2017 V6 Sport jerks coming to stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tyler47, Feb 24, 2018.
  1. Mar 2, 2018 at 3:12 PM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    What would the consequences be for over tightening the ubolt nuts on the rear axle?
  2. Mar 2, 2018 at 3:42 PM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    Over tightening the nuts on the rear axle u-bolts could possibly lead to a failure of the bolts. When you torque something to a set value you are actually stretching the item, here the u-bolt, to where it will keep the nut on it under pressure and from loosening up. When a mechanic tightens a race motors connecting rod bolts, they actually measure the length of the bolt tightened compared to the length of the bolt free sitting and un-tightened. What they are actually measuring is the amount the bolt has stretched, more accurate than torque value. Overtightened means overstretched and could lead to possibly snapping the bolt.
  3. Mar 2, 2018 at 3:47 PM
    strktly_bodysurf
    Oh, okay I understand what and why torque specifications are implemented in regards to the life of the bolt, I thought you meant over-tightening the bolt could directly cause axle wrap or some type of drive line issue. My bad and thanks
  4. Mar 2, 2018 at 3:59 PM
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    Havn't happen to many times in the Tacoma, happened a lot in my quad cab dakota. After checking for loose/worn items, spare tire, bushings, etc.. I just assumed it was fuel sloshing around in the tank. Seemed like it happen the most with the tank at about 3/4 full.
  5. Mar 2, 2018 at 4:09 PM
    CementHead18
    Jim
    SC
    Oh, and yeah, my 18 TRD Sport has done the jerk thing a couple of times. Happens also when cold and it definitely feels like it is dropping into first gear on a downshift right before the truck is actually stopped. Never happened after it was already stopped.
    trazerr and Wesintex like this.
  6. Mar 12, 2018 at 7:47 AM
    ajollyman
    ajollyman Member
    steve
    2017 Tacoma TRD Off Road
    mone
    Now that I have 500 miles on my TRD, I noticed the "jerk" happens when I stop, start, then stop again before the truck gets through the normal range of shifting. It does not do it if I am able to get far enough to get into the upper gears.
    I have another question, why does the truck have a decal on the rear of the bed that says it is a "TRD OFF ROAD" when it is actually a "TRD SPORT" I asked the salesman that, since it is not a 4 X 4. I guess it is because of the suspension? I told the salesperson that I guess i could get off the road, but getting back on may be a little tricky?
  7. Mar 12, 2018 at 8:00 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Do you have a hood scoop or a locker? They probably put the wrong stickers on. I've seen that before.
    shakerhood likes this.
  8. Mar 12, 2018 at 8:03 AM
    pralix
    pralix Active Member
    William
    2017 Cement Tacoma TRD Pro
    I haven't seen this issue with my 17 Pro but I had a similar issue with my 07 FJ. Something in the traction control system does not like the heavy paint road markings. If it is the least bit wet or slippery I will feel something similar to what the OP posted.
  9. Mar 12, 2018 at 8:06 AM
    ajollyman
    ajollyman Member
    steve
    mone
    No scoop, probably the reason as all vehicles I seen with the scoop, was marked "Sport"
  10. Mar 12, 2018 at 8:19 AM
    toyotatacomaTRD
    Sounds like you have an off road. Salesman are often very uninformed. Looking for my 2018 was frustrating, one inaccurate statement after another. Multiple dealerships.
  11. Mar 12, 2018 at 8:47 AM
    ajollyman
    ajollyman Member
    steve
    mone
    Spoke with my "real" salesman (gone to california when transaction made) He says it is an "off road" no mistake. The locking differential is the reason they call it such. Thanks you guys!
  12. Apr 5, 2018 at 9:28 AM
    toyotatacomaTRD
    Not sure if you ever got this resolved, but it sounds like there was some bent axles causing this. Known problem now. It also warped the breaks.
  13. Apr 5, 2018 at 9:33 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Care to elaborate?
  14. Apr 5, 2018 at 10:30 AM
    ajollyman
    ajollyman Member
    steve
    mone
    Just returned from 1600 mile trip and while in DC, did not notice it all. Too busy watching my fellow auto operator I guess. But I had reported that mine seemed to be more noticeable in stop and go traffic. Have since noticed it in longer driving situations, but not a regular thing/////
