2017 TRS Morimoto XB LED Fog Light Install Guide
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DarkestCon, Jan 13, 2017.
  1. Aug 23, 2019 at 2:34 PM
    #101
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The connection is polar specific. See if you can undo the wires from the connector (I used a small automotive pick, but a super super small screwdriver might work too) then reverse the connection before you redo it and mark the wires.
  2. Aug 23, 2019 at 2:38 PM
    #102
    grafparka93
    grafparka93 Active Member
    2016 Tacoma Sr5 2TR-FE
    I got green/red but i got no power coming from the truck side of the harness
    RobP62[QUOTED] likes this.
  3. Aug 23, 2019 at 2:46 PM
    #103
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Stupid questions first.
    Sorry but, switch it on?
    The OEM worked before you did the install?
    Did you check your fuses?
    If the answer to these are all yes then either somehow you pulled a wire loose farther up the line or they are reversed.
  4. Aug 23, 2019 at 2:49 PM
    #104
    grafparka93
    Tested it with a multimeter on each light setting.
    No oem foglights before hand
    Bought the harness from toyota.
    Checked the fuses didnt have the (Fog Fr) relay so i used the horn one and it still didnt work
  5. Aug 23, 2019 at 3:01 PM
    #105
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Have you checked that harness for continuity?
    Have you tried the horn after hooking things up to be sure the horn fuze didn't blow?
    Did the harness come with a relay? I would assume that relay is larger than the horn relay.
  6. Aug 23, 2019 at 3:14 PM
    #106
    grafparka93
    I got nothing coming from the truck side of the harness. Horn still works. And i thought the same.
    RobP62 likes this.
  7. Aug 23, 2019 at 7:15 PM
    #107
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    What about the harness continuity? I mean its highly unlikely that a new harness is bad but what else could it be? Sorry I'm not much help.
  8. Apr 28, 2021 at 10:51 AM
    #108
    Blue Hooligan
    Blue Hooligan Well-Known Member
    Winnipeg
    2017 Black Tacoma TRD Sport
    It's been awhile since you guys installed your fogs, just wondering if the gap between the lens and the bezel caused any problems like bugs or mud getting inside the bumper?
  9. Apr 29, 2021 at 1:24 PM
    #109
    bbrown
    bbrown Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    Had mine since 2017. No issues.
    Blue Hooligan[QUOTED] likes this.
  10. May 8, 2021 at 4:41 PM
    #110
    2017OR
    2017OR Well-Known Member
    2017 TRD Off-Road
    TRD exhaust, Pro Grill, Access Tonneau cover, TRD Pro wheels, BumperShellz, Pro shift know, Yota LED grille lights
    Had mine for about 2 years. No problems.
