2017 Toyota Tacoma TRD and multiple codes and issues (Tech Stream)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pityocamptes, Aug 10, 2024.
  1. Aug 10, 2024 at 8:53 PM
    #61
    pityocamptes
    pityocamptes [OP] Well-Known Member
    I think they tied the ign into one of the fuses on the lower panel. I know when I was installing an amp i was using one of the ign fuses for the amp relay kick on, not that much voltage, it was doing weird things then, so I ended up putting it on the window fuse which only kick on when the ign kick on. Im pulling the panel to see where these guys tied the 12+ and ign to...
  2. Aug 10, 2024 at 8:54 PM
    #62
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Well yea if it's screwing with the voltage on sensitive circuits it can cause things to get wonky too.
  3. Aug 10, 2024 at 9:21 PM
    #63
    pityocamptes
    Ok so here is what I think I found. I pulled the alarm body out, it was tight, I pulled the fuse for the hot and the vehicle did not have any issues. Put the fuse back in, and it DID NOT have any issues. So I wiggle the harness and I have issues again, after the beeping the truck does when the door is open I believe I hear the distinct sound of arcing.. Im going to have to pull the harnesses on the alarm and see whats going on. Probably rubbed against one of the metal pieces under the dash and thats why it was intermittent..
  4. Aug 10, 2024 at 9:25 PM
    #64
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's not good, might want to unhook the battery until you find that. Wouldn't want something to have a "thermal event" during the night.
  5. Aug 10, 2024 at 9:26 PM
    #65
    pityocamptes
    Absolutely! Im wondering why the fuses didnt blow?
  6. Aug 10, 2024 at 9:27 PM
    #66
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Might have not been quite enough of a short just yet.
  7. Aug 10, 2024 at 9:28 PM
    #67
    pityocamptes
    Ok thx. Will update tomorrow in the event anyone else has this problem.
    Dm93 likes this.
  8. Aug 10, 2024 at 9:28 PM
    #68
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What still puzzles me is why having the scan tool plugged in "fixed" it.
  9. Aug 10, 2024 at 9:31 PM
    #69
    pityocamptes
    I have no idea. Im hoping this is it. As mentioned it appears that the installers knew what they were doing. Lots of ecu type boxes on the drive side panel and they tied in the wires to little wires etc. Regarding the scan tool plug I have no clue, im going to make sure its a short and not something rubbing against each other. Ill update.
    Dm93 likes this.
  10. Aug 10, 2024 at 10:42 PM
    #70
    pityocamptes
    Well it wasnt a sizzling wire, that noise was velcro behind the wire harrness holding the alarm wire to the inside fire wall. When I was wiggling it, it was rubbing against that velcro... lol. I did wiggle the wires and i pulled all the connectors out of the box looking thing that has the inside fuse box under it. Pulled the connectors, reseated, wiggled the wires, cleaned it up, doesnt do it anymore. I have no idea whats gong on? I cant replicate it anymore. Will try again tomorrow.
