2016 TRD auto 6 will not move in Drive or Reverse
Discussion in '3rd Gen. Tacomas (2016+)' started by heyphillip, Nov 12, 2017.
  1. Nov 12, 2017 at 6:24 AM
    heyphillip
    heyphillip [OP] Well-Known Member
    DARRYL
    I've had this truck since new with no problems runs flawless.Well after driving my truck on Friday 11-10-17 all day with no problems parked in the lot at 6:30pm then Saturday morning at 5am start the truck up for work and to my surprise the damn thing will not move when in Drive or Reverse. What the hell.
  2. Nov 12, 2017 at 6:28 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Auto or manual?
  3. Nov 12, 2017 at 6:29 AM
    RangerComa
    RangerComa High Speed Dirt Limo Adventure Rig
    Adam
    Bay Area, CA
    17 DCLB Sport
    list is growing fast
    Rear diff? E-brake? Was it wet on 11/10?Rust on brakes?
    REDNECKTEX likes this.
  4. Nov 12, 2017 at 6:29 AM
    heyphillip
    DARRYL
    6 speed automatic
  5. Nov 12, 2017 at 6:30 AM
    heyphillip
    DARRYL
    It was 23 degrees cold I know that
  6. Nov 12, 2017 at 6:32 AM
    RangerComa
    Adam
    Bay Area, CA
    17 DCLB Sport
    Can you get it in 4hi and get the front wheels to spin?
  7. Nov 12, 2017 at 6:33 AM
    RangerComa
    Adam
    Bay Area, CA
    17 DCLB Sport
    If it was 23 degrees warm, it might make all the difference. Think warm thoughts.
  8. Nov 12, 2017 at 6:35 AM
    RangerComa
    Adam
    Bay Area, CA
    17 DCLB Sport
    Truck was warmed up? Did it feel like the transmission was shifting gears and the engine rpms would rev up, it just wouldn't move?
    Modesto Tacoma likes this.
  9. Nov 12, 2017 at 6:38 AM
    Modesto Tacoma
    central california
    LIMITED 4X4
    Should not matter the temp outside.. Specially in 23 degrees..
    doorsidedown likes this.
  10. Nov 12, 2017 at 6:42 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    That's weird, man. Can you push it in neutral?
  11. Nov 12, 2017 at 6:42 AM
    Modesto Tacoma
    central california
    LIMITED 4X4
    Is it fine now?? And if so what did you have to do to get it to move?? Did you jerk the truck back and forth like if it was stuck or just went into gear?? If it just went into gear and now it's fine I'd try in the morning and also take to the dealership. Probs will have to leave it overnight.. One suggestion is if you leave it overnight tell the advisor that you want to be there to try and duplicate it with the tech.
  12. Nov 12, 2017 at 6:45 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2017 MGM Sport DCSB V6 Manual
    Inquiring minds what to know, don't keep us hanging OP. :annoyed:
    Modesto Tacoma and Thunder Fist like this.
  13. Nov 12, 2017 at 7:04 AM
    heyphillip
    DARRYL
    No it wasn' warmed up I got right in it started it and tried to move it to my front door of my apartment
  14. Nov 12, 2017 at 7:06 AM
    heyphillip
    DARRYL
    I won' be able to get to it until Monday morning I work from 7am to 11pm Saturday and 7am to 11pm Sunday
    Spare Parts likes this.
  15. Nov 12, 2017 at 7:07 AM
    RangerComa
    Adam
    Bay Area, CA
    17 DCLB Sport
    Sorry op. That sucks man. Hopefully it's nothing serious.
  16. Nov 12, 2017 at 7:12 AM
    heyphillip
    DARRYL
    It only has 9000 miles on it still under warrenty.Someone on facebook told me my trans fluid could be low because a few 16 came from the factory low.The problem is you can' check the level because it' seal.Who in the hell designed that thinking
  17. Nov 12, 2017 at 7:14 AM
    Spare Parts
    Southern Maine
    Ohhh, good luck, sounds odd and hope to see the outcome. Oh did you check to see if you were on blocks? :boink:
  18. Nov 12, 2017 at 7:16 AM
    Spare Parts
    Southern Maine
    Not low enough to stop it from moving.
  19. Nov 12, 2017 at 7:17 AM
    Modesto Tacoma
    central california
    LIMITED 4X4
    That's not right.. When you take it to the dealership keep us updated on it.. I would like to know what they find.
  20. Nov 12, 2017 at 7:19 AM
    heyphillip
    DARRYL
    No blocks I'm just wondering if the 23 degrees cold weather had anything to do with it plus me getting in starting it right up and trying to take off
