2017 Trd pro shocks void it on top hat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pat410, Mar 23, 2025.
  1. Mar 24, 2025 at 4:06 AM
    Pat410
    Pat410 [OP] Member
    How would you go about doing that. I put them in and feel like I could do it just need to know the steps. Also does anyone have parts numbers for these.
  2. Mar 24, 2025 at 5:33 AM
    InThePlains
    InThePlains Well-Known Member
  3. Mar 24, 2025 at 7:13 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The shock doesn't need a rebuild if it isn't leaking. Being 8 years old, a rebuild is recommended, but the cost may exceed what you paid for them.
    Any independent shop that can replace normal shocks and struts can replace the top hat along with new hardware.
  4. Mar 24, 2025 at 7:54 AM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Check out this post I made. The video at the bottom of the post walks you through it. It’s a pretty solid method and much safer than the off-the-shelf spring compressors. https://www.tacomaworld.com/posts/29720633
    3JOH22A likes this.
  5. Mar 24, 2025 at 11:37 AM
    InThePlains
    Did the previous owner had someone rebuilt or replaced the shock absorber? It's not right. The threaded part is not part of the tophat, it's the shaft of the piston. Some of the shaft have fulled threaded end, some have wrench flats(i.e. Toyota). It's not the correct shaft in yours. You don't replace that as part of the lift kit, unless it's built or rebuilt by a shop.
  6. Mar 24, 2025 at 11:40 AM
    InThePlains
    Another possibility is your strut is missing one bushing under the top hat.
  7. Mar 24, 2025 at 3:38 PM
    Pat410
    Pat410 [OP] Member
    I’m having a shop look at them now. I did notice that the piston threads were different could it being a different type of piston be the issue because it seems like most people thinks it’s a bushing missing. A piston issue I’m assuming is more serious task.
