2018 leaking rear diff
Discussion in '3rd Gen. Tacomas (2016+)' started by Nimbostratus, Feb 9, 2019.
  1. Feb 10, 2019 at 8:13 AM
    #41
    gitacotrd
    gitacotrd Well-Known Member
    Marc
    Texas
    2018 Cement TRD offroad
    Avid lightbar w/30in LED, TRD intake, LED HLight HID fog. Replaced all speakers.
    Accept what you want... I brought it in and they tightened it and cleaned it off. If there is an issue it is noted and they will fix it if it continues. The seepage was minimal.
    JCOOR likes this.
  2. Feb 10, 2019 at 8:18 AM
    #42
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I vaguely remember reading something that said Toyota was moving to a different place for diffs, but that article may have not applied to Tacoma's, would have to see if a 2019 still says that.
  3. Feb 10, 2019 at 8:19 AM
    #43
    gargamel05
    gargamel05 Well-Known Member
    Bay Area, CA
    Yes, You should take it in. This happened to my 2016 Tacoma. Took it in and they changed the gasket, put in new diff oil and re-torque all the bolts. No problem since ;-)
    MoneyMan55 likes this.
  4. Feb 10, 2019 at 8:20 AM
    #44
    ShirtTucker
    ShirtTucker Well-Known Member
    2017 V6 Sport AC MT
    Lot-o-stuff
    Tightening the bolts to spec has generally been the first step the dealer takes. They'll tighten them, clean the diff, and send you on your way.
    If that fixes the issue, you're golden. If not, then you return to the dealer for a more invasive, and lengthy, fix.
    Some owners have also had the leak disappear after installing a better breather, but others say it made no difference.
  5. Feb 10, 2019 at 8:26 AM
    #45
    pelts79
    pelts79 Active Member
    Mine looked similar and when I took it in for my 10,000 mile oil change I had them look at it and they checked it out and told me it was nothing to worry about. Mine is a 2018 by the way.
  6. Feb 10, 2019 at 9:57 AM
    #46
    fl_taco
    fl_taco Well-Known Member
    manny
    2017 Off-road 4x4
    Yea rear diff. Had to go back 6-7 times to get it fixed.
  7. Feb 10, 2019 at 10:07 AM
    #47
    JCOOR
    JCOOR Well-Known Member
    2018 DCSB MT
    HF Sliders, 255/85/16
    What exactly was the problem?
  8. Feb 10, 2019 at 10:23 AM
    #48
    fl_taco
    manny
    2017 Off-road 4x4
    That I don’t know. I don’t know if it was just the dealer tech not installing parts right or a warped diff. I just know that Toyota acknowledged it was a problem and agreed to buy my truck back.
  9. Feb 10, 2019 at 11:20 AM
    #49
    Nimbostratus
    Nimbostratus [OP] Well-Known Member
    Tuscaloosa, AL
    2018 Toyota Tacoma TRD-OFFROAD
    What was it doing? Actively dripping or what?
  10. Feb 10, 2019 at 11:21 AM
    #50
    Nimbostratus
    Tuscaloosa, AL
    Did they give you what your originally paid?
  11. Feb 10, 2019 at 11:37 AM
    #51
    Fiveball
    Fiveball New Member
    Brakleen the grease or oil off the cover. Tighten bolts and give it a couple weeks . Then see about seeing if the dealer or shop will replace the gasket. Shouldn't be a big deal . If the gasket was wet and it is of an absorbant cork type it may weep out some . I wouldn't be too alarmed . I did own a Jeep for a decade though .
  12. Feb 10, 2019 at 11:43 AM
    #52
    TrdSurgie
    TrdSurgie revised
    Oahu
    Just tighten the nuts..... stupid simple.
  13. Feb 10, 2019 at 12:37 PM
    #53
    Nimbostratus
    Tuscaloosa, AL
    Just kind of scared to mess with it before Toyota looks at it. Don’t want them to think I tampered with it.
    Lt. Dangle and Tacoma2020 like this.
  14. Feb 10, 2019 at 12:39 PM
    #54
    PrimerTaco
    PrimerTaco Well-Known Member
    2019 TRD OR DCSB 4WD Cement Tech/Prem, Taco #7
    Bedmat,Tint,Suntek PPF,CeramicPro
    The leaf springs, frame and a few other things on the 2nd gen remained an issue the entire 10 years.
    JaCado likes this.
  15. Feb 10, 2019 at 12:42 PM
    #55
    sumorus
    sumorus Get in loser, we're going hammer shopping.
    Albert
    2019 Cav blue SR5 "XP" DCSB
    TRD pro wheels Predator steps Black badges
    Hell naw, dont touch it. Dont even look at it again lol
  16. Feb 10, 2019 at 12:50 PM
    #56
    sumorus
    Albert
    Just got under mine. 2019 assembled in baja, diff says HINO MOTORS MANUFACTURING. So possibly US or Japan made :notsure: I'm happy with either.
    shakerhood likes this.
  17. Feb 10, 2019 at 12:57 PM
    #57
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    I believe when your vehicle is bought back you sign a disclosure not to speak about the settlement.
  18. Feb 10, 2019 at 1:02 PM
    #58
    shakerhood
    Southern Ohio
    Wow that is interesting, maybe that article I read a couple years ago is correct.
    sumorus likes this.
  19. Feb 10, 2019 at 1:06 PM
    #59
    toyotatacomaTRD
    Pacific Northwest
    2018 OR DCSB 4x4
    I just hopped under mine. It says Hino mfg and made in Thailand both. No sign of leakage at 4,500 miles.
  20. Feb 10, 2019 at 1:08 PM
    #60
    DwightKSchrute
    DwightKSchrute Well-Known Member
    2017 Magnetic Gray Tacoma TRD Off Road 4x4
    There can only be one!
