2016 Transmission T-SB-0077-16 Shift Feeling Enhancments (PDF)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Danielnc06, Jul 14, 2016.
  1. Sep 15, 2016 at 6:48 PM
    #1921
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    They only fixed the R to D delay because that's all s/w could do.
    Wonky trans persists. Toyota should've geared it to compensate for the EPA lame ass requirements. Big fail.
    Ford and Nissan will be the benefactors of the major misstep.
  2. Sep 15, 2016 at 9:06 PM
    #1922
    mangler
    mangler Well-Known Member
    Saskatchewan, Canada
    1998 Tacoma 4x4
    Only got my 2016 three weeks ago but noticed something didn't feel quite right, had the upshift issue on cruise, and noticed a delay from R to D , had to explain to my dealer what the problem was and show them the TSB that was posted here . Shifting does feel smoother and no more delay from R to D , will take her out on the highway tomorrow to test the upshift on cruise
    Tcoma16 likes this.
  3. Sep 15, 2016 at 9:30 PM
    #1923
    Tcoma16
    Tcoma16 Galatians 2:20
    California
    2016 TRD Sport
    Thanks OP for the thread.
  4. Sep 15, 2016 at 10:09 PM
    #1924
    WMDtech
    WMDtech Well-Known Member
    Nate
    TN
    2018 TRD OR 4X4, White, DCSB
    None... sigh
    Had mine done during my 10K service. Highway performance is a lot better in my opinion, meaning I can now use cruise control. Still averaging 22-24 mpg depending on what I'm doing. Really haven't seen less than that at all. Actually impressed with how the truck feels now, except that when the truck is cold I still sort of feel the hard upshift from 2-3. Anyone else still noticing it?
  5. Sep 16, 2016 at 1:46 PM
    #1925
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Yeah, got it done.. told them about it and they did it without trying to "replicate" the problem... Print a copy for them and then ask them if they will do it for you...make sure to tell them you have 1 or more of the issues that the TSB addresses...
    Good luck man..
  6. Sep 16, 2016 at 1:51 PM
    #1926
    vmantrdorlb
    vmantrdorlb Well-Known Member
    Oklahoma
    2016 Toyota Tacoma TRD SPORT LB
    TRD Wheel + General AT2 265/70/17
    im going to try and disconnect battery to see if it resets ecu, worth i try i guess.
  7. Sep 16, 2016 at 2:24 PM
    #1927
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Post up if that helps. I am still using ECT up to cruising speed and then cut it off. Still maintaining 20 mpg in all city driving so that works well for me. Mine reverted back to doing a 1-2 and 2-3 slide shift without ECT. It really truly has similar power to my old 2000 4 cylinder automatic Prerunner in the lower speeds. And that had oversized tires. Think it had a 390 rear axle. Actually the 2000 had better 0-35 performance than my 16 in drive without ECT. The only other issue I had was R-D and P-D hesitation which is still fixed. I have had several road trips including to the Blue Ridge twice and have no issues between 45 and 75 mph with cruise on as others had.
  8. Sep 16, 2016 at 2:38 PM
    #1928
    over60
    Muskoka, Ontario
    Sounds like you qualify... have you not noticed the tranny when in CC over a hill will downshift as normal then NOT upshift when over the hill... That was MY main issue...
  9. Sep 16, 2016 at 3:46 PM
    #1929
    bwonger
    bwonger Unknown Member
    Brian
    Santa Barbara, CA
    2016 DCSB 4x4 OR Super White
    I always thought that was just "engine braking" to keep the truck at the set CC speed going downhill.....guess i was wrong! It's fixed with the TSB.
  10. Sep 16, 2016 at 4:13 PM
    #1930
    over60
    Muskoka, Ontario
    Not sure what you are saying here...!! But this issue ONLY happens in CC... It will down shift for hill and then over the hill will refuse to go back up to 6th, without a push on the gas pedal...then it will shift...
    Since my TSB.. I do not have this issue anymore... (of course, I filled the low tranny first)...
