2017 4x4 6MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tyler__LaRue, Aug 21, 2021.
  1. Aug 22, 2021 at 8:02 AM
    Shellshock
    Iowa
    I’m pretty sure it flashes when the transponder isn’t present then goes solid when it is
    if the key isn’t communicating with the immobilizer everything will work but the truck will crank endlessly and not start
    Usually that’s not something that just happens unless something changed
    doublethebass and 304_Taco like this.
  2. Aug 22, 2021 at 8:04 AM
    Tyler__LaRue
    Tyler__LaRue [OP] Well-Known Member
    2017 Tacoma TRD Sport 6MT
    Scan tool shows zero codes
  3. Aug 22, 2021 at 8:10 AM
    Tyler__LaRue
    thats what it is doing. Should this throw a code though?
  4. Aug 22, 2021 at 8:42 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I know you said its stock when someone asked for aftermarket alarm . Does it have the factory installed alarm ? If it does, there may be something wrong with it or maybe hopefully not, rodents chewing some wires. Dealer time maybe
  5. Aug 22, 2021 at 8:44 AM
    Tyler__LaRue
    Yes it has the factory Toyota security system.
  6. Aug 22, 2021 at 8:44 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Do you have to press on the clutch for it to start? Just wondering. Its been more than 30 years since I last have a manual
  7. Aug 22, 2021 at 8:48 AM
    Tyler__LaRue
    yes you do. Or you can press the clutch start cancel button and start it without the clutch. I’ve tried both no luck
    shakerhood likes this.
  8. Aug 22, 2021 at 8:50 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Wow. Hope it gets fixed soon. Please update with a fix.
  9. Aug 22, 2021 at 8:50 AM
    Tyler__LaRue
    There doesn’t happen to be a fuel rest button like on the old Ford’s does there ?
  10. Aug 22, 2021 at 8:52 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    have you ruled out battery? Jump in with another car just to make sure, if its a 2017 with original battery i might still be bad or have a bad cell. Just cause the alarm, lights, dash come on, doesn't mean it has the capacity to crank
    shakerhood and bulalo like this.
  11. Aug 22, 2021 at 8:53 AM
    Tacowin1013
    Worse case, its a manual, find a big fucking hill and bump start that mother fucker.
    doublethebass and PopishMetalFab like this.
  12. Aug 22, 2021 at 8:57 AM
    Tyler__LaRue
    I’ve jumped it and it still has the same issue. I thought about trying to bump start it but I’m thinking that’s unlikely it cranks over very strong just won’t fire.
    Bleep100 likes this.
  13. Aug 22, 2021 at 8:58 AM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    If you can hear the fuel pump turn on, then maybe you have a bad crank position sensor. Some 2016 and 2017s had issues with them.
  14. Aug 22, 2021 at 8:58 AM
    Tacowin1013
    Next thing I would do is pull negative battery terminal, let the ECU/ system alarm reset itself. Maybe it got tripped up and locked itself out.
  15. Aug 22, 2021 at 9:00 AM
    #35
    Tacowin1013
    I dont believe the 2017 6mt were part of it, or as least mine wasn't---but still a possibility
  16. Aug 22, 2021 at 9:01 AM
    #36
    Tyler__LaRue
    I left the battery unhooked for about an hour no change. I thought about the crank sensor but thought that would throw a code.
  17. Aug 22, 2021 at 9:02 AM
    #37
    Tacowin1013
    Tried a different key? DO you have a spare?
  18. Aug 22, 2021 at 9:03 AM
    #38
    Tyler__LaRue
    yes I have two keys. Both crank no fire
  19. Aug 22, 2021 at 9:05 AM
    #39
    Tacowin1013
    Cranking with no fire sounds to me like a fuel delivery issue then.
  20. Aug 22, 2021 at 9:26 AM
    #40
    Tyler__LaRue
    Would I have a code for the bad crank sensor? Or since it won’t even start and I can only scan it in the run position would there be no code ?
