2017 Tacoma transmission issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BrokenArrow44, Apr 8, 2017.
  1. Aug 14, 2017 at 8:49 PM
    #41
    apocataco2015
    apocataco2015 Well-Known Member
    Clayton
    Salado, TX
    2017 Tacoma TRD OR 4x4
    Fox/OME/Icon lift. TRD Beadlocks. Toyo MT’s. Pelfreybilt, RCI, Mobtown armor.
    I let off the brake and immediately started to roll back. I then gently pressed the gas and that's when I heard the chatter. I know it was underneath me. Not sure if transmission or drive shaft.
  2. Aug 14, 2017 at 9:09 PM
    #42
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Do me a favor: go put your truck in the same position and do the exact same thing, except this time, when you shift from reverse to drive, firmly hold the brake and then let off. You should momentarily stay in place. The sounds you heard was probably the hill assist control trying to work, but you didn't depress the brake firmly or didn't come to a complete stop. Let me know.
    gthupman likes this.
  3. Aug 14, 2017 at 9:30 PM
    #43
    Alpinist
    Alpinist New Member
    Jay
    85 SR5 & 04 Tacoma TRD
    Bought a new 2017 DCSB Off Road w/AT a couple weeks ago. The truck was modified by the dealer with 4" BDS lift, 33 x 12.50 18 tires and wheels, plus other mods.
    While driving the truck home to Ouray CO (up to 10,000' over the passes) I noticed trans issues, like winding to 5500 to nearly 6000 RPM prior to shifting in D. I had to let off on the throttle so it wouldn't redline. This with maybe 40 or 50 miles on the clock. I had commitments in SLC and so drove the truck manual shifting all the time so that I could stand driving it and not winding it out or lugging it too bad. The truck is back at the dealer. They tried to solve the issue thru re-flashing the computer. I was then told this would not solve the problem. I could not even use 5th gear unless I was going downhill. Never even thought about trying 6th.
    They are now installing 4.88 gears at my expense, though I will challenge the dealership and Toyota about this. This is my 4th Tacoma and have never had any issues prior. 1985 SR5, 5 speed W/6" lift and 33" tires (this truck now has over 350,000 miles and I still have it), stock 2004 Tacoma Off Road M/T x-tra cab, 2009 X-tra cab A/T w/3" lift and 33" tires. I did change gears in the 85' and went with 3.70 ratio. The other 2 trucks I bought used, but suspect they have stock gearing (never really had a reason to check).
    I know my new truck has issues with shifting and seeking gears. There is no doubt in my mind. I've never driven anything like it. Lugs under 3000 rpm then whines to excess, the down-shifts and then it starts all over again. It's OK if your driving on the flat at 75 if you don't mind 3500 RPM in 4th.
    Will post again when I get the vehicle back. Just crossing my fingers that the gearing changes solves the problem. Awesome truck if we can get the trans to co-operate. It's a Tacoma! It should perform.
    Tig3r_Bit and SavageTRD17 like this.
  4. Aug 15, 2017 at 7:58 AM
    #44
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Not to come off like too big of a jerk, but you should have test drove another stock tacoma. You probably would have noticed that in the stock configuration, the AT is already a little skittish and likes to hunt. After a while for some drivers, this lessens, but generally the AT hunts around and is happier revving above 3.5k RPM.
    Now slap a 4" lift and big 33" tires onto it. Of course its a dog, and needs a regear. Toyota should not cover this expense for you, there's nothing "wrong" with the truck. Your appearance "package" ended up costing you performance. Check out the OVtune thread if the regear doesn't solve your concerns.
    Just_us and cliffyk like this.
  5. Aug 15, 2017 at 8:49 AM
    #45
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    3rd brake light leaked water inside the cabin at 3600miles. Dealership did a quick fix until parts come in. Other than that I have no other complaint.
  6. Aug 18, 2017 at 11:26 AM
    #46
    Torqued
    Torqued Well-Known Member
    Purcellville, Va
    2017 Black TRD OR
    I really like my Tacoma but..
