2017 Taco Battery Always Dead
Discussion in 'New Members' started by Enzymus, Sep 19, 2019.
  1. Sep 19, 2019 at 11:47 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Alternator doesn't kick in until 35mph? Can anyone else verify? On the 2nd gens as well as every other car or machine I've worked on the alternator outputs 13.5-14.8V as soon as that fucker starts up.
    Taco critter likes this.
  2. Sep 19, 2019 at 11:48 AM
    PyroTaco
    PyroTaco Well-Known Member
    2013 Reg Cab Tacoma
    Fat Bob's lift kit, 30's on stock steelies, lunchbox locker in the rear, and a ton of other general mods and additions to help the utility of the truck for my particular uses.
    I have a 2nd gen and was seeing the same thing. Noticed once I put a meter in the truck that the power from the alternator just isn't enough. Alternator tested fine though. So I went to singer alternators.com and got a mod harness and now it sees over 14v all the time and charges the battery much faster.
    -PYROTACO
  3. Sep 19, 2019 at 11:49 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yea, I didnt want to complicate shit in this thread.. But that sounds like BS to me. I know the regulator circuit is slightly different in the 3rd gens from the 2nd gens, but as soon as that thing spins it should be pushing electrons
  4. Sep 19, 2019 at 11:50 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Sep 19, 2019 at 11:51 AM
    81shark
    81shark Well-Known Member
    huh... my factory battery out lasted my frame. nearly 10 years....
    toyota replacement will be 4 years in a couple of months.
  6. Sep 19, 2019 at 11:53 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    I think the dealer is trying somethings, OEM batteries suck. But not that bad. i would get a second diagnosis, but that does cost money. I think the 35mph thing is crap, unless someone can provide some proof. if a prius can charge the battery at low speed, why doesnt a taco?
  7. Sep 19, 2019 at 11:54 AM
    PyroTaco
    2013 Reg Cab Tacoma
    Should be operating from startup. My guess is low output from the alternator restricted by the computer. The wire I got overrides that issue.
  8. Sep 19, 2019 at 11:55 AM
    Enzymus
    Enzymus [OP] New Member
    2017 White Tacoma
    6" Fox Lift with 35x12.5 Nitto Ridge Grapplers
    According to both Right Toyota and Camelback Toyota, the 3rd gen alternators don't kick in until about 45 mph to save gas. Sounds like a great future for commuters but b******* for City drivers.
  9. Sep 19, 2019 at 11:56 AM
    Enzymus
    2017 White Tacoma
    Tell me more about overriding the alternator limitations.
  10. Sep 19, 2019 at 11:56 AM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Save gas? Batteries are like 150 bucks! Fuck that.
  11. Sep 19, 2019 at 11:59 AM
    Enzymus
    2017 White Tacoma
    Well I guess not running the alternator at low speed does reduce the use of gas, but makes this truck a POS for my driving situation.
  12. Sep 19, 2019 at 12:00 PM
    Enzymus
    2017 White Tacoma
    Isn't a 2017 a 3rd gen? Just asking...
  13. Sep 19, 2019 at 12:02 PM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    I still don't think thats right. Does the alternator have a clutch on the pulley? Its true that an alternator puts out more voltage at higher rpm, but you should be getting like 13.2 or more at idle. Enough to maintain the battery and run accessories.
  14. Sep 19, 2019 at 12:04 PM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Yes 2017 is a 3rd, but I was saying on every other vehical I know of the alternator outputs more than battery voltage as soon as the engine fires up. Its a direct belt driven pully straight off the crank pulley. As far as I know theres no clutch on that pulley to disconnect it from the engine and also that would be a dumb design. Have you checked your belt tensioner?
  15. Sep 19, 2019 at 12:10 PM
    #35
    su.b.rat
    su.b.rat broken truck
    cool. that's rare y'know.
  16. Sep 19, 2019 at 12:13 PM
    #36
    CouchlessPotato
    Zach
    2.5" lift w/35's
    The pulley on the alternator itself could also be loose. Or the alternator is bad. Or a bad ground somewhere between the alternator and the battery. Your battery sould be being charged when the truck is running. 10 miles a day is not enough to charge the battery completley, but it should still last maybe 2 years at least if you aren't running the radio with the engine off all the time.
  17. Sep 19, 2019 at 12:14 PM
    #37
    BillsSR5
    bill
    2014 SR5
    it probably has to do with the start/stop system
  18. Sep 19, 2019 at 12:21 PM
    #38
    Enzymus
    2017 White Tacoma
    How do I turn these alternator limitations off? I'd like something to override, the alternator and also maybe override that mushy gas pedal.
  19. Sep 19, 2019 at 12:25 PM
    #39
    Enzymus
    2017 White Tacoma
    While I'm not the least bit handy as a mechanic, I have had 3 dealerships inspect the vehicle and told me its working as designed. 2 of the dealerships simply told me the alternator is working just fine while engaged.
  20. Sep 19, 2019 at 12:29 PM
    #40
    CouchlessPotato
    Zach
    2.5" lift w/35's
    With the radio disconnected is the truck working without having to jump it?
