2017 Tacoma a little disappointed, need help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rodltg2, Jul 11, 2017.
  1. Jul 14, 2017 at 4:49 PM
    #41
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    Stop throwing good money after bad.
    Those trucks are geared terribly. Your best bet will be to use the ECT and S mode.
    carlosg likes this.
  2. Jul 14, 2017 at 11:07 PM
    #42
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    You're fucked because you came from a duramax. That truck has power and was made to tow.
    Your second mistake was buying the dealer preinstalled garbage lift.
    I know I'm being blunt but I had to.
    I came from a duramax as well but I've owned 4 Tacoma's including the one I have now so I knew what to expect.
    92PathSE and tcjacado like this.
  3. Jul 14, 2017 at 11:14 PM
    #43
    drewstaco
    drewstaco Member
    paul - good input. where do you typically shift (without revving the crap out of it) above 3k rpm? i usually shift right around 3k currently.
    Paul123[QUOTED] likes this.
  4. Jul 14, 2017 at 11:49 PM
    #44
    tcjacado
    tcjacado Well-Known Member
  5. Jul 15, 2017 at 5:40 AM
    #45
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Less weight than you, and I'm also in an MT, but I have no problems towing. FWIW, I see over 1000' elevation change on my trips too. Tows about how a 3.5 should. Also tows comparably to my 2011 4.0. Deff doesn't tow like my 3500hd with a 1ton welder, fuel cell and loaded rack body. But it's all about intended use with these trucks
    Good luck with figuring the tires and spacers out. I'm sure switching them out will make you happier with your ride.
    98tacoma27 likes this.
  6. Jul 15, 2017 at 7:52 AM
    #46
    esses
    esses Well-Known Member
    2017 TRD Sport Double Cab, Long Bed, 4WD
    Toddler Car Seat and some cardboard boxes in the bed.
    In addition to what's been said, Larger wheels are also going rob you of acceleration. The bigger the deviation from stock the more the loss.
    That could well be what you're feeling as less power. Drive someone's on stock wheels and see if that makes a difference for you.
  7. Jul 15, 2017 at 7:57 AM
    #47
    TejasTaco
    TejasTaco Grab a taco
    This is probably easily fixed with different tires, alignment, and balance. Did you ever state what the tires and load rating are?
  8. Jul 15, 2017 at 8:09 AM
    #48
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Welcome OP, and congrats on your truck, it looks great!
    Not much I can add here, everyone's already nailed everything that needs to be said to solve your problem, all I can do is reiterate the part that said go back to stock, or re-gear to 4.88 and lose at the top end, but the low end will be better.
    And trading to a Tundra won't be so bad in mpg because with all the mods you did, it dropped your mpg into the Tundra range, provided you don't do the same to it and you may not need to.
    Best of luck!
    Cheers!
    speedtre likes this.
  9. Jul 15, 2017 at 10:19 AM
    #49
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    As mentioned, your ride issues a likely related to tire pressures, poor lift install, poor alignment, or a trashtastic lift kit.
    Power is likely being robbed by the heavier tires, but these engines are a bit rev happy and don't make power till above 3,000 rpm. Luckily they run way better at high rpms when compared to the 4.0. The other big thing is that apparently, the throttle plate doesn't really open up like it was attached to the cable. It's really dialed back.
    The Orange Virus guys are alpha testing tunes for right now. IMO, it sounds to me like they know what they are doing, and the results are sounding quite promising, but installing the tune is at your own risk. I'm really optimistic that it will really change the driving experience with the truck. I honestly, think the truck makes plenty of power, but the throttle response is weak and the low speed power is weak.... both could be explained and fixed by a tune. Stomp on the gas in stock form and this truck scoots good enough for me.
  10. Jul 15, 2017 at 11:50 AM
    #50
    Clearwater Bill
    Billy
    Largo Florida
    1) That's good. You won't feel as bad replacing it when you're ready for a comfy ride. (Isn't 35k on the high side for an SR?)
