2017 Tacoma blown head gasket?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimmyMac$, Mar 11, 2021.
  1. Mar 11, 2021 at 1:16 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Or trade it for the same model with the 2.7L.
    1776Taco likes this.
  2. Mar 11, 2021 at 1:29 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    What? Typically head gaskets leak to a water jacket, oil passage or externally. To leak between cylinders two gasket "o rings" have to fail, which usually means the head lifted or warped. Leaking between 3 cylinders is odd, I am assuming that they are not leaking between each other but not enough info.
  3. Mar 12, 2021 at 4:49 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Yes I agree to a point, but this has low compression this is not a coolant leak.. Headgaskets for this fault go bad between each cylinder, again I have never seen the entire bank go down for this reason....
    RedWings44 likes this.
  4. Mar 12, 2021 at 12:06 PM
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    probably a bad diagnose at the dealer. maybe second opinion is needed...
  5. Mar 12, 2021 at 5:53 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    If it was fixed properly it will be fine
    Anything can fail. Any time ,any brand. Opening up a motor and never the same is not true . It was put together from pieces and can being taken apart, repaired properly and put back together.
    Chew and RedWings44 like this.
  6. Mar 12, 2021 at 7:21 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Have you been changing the oil every 5k miles or is this the first?
  7. Mar 13, 2021 at 12:05 PM
    JimmyMac$
    JimmyMac$ [OP] Member
    Tacoma Trd sport
    Thank you everyone for the input. Since I have the extended warranty I'm thinking I'll keep it and see what happens. If something else fails, I'll get it fixed under the warranty and trade it in. I've had the oil changed on service schedule and have driven the truck like the old man I am, so it was never abused. Unfortunately, this incident has undermined my faith in the Toyota brand.:(
  8. Mar 13, 2021 at 2:10 PM
    TruckGuy63
    Gilbert
    New York
    I think you will be fine, as far the brand goes a part failure has nothing really to do with Toyota .
    Sometimes it’s just a bad manufacturing flaw of the part. There is no way of knowing ahead of time if and when a part may fail. If the dealership knows what they are doing it will be fixed.Usually they give these kind of jobs to experienced the mechanics.
  9. Mar 13, 2021 at 4:42 PM
    JimmyMac$
    Tacoma Trd sport
    Thanks TruckGuy63, that makes me feel better. I asked about who was going to do the work and they indicated it was a Master Mechanic, so I feel better about it already. New trucks are just too expensive to trade in as soon as something this big happens so I'll keep it as long as possible.
