2017 TRD pro stiffer springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmc1010, Apr 25, 2017.
  1. Jan 9, 2018 at 7:09 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    You said the Icon 700# coilovers lifted the front of truck too much. Do not set any preload on the springs and will not be lifted at all. With 1.1" preload the front is lifted 2.75" from stock like mine.
  2. Jan 9, 2018 at 7:14 PM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    When you say preload I interpret that to mean adjusting coil seats like you would do with 5100's or 6112's; Pro shocks don't have that.
  3. Jan 9, 2018 at 7:24 PM
    Dacon
    Danny
    Gilbert, Arizona.
    I know PRO shocks are not adjustable, I had them and changed to Icons 700# coilovers.
    You can adjust the height if the Icons from the top where that ring is to compress the springs. You posted that the Icons 700# coilovers were tried and the truck front was too high. Remove preload and no more lift.
  4. Jan 9, 2018 at 7:27 PM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Okay, now I get it.
    The truck has the factory Pro shocks on it. We tried to change his springs on the Pro shocks to compensate for the added weight which raised the front too high. While I wouldn't put it past him in the future, he want to keep the Pro shocks.
  5. Jan 9, 2018 at 7:29 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Keep the PRO shocks with added front weight? Way too soft ride.
  6. Jan 9, 2018 at 7:36 PM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Um...that's kinda why he started this thread lol.
    For the record, I do understand that mass, dampner rates, and spring rates all affect the tuning of a proper suspension; not that I know how close to critically damped (plus or minus) you want to be or how to characterize the forcing function for modeling but I have solved a differential equation or 2 modeling the system.
    rlx02 likes this.
  7. Jan 10, 2018 at 8:41 AM
    40tude
    40tude Well-Known Member
    Lutz, FL
    Anybody thought of just going to a machinist and having them make a spacer ring for the bottom of the spring, should be the same as adding a bit of preload. Half an inch thick should work.
  8. Jan 10, 2018 at 8:42 AM
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    There are already many preload spacers out there. Most of us hate them though.
  9. Jan 10, 2018 at 9:06 AM
    justyr1
    justyr1 Well-Known Member
    17 Taco Turd Pro
    There's a guy local to me, he's on the forums, that has a lot of experience with working with suspension and revalving stuff (que the non-believers in 3...2...1...). I haven't talked to him about all the details yet but we've been discussing going with a King or Eibach #700 spring at 12". Not sure if that is the route I will take as I would MUCH rather just get the full suspension swap, but I will let this post thread know if that happens and what the end result is.
  10. Jan 10, 2018 at 9:08 AM
    Mike's Custom Toys
    Grants Pass, OR
    Let us know how it works out
  11. Jan 10, 2018 at 12:57 PM
    40tude
    Lutz, FL
    not what I am talking about
  12. Jan 10, 2018 at 1:07 PM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    I once took a rental Olds Calais over worse terrain than that...
  13. Jan 10, 2018 at 4:31 PM
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    As a Pro owner running 285/85/16 tires, and a significant amount of added weight to the front of the truck, I have settled on running Kings or Icons.
    I actually love the suspension, but I want more clearance, and the weight is causing sagging, and in turn, my tires are rubbing when under flex/full articulation conditions.
    The stock suspension did exactly what I wanted from the truck - It allowed me to drive 70 MPH in the dessert, even jump the vehicle on accident once. I have been able to hit some difficult trails, with lots of comfort. If weight wasn't an issue, and growing into the hobby of wheeling, and having the need for more difficulty than I ever anticipated, I would HIGHLY recommend the Pro Suspension.
    It's common to get hate on the forum for buying a pro, but honestly, the suspension is awesome and the other features were well worth the money, TO ME.
  14. Jan 10, 2018 at 5:05 PM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Have you considered running a Gambler 500?
    BuddyS[QUOTED] likes this.
  15. Jan 11, 2018 at 11:56 AM
    #35
    40tude
    Lutz, FL
    I think I actually just found a solution, icon factory Coil-Over springs are 13” free length and 650lb rate. I just got a pair on eBay but will not be able to install in the near term.
    #35
  16. Jan 11, 2018 at 12:42 PM
    #36
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    with swapping springs, doesn't the suspension actually change a lot, and require a "Retune".
    #36
  17. Jan 11, 2018 at 12:59 PM
    #37
    40tude
    Lutz, FL
    That will really depend on the amount of lift
  18. May 1, 2018 at 6:09 PM
    #38
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    any word?
  19. May 2, 2018 at 4:37 AM
    #39
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    Sub'd
  20. Aug 21, 2018 at 11:31 AM
    #40
    Murdoch33
    Murdoch33 Well-Known Member
    2018 Black TRD Pro
    How did it work out ?
    #40
    Alesimo likes this.
