2016 TRD Off-Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThatguyJZ, Jan 12, 2015.
  1. Jan 14, 2015 at 12:36 PM
    #301
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Very Interesting! I like the multi terrain select like the 4runner trail. Now if they could get the ride height to raise when in Low Range I might not do any mods to it! Naw that's crazy
  2. Jan 14, 2015 at 1:47 PM
    #302
    CdnTacoma
    CdnTacoma Well-Known Member
    Calgary, Alberta
    2017 DCLB TRD Sport 4X4
    Haha, oops, I just realized it was at Toyota's test facility in Arizona, not the Baja.
  3. Jan 14, 2015 at 2:11 PM
    #303
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    One way to tell where you are: The cardón cactus in Baja are much larger, taller, have more branches than Arizona's sahuaro cactus.
  4. Jan 14, 2015 at 3:30 PM
    #304
    tasnowma
    tasnowma Well-Known Member
    David
    MA
    06’ DCSB SPORT. 16’ DCLB SPORT. 14’ DCLB SPORT
    Premium tech package with JBL, 2" Rough Country lift, 265/70/17 BFG Rugged Terrains, AVS in-channel rain guards, all weather floor mats, bed mat...
    Alright, I found a pic of the center stack on the Off Road (maybe this has been posted). Looks pretty featured out... digital temp heat, heated seats, wireless charging, etc Inside it looks just like the Limited except for the leather.
  5. Jan 14, 2015 at 3:32 PM
    #305
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No ATRAC button
    Ermahgerd
  6. Jan 14, 2015 at 3:35 PM
    #306
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
    Yep but look at that shifting patter to the left of the stick.
    Those Plus | Minus symbols indicate manual shifting and manual shifting means they could be controlled by electronic paddles via steering wheel . . .
    Hmmm, this is getting good ! ! !
  7. Jan 14, 2015 at 3:40 PM
    #307
    theboy12
    theboy12 The Answer is 42, But What is the Question?
    Jon
    Redding, CA
    2005 Tacoma TRD Sport DCLB
    King 2.5 Remote Resi'sand rear 2.0s, Dakar Pack, TRD 1st Gen air intake, Stealth 6's wraped in DynaPro ATms 285/70R17s, SnugTop, ALL Pro Front bumper, Brute Fab HC Rear Bumper, Hella Black Magic Lights, Bedslide 1000
    That is what I'm thinking about the front bumper as well. The flares are no longer two pieces. You'll have to cut, and under the headlight will be a challenge as well because it wraps upward around that huge nose, I mean grill.
    -Jon
  8. Jan 14, 2015 at 3:45 PM
    #308
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Nope! The ATRAC is incorporated with the "crawl control" feature. It works both going up and down hills. 3162dfbd3b8214bc03d4495cedd0aa85_457f84183dc71839aded93f15f335bf2f4f10374.jpg
  9. Jan 14, 2015 at 3:55 PM
    #309
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Where did you get the idea that ATRAC is incorporated in the crawl control from? That's not what I have read.
    The Toyota guy during the unveiling of the off road truck only said that crawl control regulated the throttle and braking. Also, after checking out a 4Runner forum it doesn't sound like ATRAC is incorporated in it with the 4Runners. I'm not sure that crawl control will turn all four wheels on demand, like ATRAC does, it might only brake each tire individually and regulate the throttle no differently than if you pressed on the gas with your foot.
  10. Jan 14, 2015 at 3:57 PM
    #310
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    I watched the Q&A after the release and they talked about it. The crawl control controls the hill descent and ascent and throttle and braking. It seems like an updated version of the ATRAC basically.
  11. Jan 14, 2015 at 4:00 PM
    #311
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    I also just noticed the 4WD dial differs between the off-road and limited models. 63256b00208bc6d511d6f7d05f40a32d_8cfa8eaef08a7218c6cdcafdb57fc26a3f0f42a6.jpg
  12. Jan 14, 2015 at 4:12 PM
    #312
    Snowbrdr1220
    PA
    No that's not necessary what ATRAC does. When your in 4x4 you're getting power to two wheels, one wheel the front and one wheel on the back opposite side. The way I understand it is with ATRAC if either of those wheels start to spin, then it will use the braking system to move the opposite tire that usually gets no power. It's almost like having a front and rear locker, but with the other two wheels only getting power on demand from the braking system.
    From what I have read in 4Runner forums, their crawl control only controls the throttle the same as when you press on the gas with your foot, and it brakes each tire individually. If that's true then it's not the same as ATRAC and it wouldn't be incorporated, but I can't really say for sure.
  13. Jan 14, 2015 at 4:14 PM
    #313
    OZ-T
    Peter North
    British Columbia
    Newsflash , there is no ATRAC button visible
  14. Jan 14, 2015 at 4:15 PM
    #314
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Oh that may be in but I've heard so many different things. No one can understand ATRAC apparently. Lol. From what I heard in the Q&A though, that's everything crawl control does. So I know it takes place of the old hill descent control from previous models. And from what I understood ATRAC is incorporated with it. I'll find out everything when I go to see it at the show.
    You guys should all list questions you'd like and I'll make a long list of them for the toyota nerds there.
  15. Jan 14, 2015 at 4:16 PM
    #315
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Correct! Haha. Basically what I stated in my last post.
  16. Jan 14, 2015 at 4:20 PM
    #316
    Snowbrdr1220
    PA
    I have ATRAC in my truck and have researched it extensively. I just gave you a pretty clear description of exactly what it does in my last post. Someone please correct me if I'm wrong.
  17. Jan 14, 2015 at 4:21 PM
    #317
    OZ-T
    Peter North
    British Columbia
    Yeah , I said that an hour ago
    If you wanna learn how ATRAC works , pm DavidK , he'll explain it very well
    Then when he's done , tell him the 3rd gen doesn't have it , lol
  18. Jan 14, 2015 at 4:22 PM
    #318
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    I believe you. I don't think you're wrong at all. I'm just passing info from what I heard from the actual tacoma engineer.
  19. Jan 14, 2015 at 4:24 PM
    #319
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Yeah. I realized that not too long after knowing I quoted your post saying that.. Brain fart moment.
  20. Jan 14, 2015 at 4:29 PM
    #320
    Snowbrdr1220
    PA
    Well did this engineer straight out say that "ATRAC is incorporated into the crawl control", or did he say "The crawl control controls the hill descent and ascent and throttle and braking."?
    In your previous post you made it sound like he said the later, and that you made the jump to that it being the same as ATRAC.