    2) Let us know what those are. There are a couple of things that might improve drivability, but making net new HP/torque is another matter altogether.
    Hint: there are no 'chips' and the magical CAIs? Well, they aren't. Magical that is.
    And yea, living on a lake is nice. I enjoy mine. Doesn't make the truck tow any better though. :D
  11. Jul 15, 2017 at 12:18 PM
    #51
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    More power then supercharge it. Although I'm not sure if they have one for the 3.5
  12. Jul 15, 2017 at 12:39 PM
    #52
    TejasTaco
    That Mastercraft load is slightly heavier.
  13. Jul 15, 2017 at 12:40 PM
    #53
    m603holden
    Marteeen
    New England
    ^yessah. First thing I said.
  14. Jul 15, 2017 at 12:45 PM
    #54
    Clearwater Bill
    Billy
    Largo Florida
    At least for now. Maybe forever.
  15. Jul 15, 2017 at 12:53 PM
    #55
    m603holden
    Marteeen
    New England
    And it be more gas efficient too, because you know, atkinson and stuff. Haha
    Good refference.
  16. Jul 15, 2017 at 2:31 PM
    #56
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    Why do people ask such a stupid f---ing question? I've seen it 100+ times on here. Did you marry your wife after talking to her for 15 minutes. Tests drives are BS. It's a sales tool. I've never bought a vehicle based on the test drive. And i was extremely disappointed with my test drive but knew I wanted the truck anyway because I could probably fix most of the disappointing things myself. If you can't add something constructive, you shouldn't comment.
    speedtre and Bigfsur like this.
  17. Jul 15, 2017 at 2:43 PM
    #57
    FrankJake
    Southern California
    Exactly what I'm doing. And I'm not saying anything bad about the OV Tune but I want to wait and see what several buyers have to say, not just the few who have said "it's made a difference" or "it drives like it should have". It's driving like it was designed to, and that's not very good as most of us believe. But for the money I need to feel a big difference, not drive around for an hour trying to see if I can notice a difference. Again nothing bad about OV guys, I'm sure they have works their butts off figuring this out. I'm just not sure it's enough to justify the price. And the whole possible warranty issues that might be an issuer down the road.
    smitty99[QUOTED] likes this.
  18. Jul 15, 2017 at 3:06 PM
    #58
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    If you were wondering what my comment was about, re-read the OP. If you failed to understand it the first time, let me help you.
    Assuming he test drove the truck, items below should've been identified during the test drive. Shouldn't be a surprise weeks/months later down the road.
    Why buy a dealer lifted truck when you know it's crap parts that cost 4x the value. He wanted a truck that looks good (which it does) but now the ride sucks. So, did he test drive it?
    Your comparison with your wife is stupid. That's on you if you married her after talking to her for 15 minutes.
    You still bought the truck after being disappointed with the test drive. Now, as a fix, you're looking into getting a tune. Good for you if you can fix the things that disappoint you.
    I would rather mod my truck than fix.
    PS: The 3rd gen forum makes everyone bitter.
    melikeymy beer likes this.
  19. Jul 15, 2017 at 5:56 PM
    #59
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    I'm curious about why the OP felt he needed a lifted truck with 33s. I don't get the rush to lift these trucks, not unless someone plans to do a lot of off-roading, and I would venture to guess that about the most off-roading most of these trucks ever see is a gravel/dirt road. If all someone is looking for is cosmetics, I'd say that they are going to pay a price, and more than just the cost of the lift.
    On the subject of power, mine is a v6 AT, and if I goose it, it goes. Need to go faster? Give it more gas. Isn't that the way it's supposed to work? I have absolutely no beef with the power or the ride quality, but my wheel/tire combo is stock and no lift. If I were the OP I'd ask the dealer to remove their shit lift, and replace the OEM wheels/tires.
  20. Jul 15, 2017 at 6:16 PM
    #60
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    What performance upgrades are you referring to? Re-gearing the axles would be the best thing that you could do. Mileage difference isn't really that great and a lot of Tundras are now showing up with 38 gallon tanks.
