2017 Tacoma, 53000km Engine Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Buck176, Feb 25, 2021.
  1. Feb 25, 2021 at 12:56 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yeah there is the odd troll for sure..
    One thing about TW though, there are more than a few members who get prickly when they see negative threads about the 3rd gen. Some will jump right to the conclusion that you must be a troll, especially if you have a low post count. Now, there was a time on here when that did happen quite a bit, so there is something behind that attitude.
    There is also a posse of.. super fans, for lack of a better term, who will attack and call you down for complaining. I've never understood why they can't simply resist the urge to click on a thread that ruffles their feathers in some way:notsure:
    Anyway, I'm definitely interested in the outcome of your story. The more you know...
    doublethebass and Bushed like this.
  2. Feb 25, 2021 at 1:02 PM
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    Benny at it again. Seems like a cool guy to know
    doublethebass likes this.
  3. Feb 25, 2021 at 1:11 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Subbed for the final outcome, good luck.
    Buck176[OP] likes this.
  4. Feb 25, 2021 at 1:28 PM
    eggs
    eggs Well-Known Member
    Beersconsin
    2017 TRD O/R
    yes this happened to mine, 2017 also, cylinder #1, at 35,000 miles. Has 68,000 now and no issues.
    Buck176[OP] and Bushed like this.
  5. Feb 25, 2021 at 2:13 PM
    Buck176
    Buck176 [OP] Member
    2017 Silver SR5
    Hahaha by no means am I trying to bash the tacoma as a whole, im obviously here and a little frustrated bc I do LOVE my truck. I have seen some of the posts you are referring too just slamming the 3rd gen, aside from this issue I've had no other complaints.
    Thanks for responding, gives me some peace of mind my baby might be ok! Lol. If I can have her back on the road with a warranty extension as well, id be a happy customer.
    eggs[QUOTED] likes this.
  6. Feb 25, 2021 at 2:35 PM
    Jthughes
    Jthughes Well-Known Member
    2018 cement off-road Tacoma
    Do you happen to know what code is was blowing? Here's what happened to me....
    "I have had it since feb 2018 and last month (feb 2020) got a check engine light at 35,000 miles (P11EE00) they sent off my cylinder head and they recommended a new one(under warranty) and they also replaced oil pan and timing cover for some reason. got my truck back and now there is a strange sound coming from my dash that sounds like a vacuum leak or screech when I get to 3,500 - 4,000 rpms going 40-50mpg so ill have to take it back."
    anyway they still haven't figured out my weird sounds that only happens at high rpms but they are going to look into when i bring it on for my new fuel pump (recall)
  7. Feb 25, 2021 at 2:38 PM
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    It is not uncommon for assembly line engines to have an inherent defect. Manufacturers may test engines for 100's of thousands, if not millions of miles during R&D but that is still a very small sample when compared to how many units exist when an engine goes into mass production. Probably 98% of all 3.5 Tacomas will never have the issue but some folks will win the unpleasant lottery of a major engine repair. The engine plant in AL built 3 million engines in 2 years (they build 4, 6 & 8 cylinder engines so not all of them are 3.5's)....and that was 2014 so that plant has kicked-out at least 10 million engines by now. If 99.9% of them never have an issue, that still leaves 10,000 engines that could have an inherent defect.
    RustyGreen and Buck176[OP] like this.
  8. Feb 25, 2021 at 2:52 PM
    Buck176
    Buck176 [OP] Member
    2017 Silver SR5
    Couldn't tell you the actual code number, they said it was showing misfire in cylinder 3, then the next day showed misfire codes on various cylinders, tried spark plugs didn't rectify the issue, then got into taking the engine apart. That noise sounds like a headache and a half I hope they are able to straighten that out for you man.
    Yep, can't say this is a lottery I've dreamt of winning hahaha. Crap luck but glad that Toyota is standing by their product here, at the end of the day having the engine rebuilt by toyota under warranty and them extending that power train warranty is great service you probably wouldn't get with other brands.