  11. Sep 16, 2016 at 5:28 PM
    #1931
    Bardown
    Bardown Well-Known Member
    Hopefully someone can help me verify if I'm going insane or not. Had my TSB done about 2k miles ago. Difference was night and day. Loved the performance. I recently drove 8 hrs thru the Rocky Mountains to Lake Powell and it performed great (no ECT mode). On the way back I towed 2 jet skis home using ECT/S-Mode. Truck towed great but after removing the trailer and driving in regular mode again it felt pre TSB! Bad and very noticeable/sluggish performance. I reset my ECU via battery disconnnect and it feels back to post TSB (thank god). Could that really have helped that much!? anyone else have TSB symptoms wear off and then fixed again after disconnecting the battery?
  12. Sep 16, 2016 at 5:41 PM
    #1932
    bwonger
    Brian
    Santa Barbara, CA
    supposedly disconnecting the battery erases whatever learning has happened and the TSB was a reprograming of the ECU which would not be reset by disconnecting battery......i think it makes sense.
  13. Sep 16, 2016 at 6:28 PM
    #1933
    Bardown
    Thanks for the response! just took it on another cruise and it seems better again. Maybe something about driving on ECT for an extended time messes with the ECU memory. Hopefully it holds up.
  14. Sep 16, 2016 at 7:42 PM
    #1934
    barney7
    barney7 Well-Known Member
    GOOD LUCK TO ALL OF YOU TOYOTA TACOMA 2016 access cab 4x4 v6 speak for I own one was at dealership today and have a field tech COMMING IN BETWEEN TWO WEEKS TWO MONTHS HAD TBS REVERT BACK TO A DOG SHUDDING AND FLAIR I WILL GET A LAWYER WE NEED A CLASS ACTION SUIT I KNOW THE CULT WILL BE UPSET BUT WE NEED TO DO SOMETHING THE REASON I AM UPSET THE DEALERSHIP ACTS AS I AM THE ONLY ONE IN THE USA WITH THE PROBLEMS
    honey and mcmmotorsports like this.
  15. Sep 16, 2016 at 9:36 PM
    #1935
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    My new2016 with two idles at 500-600 in drive...When i put it to Park, idle jumps up to 900-1000...both with A/C on....could be compressor on/off....who knows....TSB done but lags in 3rd....Really shifts fast from stop to 4th....pain in the ass cause I have to give it gas to get going and then it down shifts
  16. Sep 16, 2016 at 9:57 PM
    #1936
    Tcoma16
    California
    2016 TRD Sport
    Not entirely sure what you're trying to say.... o_O
    surfpops and damnfingers like this.
  17. Sep 17, 2016 at 5:10 AM
    #1937
    barney7
    TRD16 what I am trying to say I am tired of not getting no wear with automatic transmission problems dealer said I will have to wait between two weeks and two months to see a field tech and him or her drive the truck long story short just very unhappy with my truck
  18. Sep 17, 2016 at 9:18 AM
    #1938
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
    Anyone else get a lot of pushback when you asked them to flash your transmission?
  19. Sep 17, 2016 at 4:12 PM
    #1939
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    Mine does the same thing with the AC on, when its at a running temp, the idle will flux between 500-900/1000 when the ac compressor kicks on and puts a "load" on the engine. I had them pull another truck next to mine to see if was doing the same thing... it was. I think its just a "normal" quirk for our truck. if they kept the idle at 900 we would prob only see a slight bump and return to normal when the compressor kicks on but its pretty drastic when its resting at 500.
  20. Sep 17, 2016 at 5:01 PM
    #1940
    mrproduxn
    steve
    Retired DoD SE VA
    Mine always does that with compressor engaged. It sounds strange. All vehicles surge and drop rpms when compressor runs but it is much more obvious in the Taco. I wonder if other model Toyotas have the same quirks with the 3.5. What bothers me is the clickity clack of the injector cleaning process. I thought I had a valve train problem the first few times I heard it.
