2018 offroad read bumper issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Saborman, Jul 20, 2018.
  1. Jul 21, 2018 at 3:00 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Dealership adjusted the bumper covers on mine first, then aligned the bed. I had mine fixed the first week I did it. My dealership is great, dropped it off, said leave it half a day. I got home and they called, said it was ready. They are doing this fix to all the Tacomas on the lot and anyone that needs it. They never knew about the issue.
  2. Jul 21, 2018 at 8:24 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Correct.. you can take the entire rear bumper off the truck and the hitch will still be in place attached to the frame.
    Your bumper looks like it got bumped and now out of alignment. G/L with the dealershit.
    They should fix but I would take a close look at bumper for any possible scuffs where some a-hole bumped into you.
  3. Jul 22, 2018 at 5:21 AM
    Kluckmater
    Kluckmater Hess lodge #93
    Kyle
    Tennessee
    2018 trd off-road quicksand
    Picked my truck up friday and it's is a thumb width on one side and a pinky on the other. Also had a wheels out of balance and one of my raduarad mounts is broke. Brand new truck 4 miles.....
  4. Jul 22, 2018 at 5:24 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Did you not look over your truck before you took it away????
    I definatly would not have left the dealership with that rear bumper looking like that!!!!
  5. Jul 22, 2018 at 5:26 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Common, just fix it yourself the dealer will charge arm and a leg.
  6. Jul 22, 2018 at 5:26 AM
    Kluckmater
    Kyle
    Tennessee
    Man I did but I didn't see it until I got home. And I just happened to catch the broke radiator mount while putting in trd pro grill. I will be on the phone monday and put the "bumper to bumper" warranty to test.
  7. Jul 22, 2018 at 5:29 AM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    I will admit that I totally missed the bumper gap while inspecting mine at the dealer. Mine is off a little bit. This has been brought up in other threads and it seems to be very common. Most people don’t notice or don’t care.
    I’m going to take a look at aligning mine if and when I decide to change to SR black bumper caps. I believe to do this right you need to remove the caps.
    Might want to try and align the box first as that may be easier. I’m just going to live with mine the way it is.
  8. Jul 22, 2018 at 5:34 AM
    Kluckmater
    Kyle
    Tennessee
    It's easy to miss . I use a dealer 4 hrs away cause they "usually" hook me up. So a 4 hr drive and sitting in finance forever cause they wanted to get stupid (10% interest.. they're out of they're minds) I was just ready to go lol
    psmura likes this.
  9. Jul 22, 2018 at 6:11 AM
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
    I fixed my took 30 minute to do it.
    psmura likes this.
  10. Jul 22, 2018 at 6:43 AM
    Dirtridercrf250
    Mine was like this when I got it in 2017 so it may be a lazy worker at the factory.
  11. Jul 22, 2018 at 9:42 PM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    You don’t need to remove the bumper caps. Just the black plastic step piece. Still might be worth waiting and doing the caps and bumper alignment at the same time, but you don’t need to remove the caps to align your bumper.
  12. Jul 23, 2018 at 3:47 AM
    psmura
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Thank you for the info. I was under the impression both had to be removed to access the mounting bolts.
    rsimi72[QUOTED] likes this.
  13. Jul 23, 2018 at 4:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    How is the gap between the bed and the cab?
    If it's wonky there too, it's at minimum a bed alignment issue, but once adjusted, the bumper may still need an adjustment. Or not.
    If only at the rear, it's a bumper issue.
    If your dealer denies it for some silly reason (most don't) or you don't want to spend the time (like you live an hour away from the closest dealer) the bed is easy to align by loosening the 6 bolts in the floor. Couple of people makes it easier.
    Same with bumper, but not 'quite' as easy because it's harder to see when under truck. Although I installed my hitch and re-squared everything by myself lying on the driveway.
  14. Jul 23, 2018 at 4:51 AM
    DirtyD1985
    DirtyD1985 Well-Known Member
    Dain
    2017 White TRD Sport
    Ill have to look for this when I pick up my new OR next month. :fingerscrossed:
  15. Jul 23, 2018 at 11:21 AM
    #35
    rsimi72
    PNW
    Nope. I did not remove the caps when I did mine. Didn’t even consider it as it wasn’t needed. Full access once that plastic step is removed. There isn’t a lot of room to adjust so I ended up moving both sides a little bit (in opposite directions) to get the sides to match. I remember loosening the center portion also to get a little more play. I think the most challenging part was removing the license plate lights. Good luck.
  16. Jul 23, 2018 at 5:10 PM
    #36
    ICU1
    ICU1 Well-Known Member
    After a few drinks, my bumper looks fine
    rsimi72 likes this.
