2016 TRD Sport AT water pump failed at 71k miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by freeriderchad108, Nov 19, 2019.
  1. Nov 19, 2019 at 3:34 PM
    freeriderchad108
    freeriderchad108 [OP] Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    Yes. I have had 0 problems with the trans or drive train.
    I checked fluid levels and color (paper towel in the top fill port) on diffs and transfer case every 30k, replaced diffs and transfer fluids at 65k ish miles.
    No discoloration or excessive metal dust/fragments. I didn't want to mess with transmission fluid myself. Not sure what the service interval is on that but I have to be close at the duty cycle I drive at.
  2. Nov 19, 2019 at 5:44 PM
    choose for me
    choose for me Not Sure
    Northwest Florida
    2017 Toyota Tacoma TRDOR
    Flux Capacitor
    Thanks for the info. The best thing about these forums is first-hand experience that can be used by other members. Sucks that this happened to you, but it gives the rest of us a heads up for potential issues, especially for those who tow. Now that these trucks are aging a little bit, we'll start seeing the real issues as opposed to "I expected my $40k+ truck to make waffles for me every morning. Thanks for nothing, Toyota."
  3. Nov 19, 2019 at 6:05 PM
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    If it is anything like an earlier Toyota V6 I worked on, replacing the water pump is not hard but it is a pain in the butt. While it is easier with the radiator removed, there is still a fair amount of time you have to spend on replacing the pump.
  4. Nov 19, 2019 at 6:39 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Isn't the AISIN water pump 50-60 bucks? Too bad you didn't have a second vehicle and had to hit up the dealer.
    What exactly failed on the pump?
  5. Nov 20, 2019 at 3:59 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i cant find the maintenance interveral on the WP just from a search. assuming its around 100k
  6. Nov 20, 2019 at 4:47 PM
    freeriderchad108
    Boston
    They said the front bearing went, it sounded like a jar full of marbles periodically. It had just started dripping so complete failure was imminent.
  7. Nov 20, 2019 at 4:59 PM
    ryan760
    ryan760 Well-Known Member
    71k still seems too low for a water pump, and Aisin makes good ones. Wondering if you just had a one-off bad pump, or it wasn't installed quite right from the factory.
  8. Nov 20, 2019 at 6:17 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
    Like a couple hundred K low... +
    ryan760[QUOTED] likes this.
  9. Nov 20, 2019 at 8:47 PM
    Hooper89
    Bad factory parts happen, including bearings. I had a Ford with a bad wheel bearing at 14k miles...
