2017 TRDOR transfer case not engaging
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spudroller, Jan 1, 2023.
  1. Jan 2, 2023 at 5:30 AM
    Spudroller
    Spudroller [OP] Member
    Dusty
    2017 quicksand Tacoma TRD off-road
    Ranchhand brush guard, Predator tubes
    Flashing light on the dash. Yes the front engages. Have confirmed the front drive shaft spins when the truck moves.
  2. Jan 2, 2023 at 6:07 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    That isn't confirming the ADD engages. Flashing light and driveshaft clues point to only the tcase engaging. ADD sounds like your issue.
    Chew and BLtheP like this.
  3. Jan 2, 2023 at 2:35 PM
    Spudroller
    Dusty
    I must have missed something. What is the ADD.
  4. Jan 2, 2023 at 2:48 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Automatic disconnecting differential or something like that. It’s the actuator at the front diff that engages and disengages it from the driveline. Both it and the t-case actuators have to engage for 4wd to function. If the driveshaft is spinning then it sounds like the t-case actuator is working and the ADD is not.
    ShimStack likes this.
  5. Jan 2, 2023 at 5:55 PM
    Spudroller
    Dusty
    That part is working. I have heard it move.
  6. Jan 2, 2023 at 6:19 PM
    ShimStack
    Ben
    NC
    We've explained why it's likely not working. You need to investigate more thoroughly. G'luck.
    Chew likes this.