  9. Feb 25, 2021 at 2:53 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I kind of expect more of them to start dropping like flies, I don't think in the big scheme of things the 3.5 is going to have the legacy of the 3.4 or the 4.0. A message board is not a real world sample.
    Hooper89 likes this.
  10. Feb 25, 2021 at 3:03 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    More than that. One guy had his fail at 60,200 miles or something (Warranty Timer lol). It seems to be a sudden failure as well.
  11. Feb 25, 2021 at 3:09 PM
    Buck176
    Buck176 [OP] Member
    2017 Silver SR5
    As much as im obviously hoping that's not the case, its true those earlier motors are just so reliable and proven, gotta go messing with things in the interest of fuel economy. The 3.5 in the 3rd gens has been around for a significant amount of time as well, just new to the tacoma. Time will tell.
  12. Feb 25, 2021 at 3:59 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    It usually works well with TOYOTA, others maybe not so much. I know.
    Buck176[QUOTED][OP] likes this.
  13. Feb 25, 2021 at 4:11 PM
    Buck176
    Buck176 [OP] Member
    2017 Silver SR5
    The hammer[QUOTED] likes this.
  14. Feb 25, 2021 at 4:21 PM
    tcjacado
    tcjacado Well-Known Member
    There have been several engine failures, mainly in valve 5 and 6, towards the back of the motor.
    I believe there is a dedicated warning thread on this topic. A lot of trucks have been produced, and mostly by machines/robots. These things Apparently need calibrated and checked more often.
  15. Feb 25, 2021 at 5:20 PM
    #35
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    WI
    2021 TRD OR Premium 6MT
    I bought another Tacoma (one pre-taco, 2 first gen’s, and a second gen previous) because of Toyota’s reliability, but also because the have a strong track record of going above and beyond what is reasonable to keep their customers happy. They had problems with the old 3.0 v6’s and totally stood behind them. Same with the frame rust issues. No mechanical thing is perfect, Toyota seems to get that.
  16. Feb 25, 2021 at 5:20 PM
    #36
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    Right on! Thanks for the info. Out of curiosity, a bit of trivia to feed my own mind, are cylinders 1, 3, 5 vehicle left? And 2, 4, 6 vehicle right?
  17. Feb 25, 2021 at 5:26 PM
    #37
    The hammer
    No we don't know, IDK, just not worrying till I see a 1k here.
    Moreover, I see production changes by all manufacturers across the board without failure being a reason all the time. Sometimes its to improve the product, sometimes to save money and every now and then to do both.
    Ironically, when there is a failure change it takes more time. It could be because it has to be thoroughly investigated. Like the infamous CPS sensor as an example.
    And no I don’t have a clue as to what the sample rate is on this sight to the real world, but I do know that the real world only seeks answers in a forum when an issue presents itself so 10X is probably a safe bet. But to answer your inquiry no IDK or claim to know, but I’ll start to worry when I see a 1k fatally wounded tacos.
  18. Feb 25, 2021 at 5:43 PM
    #38
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Let them do the work and trade that sucker while the values are sky high.....
    MOC221_ and Hooper89 like this.
  19. Feb 26, 2021 at 4:25 AM
    #39
    Greentruck843
    Greentruck843 New Member
    I had a 2017 have a cam holster failure at 19k miles. Apparently the seals went bad and they had to almost completely rebuild the motor. Then I had to return it due to the new parts having a "bad cast". Oil was leaking thru pores in the aluminum. Haha I think we just have bad luck. However they did extend my warranty with platinum coverage no questions asked, so I'm sure you'll be compensated for your inconvenience.
  20. Feb 26, 2021 at 5:38 AM
    #40
    gmtech
    gmtech Well-Known Member
    Iowa on the Mississippi
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    could be worse. could have 2014-2019 Silverado with stuck lifters/bent push rod.... we have at least one in for this concern every 2-3 weeks if not more.. and this is just at my dealership. me and the tech next to me are collecting the bent push rods.. we call it bent dick syndrome! got 7 over last 3 months and those are just ones that were not warranty and needed returned
