2017 Tacoma transmission issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BrokenArrow44, Apr 8, 2017.
  1. Sep 27, 2017 at 4:59 AM
    #61
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    More than I can count... most problems I've dealt with on ANY vehicle I've ever owned. Have been under my truck, in the shop more in the last 10 months of owning this truck than I have in the last several years combined.
    It's working out well now though and I am finally enjoying it, so that's something. I just hope the tranny issues, crankshaft sensor, loose bolts all over the damn thing, etc., were caught (mostly by me - dealership was worthless). Definitely get that transmission fluid checked properly, make sure you have the latest transmission TSB (ECU update) and with that build date it's probably not a terrible idea to shell out $100 to keep a spare CKP (some on the forum refer to it as a CPS) sensor on-hand.
  2. Sep 27, 2017 at 5:06 AM
    #62
    MikeJones7989
    MikeJones7989 Well-Known Member
    that is insane man. i wish you luck
    Kilokato and bshammer0[QUOTED] like this.
  3. Sep 27, 2017 at 5:07 AM
    #63
    AverageGuy
    AverageGuy Well-Known Member
    Jeff
    Kansas City
    Former Tacoma Owner. Currently Own a Lexus GX470
    Mine seems to have a mind of its own
    Sometimes, it will just hang around 3000 RPMS at 60. I'll let off the gas, or give it a bit more to see if it shifts. Sometimes it just takes literally a minute to straighten itself out
    2017 Tacoma SR 2.7 Automatic with 1000 miles on it
  4. Sep 27, 2017 at 5:07 AM
    #64
    MikeJones7989
    thats ridiculous
    Kilokato likes this.
  5. Sep 27, 2017 at 5:11 AM
    #65
    bshammer0
    Brandon
    Nashville, TN
    Thanks! For now things are working well and I'm enjoying my truck. More concerned the issues with fuel mix caused by screwed up timing the first 10k miles on a failing sensor caused premature wear on my power train and emissions (cats). I still log 2-4 misfires every trip from a cold start, though no load seems to be associated to them. So either I have a slowly failing gasket, catalyst, they are false positives bc it can't sense misfires accurately, or the truck is intentionally misfiring to heat up the catalyst... one far reaching theory I've heard.
    Good luck to you! They are fun trucks and we're designed reasonably well... the software and QC were not up to par however with some batches
  6. Sep 27, 2017 at 5:31 AM
    #66
    AverageGuy
    Jeff
    Kansas City
    I mean...I suppose i could ask the dealership, but I'd probably get a run around.
    I've also noticed that from a dead stop, when applying gas I hear a small pop in the rear and a small shutter through the gas pedal, It's pretty quick and lasts maybe a second or two. The truck is still so new to me that I'm just learning what's normal and what's not
  7. Oct 4, 2017 at 6:24 AM
    #67
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Unless I'm in ECT between 75 and 80 mph with cruise control on it will sometimes nearly redline as it shifts into a lower gear. I have a good dealer, so before we go to San Diego (850 miles), I'll take it in. I can't imagine driving over 800 miles like that. Around town, no problems, and in ECT it's ok on the freeway. I would have got a manual, but you can't get an ACC with a manual.
  8. Oct 4, 2017 at 6:27 AM
    #68
    shackley
    I think you're right about engine and transmission life. If I'm not in ECT on the freeway and there is any incline at all, it shifts constantly. I'll take it to my dealer, who are very responsive, but I doubt that they can do much about it. If they can't then I'll look at aftermarket options.
  9. Oct 4, 2017 at 7:40 AM
    #69
    Wranglerx101
    Wranglerx101 New Member
    2017 Tacoma SR5 4wd
    I had posted last year that my truck was shifting like a "drunken epileptic monkey", that is a good way to describe the issue. My 2017 is doing just that, it's at the dealer now with 4500 miles and they tell me that's normal which is BS.
    Rgisch and Kilokato like this.
