2017 Tacoma washer fluid pump doesn't work at 15 deg. Or below
Discussion in '3rd Gen. Tacomas (2016-2023)' started by walleye_71, Dec 6, 2024.
  1. Dec 6, 2024 at 3:04 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Where I live everyone uses -30 degree windshield fluid. Some use -40. Don't use windshield " cleaner" as it is often not fluid containing anti-freeze. Don't mix or dilute in the summer. -30 or -40 for 365 days a year. If any less in your system pump out what's in the system when it's working and replace with the good stuff. It comes in different colors not just blue. And ya don't use ww fluid to defrost your windshield. That's what the heater and defrost settings are for.
  2. Dec 6, 2024 at 3:13 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    You mean it’s not a fluid issue, right? It most definitely is a temperature issue.
    Have you tried freezing the fluid? Just because a label reads -20°F doesn’t mean the stuff inside the jug has to be. Could be bad original quality (too low antifreeze, which is usually an alcohol), dilution at some point, or contamination in your system.
    Take out some of the fluid in your reservoir and put the jar on the ground next to your new fluid. Reassure yourself with experimental results that it’s something beyond the fluid itself, as you suspect.
    Toyota use a nice weather-sealed connector on the wiring to the washer pump. If you can get to it in your temperatures check that the contacts are clean, dry, and have bright metal.
  3. Dec 6, 2024 at 3:17 PM
    walleye_71
    walleye_71 [OP] Member
    2017 Tacoma TRD
    Thank you. I think the wire connection is the issue. It probably needs to be cleaned.
  4. Dec 7, 2024 at 11:44 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^On cold mornings where the washer pump doesn't work, do your wipers move when you try to spray washer fluid? This info helps with fault isolation.
    xxTacocaTxx and Chew like this.
  5. Jan 26, 2025 at 11:40 AM
    millcho
    millcho Active Member
    Chicago burbs
    23 TRD OFF ROAD
    I'm in the same boat with the exact same symptoms, did you ever found out what's wrong with it?
  6. Jan 26, 2025 at 12:08 PM
    canuck guy
    Alberta
    23TRDOR
    Good way to destroy anything that boiling water would touch due to the rapid temperature change. Windshield would totally shatter. Complete dumb idea.
    eurowner likes this.
  7. Jan 26, 2025 at 1:08 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  8. Jan 26, 2025 at 1:45 PM
    canuck guy
    Alberta
    23TRDOR
    fmb and TA2016[QUOTED] like this.
  9. Jan 26, 2025 at 1:48 PM
    millcho
    Chicago burbs
    23 TRD OFF ROAD
    TA2016[QUOTED] likes this.
  10. Jan 26, 2025 at 2:09 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Same problem. Had the orange stuff rated to -25 I believe and it froze up in the lines and bottom of tank where pump is. After warming up I replaced the fluid with a new jug of the blue rated at -20 and it froze up also. Bought a new jug a month later for my work truck and it froze up for the first time too in single digit above zero temps. I think a couple of these companies are screwing us.
  11. Jan 26, 2025 at 2:19 PM
    canuck guy
    Alberta
    23TRDOR
    This blue stuff works good up here. -40 rated . Never "freezes".
  12. Jan 27, 2025 at 7:58 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    It was sarcasm. You are correct, it's a horrible idea. Was just another bad idea like expecting windshield washer fluid to melt your windshield ice instead of just scraping it.
    b_r_o likes this.
  13. Jan 27, 2025 at 9:39 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the pump isn't humming when problem happens test for power right at the connector w/ a DMM or test light and see if the pump is being commanded to run.
    If 12volts is present then look into the fluid freeze point or or maybe it needs a pump. They're just cheap little plastic things after all..
    If 12 volts isn't present then look at the control side like washer switch, relay(s) and wiring.
    Anything else is just guessing
    xxTacocaTxx likes this.
  14. Jan 27, 2025 at 9:41 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I used hot water to clear ice from the front porch once also, worked great until the ice wreaked revenge and came back in full force on all the water I sprayed on the porch!
    YF_Ryan[QUOTED] likes this.
