2017 SR - Suspension - How to get softer ride??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ExpertReader, Jul 7, 2024.
  1. Jul 7, 2024 at 3:16 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    First,
    Check your bump stops for signs they are getting "over used" .
    If you are bottoming out, that needs fixing with springs.
    IF the springs you have are physically OK, not putting you on the bump stops, but harsh, Buy 300# of bagged sand and put it against the front of the bed. (That's only 6 50# bags and about 25 bucks in my area)
    Evaluate your ride quality with the extra weight.
    Most shocks have very little compression damping for the initial inches.
    The rebound damping follows the spring rate.
    Oh! If your bump stops are gone altogether due to age and use, get some replacements before throwing too much money around.
  2. Jul 7, 2024 at 4:43 PM
    ExpertReader
    ExpertReader [OP] Active Member
    2017 Tacoma SR Access Cab
    F that lol!!!
    cropduster78 likes this.
  3. Jul 7, 2024 at 6:44 PM
    VTCAL
    2021 Sport
  4. Jul 7, 2024 at 7:31 PM
    VTCAL
    2021 Sport
  5. Jul 8, 2024 at 3:13 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Ditto
  6. Jul 8, 2024 at 5:03 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I can confirm that my '17 SR suspension is the same as you describe, since purchasing it new back in 2018. The upside is that it takes corners like a Honda Civic. lol
    I now have 20K on the ODO and it's only slightly more forgiving. I think Fox TRD Pro takeoffs would be perfect on this truck.
  7. Jul 8, 2024 at 7:28 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Two people have already asked about tires. What are the tires.. SL, C, E load rating? It makes a big difference especially when empty/unloaded.
    Chew likes this.
  8. Aug 8, 2024 at 4:35 PM
    ExpertReader
    Thank you. I’m in Atlanta GA. If they would soften this harsh ride I’d be happy to pay for boxing and shipping but I know that’s a lot of trouble so no worries.
  9. Aug 8, 2024 at 4:38 PM
    ExpertReader
    is that for front and rear? I’m really clueless about what I need. My brother suggested air shocks and I see some for $300 on Amazon and then I hear they can cost $3000. Then I hear coil overs will work but maybe not as soft as air. It’s really frustrating and confusing
    NoOne[QUOTED] likes this.
  10. Aug 8, 2024 at 4:43 PM
    ExpertReader
    I
    I haven’t regularly been in a truck since my dad’s Ford Ranger on the cattle ranch from 1976-1981. And I didn’t pay attention bcz we worked from sun up to sun down. Too tired to pay attention lol.
    NoOne likes this.
  11. Aug 8, 2024 at 4:51 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    There’s 3 factory types (well, 4 = PRO)… 1) SR/SR5 2) TRD Sport 3) TRD Offroad.
    You’d be changing yours out for the other, essentially modifying the ride/handling in the most economically efficient manner. Plenty to read around here and plenty of YouTube videos too!
    Chew likes this.
  12. Aug 8, 2024 at 6:00 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Just ad Bilstein 5100s up front, set 1" higher than stock. Truck will look lifted, level and you will lose the oem brake dive.
    Just the shocks, as Bilstein recommends you keep the oem springs....
  13. Aug 8, 2024 at 6:30 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Exactly what I did on my SR. The ride was way better. Didn’t cost much either…
    Tocamo[QUOTED] likes this.
  14. Aug 8, 2024 at 6:47 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I’m afraid to touch my shocks/suspension on my limited because it rides so nice. Maybe look for a take off set from a limited model?
    That said, the 4600/5100 Bilsteins are hard to beat. When it comes time for shocks it’s going to be a hard decision.
  15. Aug 8, 2024 at 6:58 PM
    #35
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Tires will make the biggest difference. Heavy LT rated tires ride anywhere from bad to terrible on these trucks, and they aren't necessary for most people. Stock size and rating tires at the factory recommended pressure should give you a decent ride. The lighter the tire the better, because the shocks have to do less work.
  16. Aug 8, 2024 at 7:00 PM
    #36
    Gen3TacomaOBX
    S
    From what I've heard the SR/SR5/Limited all share the same shocks.
    Something for the OP to consider.. is that double cab v6 4x4 will ride very differently than an access cab I4 2wd with the same exact shocks due to the weight differences of each.
    MannyS likes this.
  17. Aug 8, 2024 at 8:18 PM
    #37
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    limited, sr, sr5 run same shocks
  18. Aug 8, 2024 at 8:28 PM
    #38
    M85
    Colorado
    2019 SR ACLB
    Archive Garage hammer hangers are supposed to improve the ride. I'm skeptical that it's as significant as they claim, but it's worth a try. I haven't installed mine yet.
  19. Aug 9, 2024 at 5:46 PM
    #39
    ExpertReader
    Which way
    Which way is the best cost/benefit if I want to spend the minimum???
  20. Aug 9, 2024 at 5:50 PM
    #40
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Maybe you just need to do some test drives instead of asking a forum to pick a vehicle for you !
