2017 Tacoma won’t start - because tail lights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jasonalex28, Jan 22, 2019.
  1. Jan 22, 2019 at 6:28 PM
    #41
    DoggMan1163
    DoggMan1163 DoggMan1163
    Robert
    2020 Taco TRD off road
    Sounds like a direct short pinched wire will kill system because of direct ground
    Running Board Man likes this.
  2. Jan 22, 2019 at 6:34 PM
    #42
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  3. Jan 22, 2019 at 6:48 PM
    #43
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    All vehicle electrical wiring circuits are designed with “engineered” resistance which has always been critical. Today with canbus and multiplexing you simply cannot change or alter the “engineered” resistance at all. There is no “what if’s”, you cannot substitute bulbs, resistors, actuators, relays, etc., the electrical part or components you replace must match exactly what you removed or you will definitely find yourself in a huge electrical mess where nothing will operate as designed. Today’s vehicles are no longer the “simple” set of wheels that anyone could work on with their $50 Craftsman tool set. :mudding:
  4. Jan 22, 2019 at 7:01 PM
    #44
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Could be a Das Boot sorta thing. o_O
  5. Jan 22, 2019 at 7:46 PM
    #45
    Shill1369
    Shill1369 Active Member
    Tacoma
    Lifted,lights
    Check for a ground wire that may have broken when you moved the bed
  6. Jan 22, 2019 at 8:01 PM
    #46
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Whoa, so many guests here. I hope OPs grammar teacher isn’t here. Glad you got it started OP .
    Sounds like you pinched a wire moving the bed which caused a short.
  7. Jan 22, 2019 at 8:58 PM
    #47
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Bias voltages, known resistance specs, etc allow the modules to monitor circuit integrity. CAN and other network types allow the modules to communicate.
    These systems allow easier diagnostics and more advanced functions (like not going into reverse at 80mph) but unlike your '69 GTO you can't just splice into any convenient wire to run random 12V components.
    If you want to add stuff install a secondary fuse box and use appropriate guage wire with each load component on its own fused circuit.
    Everybody reading this thread should see why aftermarket remote starts and alarms are a bad idea. Very few of them do it properly.
  8. Jan 22, 2019 at 9:22 PM
    #48
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Example 1: See my old roommate's Tacoma with the SUPER AWESOME COBRA ALARM SYSTEM!!!!! Splice galore and somehow still worked... (80% of the time).
  9. Jan 22, 2019 at 9:23 PM
    #49
    Jacktracysmogjack
    Jacktracysmogjack Member
    Jack
    16 TRD OFF ROAD
    None yet
    Sounds like a bad ground
  10. Jan 22, 2019 at 9:41 PM
    #50
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    i waz hopping thaat some1 wood tell him thaat BRAKE is not speeled BREAK
    sorry
  11. Jan 22, 2019 at 9:42 PM
    #51
    JasonLee
    15 TRD OffRoad
    It's a combination of the "one-size-fits-all" wiring gauges (cheap) splices normally used combined with the fact that a lot of people go to the cheapest place to install and end up with issues.
  12. Jan 22, 2019 at 9:51 PM
    #52
    JasonLee
    15 TRD OffRoad
    I was thinking more these type:
    Twisted and taped is great until the copper wire starts stress relieving itself and loses the tightness of the wrap and then has intermittent connectivity...
  13. Jan 22, 2019 at 10:04 PM
    #53
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Made me spit my drink.
    I think someone told him, but he continued to use "break"
  14. Jan 22, 2019 at 10:07 PM
    #54
    JasonLee
    15 TRD OffRoad
    Does this image work? [​IMG]
  15. Jan 23, 2019 at 2:08 AM
    #55
    Rainoffire
    What about posi-taps?
    Less damage to the existing wiring, and small hole it makes is almost unnoticeable.
  16. Jan 23, 2019 at 5:42 AM
    #56
    0v3rwatch
    0v3rwatch Member
    JL
    Cement Black 2018 Tacoma TRD Off-Road
    Predator step bars, Decked Drawer System
    These Tacoma's have the most finicky electrical system I've ever seen in my life. 3 days after I bought my Tacoma I had to have it towed to the dealership with 138 miles on the odometer. It shut off on me on the highway with the screen claim the transmission was critically overheating and it shifted itself into neutral. I had to pull over and try to restart the truck. Kept giving me the message that it be couldn't start because the Transmission had seized up and to see my dealer. Towed it in. Turned out to be I had one of those cell phone chargers off eBay with the little led lights on them that make it look like power is flowing into the phone. Apparently that was somehow feeding Back into the electrical system making the ECU detect problems that weren't there. Even the Toyota tech couldn't believe it. Their computer showed power anomalies all over the place so he called me out into the shop asked if I had done anything to the truck yet and I reached into my center console to grab something else out and apparently knocked the USB out of the cigarette plug and he goes "what did you just do?" So I told him, and he jumped in hit start and all the problems were gone. Plugged that back in and got "transmission has seized. See your dealer" message. No one at the shop could believe that USB cable had crippled the entire truck. I had that cable in my 2003 Avalanche and in my 2004 Wrangler before this with no problems whatsoever.
    So if my phone charger could cripple my tacoma it's likely something equally stupid crippled yours :(
    #56
    Delmarksman likes this.
  17. Jan 23, 2019 at 5:55 AM
    #57
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    wtf. That 12v should be straight to fuse box and straight to power source. Why that is hooked up to the ECU or other sensitive electronics is ridiculous.
    I remember my Chrysler 300 being somewhat similar. Couldn't even replace a speaker without frying the whole stereo since its all computer controlled now.
    #57
  18. Jan 23, 2019 at 6:14 AM
    #58
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    It’s called canbus and multiplexing.
    Running Board Man and JasonLee like this.
  19. Jan 23, 2019 at 6:15 AM
    #59
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    Total garbage and does not belong in any vehicle, new or old.
  20. Jan 23, 2019 at 6:32 AM
    #60
    toysrgood
    SC
    2011 4x4 Reg Cab
    Right but that's like swapping your bulbs in your house to LED and now your microwave doesn't work. That should all be on separate circuits not connected or affecting each other in any way. It's a 12v charging port, not an OBD2 port with access to the whole system.
    They're making vehicles more complex in many great ways, but also over complicating simple features.
