2017 TRD OR Performance Boost with an air intake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sheiweesh, Sep 22, 2018.
  1. Sep 22, 2018 at 3:51 PM
    Sheiweesh
    Sheiweesh [OP] Well-Known Member
    Massachusetts
    2017 Tacoma Double Cab 4X4 Off Road
    Chrome Step Rails and Foldable Tonneau
    Will do that first. Thank you.
  2. Sep 22, 2018 at 4:15 PM
    Sheiweesh
    Massachusetts
    I’ll definitely take it in for that TSB 62-18. Thanks.
    Thegenerik1 likes this.
  3. Sep 22, 2018 at 4:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Out of everything you listed above, the non ethanol gas is your only thing that adds a bit of power. The intake might give you a few hp, but only at wide open throttle when the engine control unit is out of the equation. Your extra octane fuel adds nothing but it does change the spark advance a bit and gives you a bit more (maybe 5) hp.
    So, pure gas and high octane gives you between 5-10 hp which is good, as long as you keep using it. Everything else? Nada.
