and have discarded them after 70k with usable life left. But its important to rotate them every 5-7k and keep them balanced.
    Running a tire under inflated at higher speed could build up heat and make it subject to a blow out. That's the very reason It states on the side wall MAX load pressure.
    In other words, If you're running max loads, air up! If not, stay a few lbs under it to counter middle thread wear, get longer overall tire life, better mileage, and handling.
    But if you want better traction, more ride comfort go with the sticker on the door pillar.
    Hope that helps
    Cheers!
    sethhawaii[QUOTED] and bert8 like this.
  8. Jul 19, 2016 at 7:54 AM
    #428
    bert8
    bert8 Well-Known Member
    Brett
    Ontario
    2016 TRD Sport DCLB + Tech - Inferno
    Tint, tonneau, bed mat, derped
    Hey Canadians, any more info on how Canadian dealerships are handling this? I have an appt at the dealer tomorrow to fix noisy wipers and get tranny fluid level checked. I'm going to bring the tsb printout with me and see what they say.
  9. Jul 19, 2016 at 8:18 AM
    #429
    Jbeiker
    Jbeiker Well-Known Member
    2016 Trd Sport
    Hey guys wanted to pass along my feedback. I just got the tsb update done to my 2016 double cab. Prior to the update I was experiencing
    1) a major delay from reverse to drive (probably 3-5 seconds each time)
    2) surging when pulling out slowly from my garage or pulling into the garage
    3) shift points seemed sluggish and off causing acceleration especially in first gear to be slow
    These were my major issues prior to the update. Since then
    1) minor to almost zero delay from reverse to drive! This was a huge win for me as before the surge and lunge of it hitting drive was concerning of damage.
    2) no more surging when pulling slowly in or out of garage. Another huge win as nothing sucked more to be creeping in on your tool box for a sudden surge to take place and damn near hit the toolbox.
    3) first gear is a whole lot more responsive now
    All of these are huge wins for me as I love my truck and this tranny concern was the only real drawback! Good luck to all the others with the update!
    08sprsnke, NorCalTaco and Schyfy like this.
  10. Jul 19, 2016 at 8:33 AM
    #430
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    After experiencing the surge pulling into the garage my wife has refused to drive my truck again. So my question is should I not get it fixed or have it fixed and just not tell her?
  11. Jul 19, 2016 at 8:35 AM
    #431
    Jbeiker
    2016 Trd Sport
    @melikeymy beer ^^^^ that was epic hahaha! Solid point. In your shoes I would fix it and not tell her. She already has the fear so she won't test the waters again hahahah :cheers:
    :notsure:
    JayDubya and melikeymy beer like this.
  12. Jul 19, 2016 at 8:42 AM
    #432
    jdpatchin
    jdpatchin Well-Known Member
    Jake
    Bozeman, MT
    2016 Ram Power Wagon
    Softopper, Amp Power Steps
    Used the online scheduler to setup an appointment with Wilsonville Toyota in NW Oregon for friday afternoon. Hopefully they won't give me any issue about having to replicate it. The random surging in stop and go traffic is annoying. I'll update on how they handle it when I go in!
    Kilokato likes this.
  13. Jul 19, 2016 at 8:47 AM
    #433
    darncart
    darncart Well-Known Member
    Boss ignored that I had a work offsite scheduled for tomorrow and scheduled me for a presentation during my appointment. Had to reschedule for Monday.
  14. Jul 19, 2016 at 8:49 AM
    #434
    Z50king
    Eric
    Southern California
    Stock and loving it
    I left my truck in D when going up the hill and it only shifted into 5th instead of 4th. Before, it would hold 6th too long and then drop down through 5 to 4. This time it dropped to 5 a little earlier going up the hill but did not drop to 4. Then it upshifted near the top and held 6th all the way over
  15. Jul 19, 2016 at 8:52 AM
    #435
    ÜberToyota
    ÜberToyota Well-Known Member
    Jay
    PoCo BC Canada
    2018 MGMDCLB TRD SPORT TECH PKG
    ROLL-N-LOCK Cover, Rear Tailgate Actuator Lock, 26570R17 BFG K02
    Went in Yesterday to the dealer in Port Moody BC Canada and second time I commented on the tranny. They tried to do the tsb I showed them as mine is on the list a Texas made dz5bn and failed to do the update five times ? They did however do a manual inspection and found and added .5 quart of tranny fluid. So far No difference any ideas go to a diff dealer ? Also I thought dealer could adjust odometer to calibrate for diff tire size they said not poss true/false anyone!
  16. Jul 19, 2016 at 9:03 AM
    #436
    OkTacoTRD
    OkTacoTRD Well-Known Member
    Jerry
    2016 Black Tacoma TRD Off Road
    My dealer said they could not make the adjustment for different size tires.
    ÜberToyota[QUOTED] likes this.
  17. Jul 19, 2016 at 9:21 AM
    #437
    Slipstream87
    Slipstream87 Well-Known Member
    Andrew
    2016 DCSB TRD Sport 4X4
    5100's w/ 285 KO2's, AFE CAI, MBRP Catback, BAMF Grill, remote start, oemaudioplus setup, sound deadened
    i actually had the service guy notice i was coming in to talk about the purchase of a fleet truck for my company and came and told me they had a tsb for it. I went from sales floor straight to service department and its going in tomorrow. Nothing required of me since he knows ive had issues in the past
  18. Jul 19, 2016 at 9:40 AM
    #438
    Weedly
    Weedly Well-Known Member
    Doug
    Collingwood, On. CAN
    2022 DC TRD Sport in Lunar Rock, 1988 RX7 Convertible
    I've been complaining to my dealership of this issue since taking delivery in October. My sales rep is a good friend, also driving a 2016 Tacoma and he has been experiencing the same issue and talking to service about it. I have my 16000 km service (yup, Canada) scheduled for Thursday so I emailed my buddy the TSB and asked that he bring it to the tech's attention. I'm hopeful that they will take care of it rather than blow me off as it originated in the states. I'll fill you in on the results.
    On a side note, my BSM failed mid winter and the dealership has been telling me it can't be fixed till they get a special calibration tool...6 months now and no tool! Getting a little pissed at Toyota.
  19. Jul 19, 2016 at 10:12 AM
    #439
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    Good luck! I called Toyota of Portland first and they said if I don't have a symptoms that is described on TSB they won't do it. Next day I went to Ron Tonkin(last Saturday). I just walked in showed advisor TSB on my phone and they took my truck. I was there for four hours but I'm happy with update!
  20. Jul 19, 2016 at 10:35 AM
    #440
    AZTaco13
    AZTaco13 Well-Known Member
    Rob
    2016 Tacoma TRD Off-Road
    Went to the dealership here in Mesa, AZ. Brought in the TSB PDF and before I mentioned it he said no problem they will take care of it. Didn't even have an appointment. I really can't believe some of the stories I've seen of people who present with a TSB and still get refused.
