2017 Toyota Tacoma oil leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bbmaddox89, Nov 12, 2022.
  1. Nov 12, 2022 at 6:57 PM
    #41
    Bbmaddox89
    Bbmaddox89 [OP] Active Member
    2017 Tacoma off-road
    Oil change tomorrow is the plan with 020 mobile one oil
  2. Nov 12, 2022 at 7:00 PM
    #42
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Good luck.
  3. Nov 12, 2022 at 7:09 PM
    #43
    Bbmaddox89
    Thank you I need it
  4. Nov 12, 2022 at 8:34 PM
    #44
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    You sure you drained the engine oil and not the trans fluid? Oil is in the litttle black oil pan. Just in case you drained trans, added 6 qts to engine.
  5. Nov 12, 2022 at 9:24 PM
    #45
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You didn’t notice a leak when you changed the oil?
  6. Nov 13, 2022 at 5:04 AM
    #46
    Bbmaddox89
    I didn't notice any leaking when I change the oil
  7. Nov 13, 2022 at 5:45 AM
    #47
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yeah, or you could of pinched that o ring.
  8. Nov 13, 2022 at 5:46 AM
    #48
    Bbmaddox89
    Why would pinching an o-ring make it leak above the pan there's no oil up by the filter it's back further on the vehicle
  9. Nov 13, 2022 at 5:54 AM
    #49
    Northwoodshyun
    Northwoodshyun Well-Known Member
    St. Paul MN
    Oil pressure will make the leak worse and look like it is coming from the above because of the pressure induced spraying action. My money is on the improper installation of the oil filter housing which includes seating of the O-Ring. Did you use Toyota factory OEM filter and O-rings? I don't think the issue is due to oil brand.
    zoo truck likes this.
  10. Nov 13, 2022 at 6:00 AM
    #50
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you have 12 QTS of oil in the sump it sure as hell will show up on the dip stick! Oil it's self has nothing to do with it, it does not arbitrarily leak.
  11. Nov 13, 2022 at 6:07 AM
    #51
    zoo truck
    None
    Maybe that plastic oil filter housing has a small crack from using the old movtix tool or some other similar type that grabs the housing's ears instead of the flutes.
  12. Nov 13, 2022 at 6:10 AM
    #52
    Bbmaddox89
    I will check again I'm going to wipe everything down super clean pop that plastic clip off I have to watch start the truck and watch with a flashlight to see if the oil is coming down or getting squirted up I'm pretty sure it's coming down I don't see how even with a squirt gun you could get oil from the filter housing to the rear of the pan above it and then up into the housing past that clip
  13. Nov 13, 2022 at 6:11 AM
    #53
    Bbmaddox89
    I also wonder how that small oil pan can even hold six quarts lol
  14. Nov 13, 2022 at 6:13 AM
    #54
    Bbmaddox89
    I changed the plastic housing out yesterday morning for the metal one because it was a piece of crap and the drain plug on the bottom was not working it was frozen.... Also I was hoping bringing the oil level right in between the two dots would help but it didn't
  15. Nov 13, 2022 at 6:13 AM
    #55
    Bbmaddox89
    I did use a fram filter the first time and when I change the cartridge housing I put a new mobile one filter in there the more expensive filters around $20 a piece
  16. Nov 13, 2022 at 6:14 AM
    #56
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    FWW these trucks are miserable to check oil level. If you simply check the level pulling the dipstick it's not uncommon for it to read high. If you pop the dipstick and leave it slightly ajar for 15-20 minutes and let the dipstick tube drain down you'll get a more accurate level. I ran into this with my truck after a dealer oil change. I thought it was way high and the service advisor said to try that for level so while I didn't buy it at the time, I did it at home and the level was bang on.
    Rusty66 likes this.
  17. Nov 13, 2022 at 6:15 AM
    #57
    Bbmaddox89
    Yes big time streaking and it's way miserable my old GMC Sonoma has gritted on the dipstick really helps
  18. Nov 13, 2022 at 6:19 AM
    #58
    Bbmaddox89
    I just don't understand...... I've never seen a filter raise pressure enough to blow SEALS or anything like that I'm not a mechanic but usually you can find the two plus two and always get four
  19. Nov 13, 2022 at 6:20 AM
    #59
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Your truck has 90k on it. It's the rear main seal. Ignore it, put 30 wt in it , or get it fixed.
  20. Nov 13, 2022 at 6:22 AM
    #60
    Bbmaddox89
    I'm definitely going to get it fixed . To have a rear main seal go out at 90,000 is crazy I have a RAV4 it's a 2001 with over 315,000 on it and it just keeps going..... It does burn a little oil though.
