2017 Low Automatic Transmission Fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2lazy2, Mar 2, 2018.
  1. Mar 11, 2018 at 3:44 PM
    #61
    99Mike
    99Mike Well-Known Member
    Fayetteville, NC
    2018 SR5 DCSB
    "Clunk' or harsh downshift. I think mine does the same thing. I think it is fairly common. That is why I am checking my fluid level. That and peace of mind.
  2. Mar 11, 2018 at 3:59 PM
    #62
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    I am starting to think it the way they designed the transmission. My fluid is full and still does it when cold. I only have 600 miles on it so I am giving the 2k miles it takes to learn my habits to see what changes.
  3. Mar 11, 2018 at 4:01 PM
    #63
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    I hear you... Me too, taking my truck to get the transmission fluid levels checked on Tuesday, and hope the dealer do it right...
    Cheers.. :cheers:
  4. Mar 11, 2018 at 4:40 PM
    #64
    99Mike
    Fayetteville, NC
    2018 SR5 DCSB
    Check back with with the results.
  5. Mar 11, 2018 at 4:42 PM
    #65
    El Latigo
    Anaheim CA
    Sure will..
  6. Mar 11, 2018 at 4:43 PM
    #66
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    If the clunk you’re hearing is there when harsh axle changes occur, check the u-joint on the axle as it may need grease, or be failing. Get low on the side of the truck, looking at the differential and have some one start, put in forward gear (brakes on), neutral, reverse(brakes on) and listen and look for the clunk.
    Auto-Transmissions are fluid and should not clunk. There are valves that open/close, which can cause abrupt sensations, but shouldn’t be clunks.
  7. Mar 11, 2018 at 4:43 PM
    #67
    El Latigo
    Anaheim CA
    Very possible.. But who knows?
  8. Mar 12, 2018 at 12:55 PM
    #68
    eg605
    eg605 New Member
    I can assure you I didn't drain the transmission fluid. Toyota is giving me an 8 yr 125k extended warranty. I am just afraid if my transmission does fail they will make up an excuse to not cover it.
  9. Mar 17, 2018 at 8:08 AM
    #69
    99Mike
    Fayetteville, NC
    2018 SR5 DCSB
    Checked my fluid this morning per the procedures in post #18. I first put a quart in and pinned the cooler bypass. I drained out about a quart. Fluid level was fine. Thanks to Splitbolt for the procedures and gearcruncher for the advice.
  10. Mar 17, 2018 at 4:37 PM
    #70
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Now you know it's right.....
    That was worth the effort wasn't it..? :thumbsup:
    gearcruncher likes this.
  11. Mar 17, 2018 at 4:50 PM
    #71
    99Mike
    Fayetteville, NC
    2018 SR5 DCSB
    Gave me peace of mind!
  12. Mar 17, 2018 at 6:40 PM
    #72
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    thats what they do....add but dont tell you and make no notifications on the paperwork....bastards
    over60 likes this.
  13. Mar 17, 2018 at 6:42 PM
    #73
    petr321
    Petr
    San Diego
    2018 DCSB OR
    why would they, its only opning a can of worms if they tell u. this way they just say nope everything was good here,
  14. Mar 17, 2018 at 6:45 PM
    #74
    r1200gs4ok
    O. K.
    Irvine, Ca
    dont let them use the tech stream....make them do it manually
    El Latigo[QUOTED] likes this.
  15. Mar 17, 2018 at 7:12 PM
    #75
    gearcruncher
    Canadain bumper technician
    In for the results . I would like to hear from other 2018 owners .
    Let us know if the 18,s are filled to spec or low on fluid
    In post 18 , Mr. Splitbolt provided the instructions . Its not hard to check your own fluid .
    Do I change the Low fluid poll and add the 2018 Tacoma,s to the list ?
    There are now 2 members with 2018 Tacomas who have had low fluid .
    Need to hear from other members who own the 18 Taco .
    In a small community such as Tacoma World , I beleive 10 trucks low on fluid will be enough of a deciding factor ( baseline ) to comfortably add the 18 to the low fluid poll .
    https://www.tacomaworld.com/threads...be-low-on-fluid-directly-from-factory.405642/
  16. Mar 17, 2018 at 7:16 PM
    #76
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    If I don't want to go through the hassle of pinning the obd port and putting the truck into temp check mode - couldn't I just pin the thermostat and monitor the pan temp on the fusion app until it reaches 95*F and check it at the point?
  17. Mar 17, 2018 at 7:25 PM
    #77
    gearcruncher
    This is why we tried to get you guys to watch the technician perfoming the level check .
    If you read the low fluid poll , there are some good posts about dealership techs saying one thing , yet doing another hint hint .
    Painting the overflow bolt was an excellent idea !!
    You can always slide under the truck and have a peek to see if the paint is ripped up . At least you will know for certain the manual fluid level check was done somewhat properly .
  18. Mar 17, 2018 at 7:31 PM
    #78
    gearcruncher
    [QUOT
    E="SearArtist, post: 17401915, member: 174151"]If I don't want to go through the hassle of pinning the obd port and putting the truck into temp check mode - couldn't I just pin the thermostat and monitor the pan temp on the fusion app until it reaches 95*F and check it at the point?[/QUOTE]
    Sure !!
    There is no reason why you couldnt do the fluid level check this way . Its going to get you very similar results as doing the full procedure .
    If you do find the trans low , dont add fluid ...Off to the dealer you go for proper warranty documentation of the issue
  19. Mar 17, 2018 at 7:37 PM
    #79
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    The last time I wanted them to check it, they said they don't do checks unless there is a failure in some way. Instead, they applied the first tsb.
    It have 42k on it now, and it's never really given me problems, but if it IS low then I would like to at least top it off.
  20. Mar 17, 2018 at 10:18 PM
    #80
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    I followed Mr Splitbolt’s instructions at 92miles on my 2018. It was filled to spec.
