2017 Fall Camp & Ride Picture/Video Thread...
Discussion in 'Florida' started by Taco No Baka, Oct 18, 2017.
  1. Nov 9, 2017 at 11:32 AM
    #61
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    you learn something new everyday now don't ya! Now how many diffs do we have?
  2. Nov 9, 2017 at 11:33 AM
    #62
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    3 :D its plural Diffs
    Taco No Baka[OP] and 5 Lug Fury like this.
  3. Nov 9, 2017 at 11:39 AM
    #63
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :facepalm:
    Edit: go grab me a mountain dew!
  4. Nov 9, 2017 at 11:41 AM
    #64
    TacoTRD78
    Stuart,fl
    @Rattletrap66 Hey man I read that after AOP your traction control light wont go off? You get it fixed man
  5. Nov 9, 2017 at 11:44 AM
    #65
    TacoTRD78
    Stuart,fl
  6. Nov 9, 2017 at 11:45 AM
    #66
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Actual @TacoTRD78 was right. He didn't say I had multiple diffs but he was describing that I have that certain type and was referring to the type as a multiple.
    :violent:
    TacoTRD78 likes this.
  7. Nov 9, 2017 at 12:03 PM
    #67
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    nothing yet, happened before but forgot how I fixed it lol
    wut
  8. Nov 9, 2017 at 12:06 PM
    #68
    5 Lug Fury
    Kenny
    Knoxville, TN
    Nevermind I'm bored at work :ballchain:
  9. Nov 9, 2017 at 12:15 PM
    #69
    TacoTRD78
    Stuart,fl
    Did you try and reset it ?
  10. Nov 9, 2017 at 12:51 PM
    #70
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    nope
  11. Nov 9, 2017 at 1:02 PM
    #71
    TacoTRD78
    Stuart,fl
    Could be a fuse or a bad sensor or alignment can sometimes cause it to not turn off. There is away to reset It. If I find the thread Ill post up the link
    Rattletrap66[QUOTED] likes this.
  12. Nov 9, 2017 at 1:03 PM
    #72
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    ok cool, thanks man. just cleaned all the mud off yesterday and still need to thoroughly wash it. then i'll fiddle with it
    TacoTRD78[QUOTED] likes this.
  13. Nov 9, 2017 at 1:37 PM
    #73
    TacoTRD78
    Stuart,fl
  14. Nov 9, 2017 at 4:42 PM
    #74
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    The OGT technically only has one diff even though it's 4WD. Natty has 3. 4WD 3rd Gen Tacomas have 3 as well, I think. :D