    I live in Co and I am always going up into the mountains for mtn bike riding etc. I've noticed that when going uphill on the hwy I feel like there are certain speeds that I cannot maintain in one gear. For example, driving 50mph in 5th. I'll start loosing speed and keep giving more throttle. Then it kicks down to 4th and accelerates back to 50mph, then upshifts to 5th again but can't maintain the speed and I slowly start loosing speed.
    Today I put the cruise on at 50mph. It holds the speed just fine in 5th. Then while on the same incline I cut the cruise off and then it can't maintain 50mph...keep adding more throttle then it kicks down and speeds up.
    It's like in cruise the throttle mapping, or shift points are completely different. Up to this point I just assumed that it was down on power because of the altitude.
    Anyone else see a dramatically different driving truck while in cruise control?
    Tig3r_Bit and mateo_roberto like this.
  7. Aug 18, 2017 at 11:29 AM
    #47
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    From my personal experience in the PNW, this is true. I would do the same drive home from work at ~65 mph and get 2mpg's better when I used cruise. The engine hunted less and holds 5th better.
    One of my biggest issues with this truck is 5th gear. It's a good ratio, but the damn truck will never let me wind it out. It sits at 1.8k-2k always. Hoping @OVTune changes this.
  8. Aug 18, 2017 at 11:38 AM
    #48
    bladsville
    bladsville Well-Known Member
    DFW
    2017 TRD Off-Road 4X4 MT
    shoulda bought a manual.
  9. Aug 18, 2017 at 11:47 AM
    #49
    Torqued
    Purcellville, Va
    2017 Black TRD OR
    Great input, thanks.
    Kilokato and mateo_roberto like this.
  10. Aug 18, 2017 at 11:48 AM
    #50
    bladsville
    DFW
    Np. Thats what we are here for. :fistbump:
  11. Aug 18, 2017 at 12:22 PM
    #51
    apocataco2015
    Clayton
    Salado, TX
    Yes I am having the exact same issue. It’s like the transmission can’t decide what gear to be in and it gets confused. I have having the update done tomorrow at my local dealer. I will follow up a few days after that to see if it resolved that issue and my original issue that I posted about in this thread.
  12. Aug 19, 2017 at 10:07 AM
    #52
    apocataco2015
    Clayton
    Salado, TX
    Got the update done this morning. Took them about an hour. I think I could tell a difference on the way home. Truck seemed to be more consistent when shifting. The truck also didn't shift too soon either which seemed to allow better throttle response. Haven't tested on highway yet. I think I need to drive it for about a month before I call it completely fixed.
  13. Sep 25, 2017 at 9:09 AM
    #53
    MikeJones7989
    MikeJones7989 Well-Known Member
    interesting
  14. Sep 25, 2017 at 2:54 PM
    #54
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Indeed it's common for folks to drive off after the update (like I did) feeling like it was all fixed, but the learning in these things is so nuanced and complex it seems to slowly pick back up poor behavior - not as bad as before the update but pretty bad, which is why you have so many folks over in the OVTune thread trying to get it addressed with an aftermarket solution. Good luck to you!
  15. Sep 25, 2017 at 2:59 PM
    #55
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    My limited shifts fine.
  16. Sep 25, 2017 at 3:00 PM
    #56
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    The timing is weird. My 17 was built in Feb and dealer has stated two times the TSB has already been applied. The biggest thing I notice is torque converter behavior when cold is better than warm. Once it locks up it's like the RPM's drop too far. The first few minutes in the morning are the best to me.
  17. Sep 25, 2017 at 3:25 PM
    #57
    apocataco2015
    Clayton
    Salado, TX
    Thanks! So far mine hasn't changed since the update was applied. I'm hoping it will stay that way.
    bshammer0[QUOTED] likes this.
  18. Sep 26, 2017 at 12:21 PM
    #58
    MikeJones7989
    do the ones built after August still do that?
  19. Sep 26, 2017 at 12:36 PM
    #59
    bshammer0
    Brandon
    Nashville, TN
    Mine was a July build - so can't comment on whether they resolved by August. I'd be shocked, sadly
  20. Sep 27, 2017 at 4:52 AM
    #60
    MikeJones7989
    have you had any issues?
