2018 Pre Collision System Malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by s18_taco, May 20, 2018.
  1. May 21, 2018 at 7:53 PM
    rowsdower
    rowsdower Well-Known Member
    Yeah but it's not like a menu or anything. You just press the cruise control button for 2 seconds to get to the regular (non-radar) cruise control. This video shows what I mean. The second half shows how to do it with the stalk.
    https://www.youtube.com/watch?v=avHSR2Vn58M
  2. May 26, 2018 at 10:11 AM
    s18_taco
    s18_taco [OP] Mall...before crawl.
    Allen
    Central MD
    2018 Cement Grey Off Road
    PCS malfunctioned again. This time I experienced brake issues. Driving 10-15 miles in traffic when brake started doing the ABS shuffle and alerts for PCS, ABS, and BSM popped up. Freaked me out. Truck is at the dealer now for the next several days for a bad sensor. Case was generated with Toyota and I got a loaner. I'll be updated Monday.
  3. May 26, 2018 at 11:26 AM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Feeling bummed about your situation OP. I’m on the other side of the fence and the post above nails the 16D in one blow. I’ve been using the default setting for sensitivity, but recently changed it to the highest setting to see if there would be a difference. There is for sensitivity. First time the system saved my skin it was on default and in freeway stop and go stuff. It was a bit late and the brakes hit somewhat hard. In the most recent mode, being the most sensitive, I was blown away on how it worked in the most recent situation. Since I’ve changed it, a couple of weeks ago, it has worked just like the default setting. With circumstances much like you described, except not being in cruise control. It has only warned me. It never intervened. Well, this past Thursday was a good feel day for the system. I was in stop and go light to light traffic going home from work. At one point, I reached for something as I had my left foot lightly on the brake as we neared a stop light. I drive left foot on brake right on gas. Knowing I was coming to a stop, as I quickly reached over to grab whatever it was, I felt my left foot gentlly depress on the brakes which caused me to look ahead. I didn’t do it, I thought. When I reached over, I was probably about 20’ away from the vehicle. I actually would have expected slamming on the brakes, however, I was not that close to the vehicle in front, I’d say 15’ by the time I was aware of the total situation. I then took control by pressing on the brakes more. As stated above, if the system detects movement in the steering wheel, or pressing of the brake system, TSS will give up control to you.
    Perhaps you can ask the dealer to swap a grill with a different radar?
    s18_taco[OP] likes this.
  4. May 26, 2018 at 12:01 PM
    s18_taco
    Allen
    Central MD
    This is great insight to the system. I’ll see what the response is come Monday. Hoping it’s just a quick sensor replacement.
    Topanga Taco[QUOTED] likes this.
  5. May 26, 2018 at 12:41 PM
    Topanga Taco
    Rick
    Unfortunately there are hiccups to all systems. Overall, the toyota engineers did a good job on the Tacoma, with the exceptions of all known issues described here on the 3rd Gen forum. Not directed at OP as his original question was a different topic, but the thing not to do is to become complacent with driving and expect the TSS to react perfect in every situation. I know, easy to say but hard to do, or sometimes not paying attention to do. :anonymous:
    OP, buena suerte with your truck. Hope all goes well in the end. I’m enjoying this truck more and more as the days go by, most particularly the drivetrain.
  6. May 26, 2018 at 2:19 PM
    s18_taco
    Allen
    Central MD
    Thanks, much appreciated. Once this is resolved, I can be back to enjoying the truck as well.
  7. Jul 10, 2018 at 5:43 AM
    guntotingmexican
    guntotingmexican New Member
    Curious to know if the dealer was able to solve your problem? I'm experiencing a very similar thing in mine, it started just a few days after getting my truck new. I've had the PCS Malfuction warning and the Clean Sensor warning even though the sensors appear clean. It happens almost every time I drive.
    s18_taco[QUOTED][OP] likes this.
