2016 TRD Off-Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThatguyJZ, Jan 12, 2015.
  1. Jan 18, 2015 at 3:11 PM
    #501
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Sorry, didn't see that pic you posted before. With two separate buttons in the 2016, I would think they still operate separately.
    What's the point in two bottoms if not? (On the grand scheme of cost efficiencies)
  2. Jan 18, 2015 at 4:41 PM
    #502
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No worries
    I agree that the MTS and Crawl act seperately , the discussion has mostly revolved around ATRAC as there doesn't seem to be a seperate ATRAC button on the 2016 , so perhaps ATRAC is integrated into one of the other 4LO systems
  3. Jan 19, 2015 at 9:20 AM
    #503
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Has the HP/Torque #'s but posted for the 3.5 V6 yet?
  4. Jan 19, 2015 at 12:19 PM
    #504
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    nope. probably wont be forawhile as its likely still going through epa testing.
  5. Jan 19, 2015 at 1:12 PM
    #505
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Its probably going to be similar to the lexus fleets 350 engine if not the exact same. Hopefully they focus on torque and strength/durability if making changes.
  6. Jan 19, 2015 at 4:08 PM
    #506
    HB Taco
    Curt
    I've driven several different versions of that 3.5. It's a much more refined engine than the 4.0 and sounds waaayy better and rev's higher (I just noticed the redline is at 6k rpm's instead of 5500). It should deliver better MPG especially with the 6AT (maybe premium fuel req). My guess HP will be up close to 300 and torque maybe 275 if were lucky. I'd be happy with 290/280. That would make it quite a bit quicker.
  7. Jan 19, 2015 at 5:29 PM
    #507
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    First concern when describing the smaller motor in a discussion was less torque for more mileage...?
  8. Jan 19, 2015 at 6:26 PM
    #508
    nd4spdbh
    SoCal
    naw, toyota knows what they are doing, this motor is designed for the truck not just a replacement out of a car. Its most definitely got different cam profiles and different cam timings to produce more torque down low. im not worried at all about the smaller displacement.
  9. Jan 19, 2015 at 7:06 PM
    #509
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Good luck seeing over your hood while wheeling... thing looks like a retarded shark from the front.
    At least they FINALLY put projectors in the headlights. They and Nissan waited to be the LAST trucks to incorporate them.
  10. Jan 19, 2015 at 7:12 PM
    #510
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    It is from the same family as the 1GR-FE so my guess is Toyota would reinforce the block and give it different cams.
  11. Jan 21, 2015 at 1:18 PM
    #511
    Bustotaco
    Bustotaco Member
    2014 tacoma dbl cab off road
    None
    It's easy, just don't turn crawl control on. If you leave it alone and don't modify it, you may be able to preserve your resale value.
  12. Jan 24, 2015 at 8:20 AM
    #512
    toddhofford
    toddhofford New Member
    Portland, OR
    2010 Double Cab 4x4
    Anyone know if the Limited version will have TRD Off Road? They say it will be fully loaded? The TRD stickers are not in the Limited pics. Thanks
  13. Jan 24, 2015 at 10:04 AM
    #513
    OICU812
    OICU812 Well-Known Member
    Doubt it. They've said numerous times there will be a SR5, TRD OR, TRD Sport and Limited. Limited and options for it are and have always been on their own. What one can have additionally for options on any of the TRDs is not yet known.
  14. Jan 24, 2015 at 1:36 PM
    #514
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    They will be making a limited version of the TRD Off Road, if that's what you mean.
    The TRD Pro:
    http://www.tacomahq.com/4797/2016-toyota-tacoma-trd-pro-dead/
  15. Jan 25, 2015 at 6:08 AM
    #515
    Quentin
    Quentin Well-Known Member
    Eleanor, WV
    2016 Toyota 4Runner Trail Edition, KDSS
    The 4Runner TRD Pro was based off a Trail Base/Premium (no moonroof, KDSS, but they did have leather). The Tacoma and Tundra were a step beyond the SR5 Off Road upgrade packages (not Limited... No leather). I agree that the Pro is coming back, but they haven't really set a standard of what trim the pro starts with.
  16. Jan 25, 2015 at 7:03 AM
    #516
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    What are the differences between the Offroad, TX Baja, TX Pro and TRD Pro? It's just suspension packages and a sticker right?
  17. Jan 25, 2015 at 10:36 AM
    #517
    nd4spdbh
    SoCal
    They are all based off the TRD off road. ( think elocker and atrac with 4x4)
    Tx pro gets you different rims and cat back
    Tx Baja / pro get you suspension on top of the tx pro.
  18. Jan 30, 2015 at 4:52 PM
    #518
    =JSG=
    =JSG= Well-Known Member
    Canada
    2006 OR to 2021 DC TRD OR 4x4 SB
    Morimoto 2 Stroke 3.0 lows, Squadron-R Sport , Method NVs, Bilstein 6112/5160
    Does anyone know if TRD OR will be available as double cab in Canada?
  19. Jan 30, 2015 at 4:53 PM
    #519
    OZ-T
    Peter North
    British Columbia
    Just Toyota
  20. Jan 31, 2015 at 8:01 AM
    #520
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    I have the push button in my 2014 Corolla. It is great in the car, I thought I would hate it. All the issues people have mentioned so far are avoided. Much better system than I thought.
    I personally do not want it in the truck.
    -cant start the truck in gear on an incline to prevent rolling back after a stall, which is good in some hairy offroad situations.
    -cant jingle the ignition to get a stubborn starter to work.. much more prone to happen offroad
    -in a no start situation there is a lag, and you can't hold the key or turn it again real fast.
    -if you stall it in traffic. its weird to restart with the button. Which is only an issue really in the Corolla because its the most underpowered slow ass car ever. And its so quite you barely notice if it stalls.