  10. Oct 6, 2017 at 7:14 AM
    #70
    modform1975
    modform1975 New Member
    chris
    2017 sr5 v6
    33 inch tires and 2 inch front lift.
    I have a 2017 sr5 a/t v6 with 6,000 miles on it. its been in twice for shifting issues and now about to get switched out for another truck bc it cannot decide what gear it wants to stay in. constantly shifting and has no low end power. it honestly feels like a weak 4 cyl. vs a 278 hp engine. I am barely getting an avg of 15 mpg. very sad since they advertise 19-24.
    Rgisch likes this.
  11. Oct 6, 2017 at 10:25 AM
    #71
    Wranglerx101
    2017 Tacoma SR5 4wd
    The dealer told me that this is normal operation and there is nothing that can be done.
  12. Oct 6, 2017 at 10:26 AM
    #72
    Wranglerx101
    2017 Tacoma SR5 4wd
    I was told the same thing, "normal operation", BS is right.
  13. Oct 27, 2017 at 9:30 PM
    #73
    jakes1
    jakes1 Active Member
    Ore.
    2017tacoma Black crew SR5
    3" leveling
  14. Oct 27, 2017 at 9:32 PM
    #74
    jakes1
    Ore.
    3" leveling
    Not gone away- have 2017- shifts constanty, no power at all. Has lost power and had coast side road/ dealership finds no codes or anything. Trans( auto) horrid.
  15. Oct 28, 2017 at 6:19 AM
    #75
    Wranglerx101
    2017 Tacoma SR5 4wd
    My 2017 jumps and jerks, can’t figure what gear to go to. Downshift hard when stopping. Feels like it’s starving for fuel and when you accelerate it down shifts hard and lurches forward. Dealer says it’s normal. I’m glad I leased it. Last Toyota I will drive. Junk in my opinion.
  16. Oct 28, 2017 at 7:57 AM
    #76
    CheapLaborTJ
    CheapLaborTJ Well-Known Member
    Corporate still purposely short filling all the fluids at both TX & Mexico plants.The savings adds up with 200 K trucks a year going out the door.
  17. Oct 28, 2017 at 8:27 AM
    #77
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    I run my truck in S mode 4 at ALL times in the city. and 5 on the highway. Very rarely do I ever let it go into 6th
  18. Oct 28, 2017 at 8:29 AM
    #78
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    I've found the trick to this truck is to DRIVE it. and not let it drive you.
    If you're trying to keep your MPG's up then you're gonna have a problem and should probably buy a corolla.
    jsinnard likes this.
  19. Dec 14, 2017 at 9:29 AM
    #79
    Tacofan1981
    Tacofan1981 New Member
    2017 Tacoma TRD offroad, ext cab
    I have a 2017 Tacoma TRD off road, 8100 miles and my transmission seems to shift erratically. I have noticed that it will shift from 2 to third fine with plenty of torque (most of the time) but when it shifts to 4 it will drop from about 2500 RPM's to about 1800 and the hold for a brief second then drop again to below 1500 RPM. I assume it basically skips 4 and goes right in to 5 gear. The net result is an absolute loss of power so much so I start to slow down. I then have to give it more gas to get it to downshift and accelerate. I noticed this when I bought the vehicle but figured it was just because it was new and "stiff" so I figured I would ride it out to see if it improves. I also don't use cruse control because my MPG will drop from about 18.9 to below 16 due to frequent down shifts.
    I have an appointment with my dealer tomorrow to have it looked at and I have read, but cannot confirm, that there is a TSB to address a problem with the shift points. Is that true? I plan on asking that the transmission level be checked but is there anything else I should ask about?
    Any insight is appreciated.
  20. Dec 14, 2017 at 9:33 AM
    #80
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    THIS!
    I have a 2017 Pro, with 285/75/16 tires..... Part of me thinks its the tires, but the truck does some weird stuff on the highway, and my MPG goes to COMPLETE trash.
    Chipi3s likes this.
