2017 Tacoma transmission issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BrokenArrow44, Apr 8, 2017.
  1. Dec 14, 2017 at 9:35 AM
    #81
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    Let me know how that goes. I also can't use cruise control unless i'm going 75+ and hold 6th.... I have to almost force it into 6th.... I've been driving on long trips where im getting 19-21MPG, with my larger tires, and a roof top tent, and then i have to slow down behind a semi, and then I cant find 6th again, and get 9MPG in 4th....
    I then throw it in sport and try and force it into 5th or 6th, and it shows 5th, but never shifts.
  2. Dec 14, 2017 at 9:44 AM
    #82
    Tacofan1981
    Tacofan1981 New Member
    2017 Tacoma TRD offroad, ext cab
    I will let you know for sure. Toyota was of little help they just created a ticket for me that then forwarded to my dealer. I think my truck goes into 6 when traveling down the thruway but I am not sure i have not payed attention. What I do notice is, while using cruise control, a drastic down shift when the slightest gust of wind hits my truck. If you don't know its coming it can make you think its going to take off like a rocket.
  3. Dec 14, 2017 at 9:49 AM
    #83
    SLO TRD
    SLO TRD Living the SLO life.
    Gene
    San Luis Obispo, Ca.
    2016 Magnetic Grey TRD Sport DCLB
    Snugtop, 5100's, weather tech mats floors, truck bed, Tinted front windows.
    After second ECU update no problems.
  4. Dec 14, 2017 at 9:59 AM
    #84
    Tacofan1981
    Was there a TSB for the ECU update or was this something they just did when you took it in?
  5. Dec 14, 2017 at 10:25 AM
    #85
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    If you put in S5 it will never see 6th, S-mode limits the transmission to the gear shown in the center display, not indicate what the gear it's in. If you put it in S5 it will shift through gears 1-5 automatically but still indicate 5 on the display and never go into 6th. It only goes into 6th when in D or S6 and conditions are optimum to select the 2nd OD gear, usually meaning light load, level terrain. If more torque is needed to maintain speed it will kick down to the 1st OD gear (5th) or even down to 4th if more power is needed.
    Truck is not like a 6 speed manual or manu-matic where you can force to or keep it in 6th.
    oscolivar1 likes this.
  6. Dec 14, 2017 at 10:53 AM
    #86
    CheapLaborTJ
    CheapLaborTJ Well-Known Member
    Supposedly the main reason the engineers ruined the power trane in the 3rd Gen was to improve the MPG.
    Rgisch likes this.
  7. Dec 14, 2017 at 10:55 AM
    #87
    Brodozer69
    Brodozer69 Member
    2017 TRD Bro
    **Yelow BD led fogs** **Sick tint all over my windshield** **Fox Head Air freshener**
    It's a low torque 4500lb truck with throttle by wire and a slush box, what do you expect?
    Stocklocker, Rgisch and taco2010trd like this.
  8. Dec 14, 2017 at 3:20 PM
    #88
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    LOL - I wasn't clear enough in my description. oops
  9. Dec 16, 2017 at 6:52 PM
    #89
    Buster9898
    Buster9898 Active Member
    2017 Taco v6 sr5 4by4
    Bpf recovery point passenger side
    Not experiencing any trans.issue shifting or on the highway. I’m in the northeast - no problem on a cold start in 15 degrees in the morning, shifting from P to D than on my way to work.
  10. Dec 18, 2017 at 10:23 PM
    #90
    93 hilux
    93 hilux Member
    2017 trd sport
    Just got my 2017 trd it surges forward when I'm trying to park it also when I'm
    Backing out of my parking spot not sure what the problem is dealership isn't helpfull
    Rgisch likes this.
  11. Dec 18, 2017 at 10:30 PM
    #91
    bluenv
    bluenv Well-Known Member
    There's a whole thread on this. "Normal operation". People here will just tell you to keep your foot on the brake.
    BrokenArrow44[OP] likes this.
  12. Dec 19, 2017 at 6:17 AM
    #92
    93 hilux
    93 hilux Member
    2017 trd sport
    Ya it's not good... Or normal
  13. Dec 19, 2017 at 6:29 AM
    #93
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    The 'S' doesn't mean "Sport"... it's the manual option so that you can select which gear you want it in. Once you move it over there, it won't shift on it's own. I'm a bit confused on what issues you are seeing there.
    ** Edit - this is incorrect so please disregard!
  14. Dec 19, 2017 at 9:12 AM
    #94
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    I’ll record a video
  15. Dec 19, 2017 at 5:52 PM
    #95
    jakes1
    jakes1 Active Member
    Ore.
    2017tacoma Black crew SR5
    3" leveling
    Mine surges too----when stopping, and backing up---dangerous. Dealership no help. ( I have hesitation loss of power too) no one helps.( SR5-2017)
    Rgisch likes this.
  16. Dec 21, 2017 at 1:09 PM
    #96
    Kajabi69
    Kajabi69 Member
    Stephen
    2017 Orange Tacoma TRD Sports
    Just drove my new 2017 sports from La Paz Baja Mexico to Alta Wyoming aprox 2,500 miles . I am having the same problem with the transmission , I set the cruise on 75mph and when i come to the smallest incline it kicks back to 4th and seems to get stuck there . Love the truck but hate how it drives .
    Rgisch and Kilokato like this.
  17. Dec 27, 2017 at 1:20 PM
    #97
    AverageGuy
    AverageGuy Well-Known Member
    Jeff
    Kansas City
    Former Tacoma Owner. Currently Own a Lexus GX470
    Mines still doing it at 6k miles. I might bring it up with the service tech soon... But in the meantime I'll just continue to scream "Oh quit hunting for the damn gear" and go about my day.
  18. Dec 27, 2017 at 1:27 PM
    #98
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    It will too shift on its own, S mode limits shifting to the highest gear you select. S3 = 3 speed Auto, S4 = 4 speed auto, S5 = 5 speed auto etc
    Stocklocker likes this.
  19. Dec 27, 2017 at 2:35 PM
    #99
    jsey21
    Ok, I stand corrected.
  20. Dec 27, 2017 at 5:04 PM
    #100
    unclezippy
    unclezippy Active Member
    I have a 17 sport...shifts all over the place, cruise will drive you crazy, up and down, revving and idling....Ive had it 6 months, has 2,000 miles on it...rather drive my Odyssey with 200k on it.....dealer is no help, I asked to move up to a base Tundra, same price, twice the payment....offered me $30 k for my truck..letters to the owner, toyota customer service...no response so far.....supposedly has the latest flash, service and sales acknowledge the problem...I really want to love this truck, 42 years of Toyotas, 8 so far....traded the best truck Ive owned ('oo Tundra)for the worst...sucks because I know it could be fixed....
    If nothing else, Ill pay for the reflash when I can....but for now....anyone want to take over a lease?.....
    Rgisch likes this.
