2017 Tacoma Transmission Slipping
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jaydnul, Mar 4, 2023.
  1. Mar 5, 2023 at 12:47 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I was asking you, which Toyota vehicle did you put which wrong ATF in.
  2. Mar 5, 2023 at 12:58 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    trans shops will do a deep dive into the transmission; that's what they do. they can do the work a lot quicker than a shop that doesn't know what they are doing. the dealership isn't going to open up the transmission but a transmission shop will because they have experience.
    Chew likes this.
  3. Mar 5, 2023 at 1:16 PM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    They can also hook up a scanner and take a look at adaptation values and the likes to see if anything looks out of spec or abnormal. Which is a bit faster and actually tells a lot more than just dropping the pan. My trans shop was able to do this when my trans clutch packs were failing in my Jeep.
    cryptolime[QUOTED] and Chew like this.
  4. Mar 5, 2023 at 1:34 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    When you changed the transmission fluid, are you sure it is at the correct level at the recommended temperature range? Also, has your 2017 had the transmission flash TSB done? When my truck was new it came 1 quart low of transmission fluid and I had the transmission TSB done. Not sure which or both fixed the reviving issue.
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
  5. Mar 10, 2023 at 4:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Actually you are asking @zoo truck from his post 16.
    I'm curious as well
    splitbolt[QUOTED] likes this.
  6. Mar 10, 2023 at 4:53 AM
    splitbolt
    NW Arkansas
    Right you are.:thumbsup:
    I derped the quote.:(
  7. Mar 11, 2023 at 4:39 PM
    Domeimazn
    Domeimazn Well-Known Member
    Henro
    2020 tacoma pro
    Did you get improvement with what you tried or suggested