  8. Jul 11, 2018 at 5:56 PM
    s18_taco
    Allen
    Central MD
    I had a bad hub seal that caused the malfunctions. Toyota replaced the seal, speed sensor, and hub assembly. Everything has been fine since then.
  9. Jul 16, 2018 at 12:57 AM
    TylerRod
    TylerRod New Member
    My truck has had the same alerts for a little over a week now. I don’t have the ABS alert just the pre collision system malfunction alert and as of this morning the lane departure malfunction alert came up. Dealership already tried to calibrate it and couldn’t so they’re ordering a new sensor. Think that will solve the issue since those are the only 2 alerts I am getting?
  10. Jul 16, 2018 at 1:30 AM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    For those experiencing problems, I think it’s worth mentioning if your grille is an untouched OEM that came with your truck or if you changed it to say a PRO grille and if you did, whether you are using an OEM garnish or fabricated your own and/or if you have a lift but have not recalibrated the sensor...this would help because there are some ding dongs on this forum who have Mickey Moused their garnish for looks or cost savings but don’t get the concept of sonar deflection. I am not saying this is the case here with anyone who has posted in this particular thread, but it does help when getting and looking for feedback from members on probable causes.
  11. Jul 16, 2018 at 2:16 AM
    s18_taco
    Allen
    Central MD
    I think a new sensor might be what is needed. Hopefully it pans out.
  12. Jul 16, 2018 at 2:18 AM
    s18_taco
    Allen
    Central MD
    Good mention on this.
  13. Oct 1, 2018 at 2:21 PM
    Mr12voltz1
    Mr12voltz1 New Member
    Angel
    2018 Tacoma TRD Sport
  14. Oct 1, 2018 at 2:28 PM
    Mr12voltz1
    Angel
    This is a known issue. The sensor isn’t sealed very well. So water gets in the sensor and damages it. The dealer had replaced mine 2 times already. And it’s doing the same thing again. So you know I only have 2800 miles on my truck. I’m on my 4th repair for this issue. Can we say lemon law time. This is so disappointing. I bought the truck because of the safety system. I should have bought the Honda Ridge Line instead. I feel I made a big mistake.
  15. Oct 1, 2018 at 2:40 PM
    #35
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    Really...wrong forum to be saying that.
    I find that hard to believe that you have had 3 bad sensors!
  16. Oct 1, 2018 at 4:21 PM
    #36
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    The Honda Ridgeline is essentially a minivan with 4wd. Be sure to grab a box of maxi pads when you buy it. You can even name your new Honda the “Vangina.”
  17. Oct 18, 2018 at 2:53 PM
    #37
    Mr12voltz1
    Angel
    Yes. Now I’m up 4 sensors and replacement of the harness. Now the connector to the sensor. This is a nightmare 3200 miles on the truck.
  18. Nov 1, 2018 at 4:24 PM
    #38
    InbredRoss
    InbredRoss Member
    Ross
    2018 Barcelona Red Tacoma TRD offroad DC
    this thing is brand new
    i had the problem the first time at 2000 miles. they replaced the PCS computer. its been fine till this week. 3500 miles and its doing it again. Im going monday to try again. I ve got an Icon stage 10 kit, SCS Ray10s, and new geolanders sitting in the shop. im scared to lift the truck because that will be their reason for it not working. im livid.
  19. Nov 1, 2018 at 4:30 PM
    #39
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  20. Nov 20, 2018 at 1:44 PM
    #40
    JBW1975
    JBW1975 Member
    2018 TRD off road dbl cab &1997 Tacoma Xtra cab 4*4 3.4L
    None
    My truck started turning PCS off and back on randomly at 4400 miles. It might would go 20 miles without incident and then when it started it would do it 10 to 15 times in a 3 mile stretch of road. Took it to dealership and showed a video of it happening to them and they replaced the sensor behind toyota emblem and the harness plug in. 300 miles since fix and haven't had it happen again.
