2017 Tacoma auto transmission slippage.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eagleguy, Dec 28, 2019.
  1. Dec 28, 2019 at 7:30 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Yea man, all those exclamation points.
    Kbran24 and Comato$e like this.
  2. Dec 28, 2019 at 7:52 PM
    jeffKcan
    jeffKcan Member
    2010 2.7 4x4
    Hey I thought mine was doing this downhill in third or whatever gear, it’s actually something to do with the emissions system. Keeping something warm or cool I can’t remember, but it’s normal.
    GreyBaldTaco likes this.
  3. Dec 28, 2019 at 7:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    It will after x keystarts where the problem is still present. Until then they are not 'set', just pending.
  4. Dec 28, 2019 at 8:13 PM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Are you a Snowflake ?
  5. Dec 28, 2019 at 8:15 PM
    GreyBaldTaco
    2019 F150 5.0
    That's a question only a snowflake would ask.
    Does my question/observation about the exclamation point offend you that much? Or are you just projecting?
  6. Dec 28, 2019 at 8:18 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Every transmission that has ever slipped in my lifetime exhibited symptoms when accelerating, putting a load on. Not letting off the accelerator.
    CrippledHo, Bleep100, Chew and 3 others like this.
  7. Dec 28, 2019 at 8:22 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    It is the Atkinson Cycle engine I think. When the load is taken off, the Atkinson cycle does what saves gas.
    Chew likes this.
  8. Dec 28, 2019 at 8:27 PM
    GreyBaldTaco
    2019 F150 5.0
    To me it sounds like the converter being unlocked. There's a thread around here where OVTune talks about some of the sorcery of the stock converter programming and how some people misinterpret the converter locking and unlocking as gear shifts
  9. Dec 28, 2019 at 9:50 PM
    ryan760
    ryan760 Well-Known Member
    I think it would have to be really low for that to affect shifting. These things hold over 11 quarts.
    2016Tacoman likes this.
  10. Dec 28, 2019 at 10:01 PM
    ryan760
    I would be extremely surprised if anything mechanical was wrong with it. My guess is it's nothing, or at worst a software update.
    Chew, 2016Tacoman and GreyBaldTaco like this.
  11. Dec 29, 2019 at 7:16 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I was wondering how a downhill slip happens too. If the transmission is actually slipping, it'll slip under heavy load/acceleration. Sounds to me like the auto downshifting.
    ryan760 and 2016Tacoman[QUOTED] like this.
  12. Dec 29, 2019 at 7:23 AM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    If you are in cruise control it will down shift to maintain speed and rpm will climb, going down hill. Sometimes it will do it without cruise.
  13. Dec 29, 2019 at 7:33 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  14. Dec 29, 2019 at 8:04 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    How familiar are you with damper lockup torque converters(a.k.a. slip controlled, half-lock, partial lock, flex lock)?
    How about transmission programming coupled to engine intervention programming?
    ryan760 likes this.
  15. Dec 29, 2019 at 8:14 AM
    #35
    Rottencotton
    Stinkin Rincon
    So the overflow hole is what used to be the drain hole ?
  16. Dec 29, 2019 at 10:10 AM
    #36
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    What are the average temps these transmissions run? Just hooked my ultragauge and was surprise that the trans temp was ave 180°. Is that normal for these?
  17. Dec 29, 2019 at 11:01 AM
    #37
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Normal 190. You are fine
  18. Dec 29, 2019 at 11:20 AM
    #38
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    Thank you. Just was curious since my 12 4cyl was always around 150.
  19. Jan 12, 2020 at 8:05 AM
    #39
    eagleguy
    eagleguy [OP] Well-Known Member
    Just got the truck back from Toyota and I quote! "Shifting of the fluid causing NO fluid to be getting in the line causes shift issues to happen". Can't make this stuff up and they actually put it on my service invoice.
  20. Jan 12, 2020 at 8:22 AM
    #40
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I would definitely try a different dealer just to see .
