2018 Tacoma battery life
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djgynee, Sep 26, 2019.
  1. Sep 27, 2019 at 8:11 AM
    bern_10
    bern_10 Active Member
    Brendon
    Spokane, WA
    2017 Tacoma TRD Off Road
    OV Tune, cali raised rock sliders, 12v power outlets and usb in bed cubby, , Group 27 battery with monitor and solar port for charging, Bed lights, pop n lock for tail gate,
    2017 Tacoma, stock battery, 24k miles
  2. Sep 27, 2019 at 8:55 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    2016 51k miles. Lives outdoors never and garaged once. Still going :notsure:
    GreyBaldTaco and SmoPo16 like this.
  3. Sep 27, 2019 at 9:31 AM
    Tacospike
    Two Trucks
    2016 battery died after 15 months at a car wash. Luckily auto zone was a half mile a way, still a pain to carry a battery both ways
    BSFord and shakerhood like this.
  4. Sep 27, 2019 at 10:12 AM
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    My OEM battery lasted about 18 months. Dealer refused to warranty it because I have “too many accessories.”
    They disregard the fact that everything is running off the second battery and only connected with an ACR. :frusty:
  5. Sep 27, 2019 at 10:18 AM
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    The original battery in my '16 is still going. 70,xxx miles later
    Navigator1 likes this.
  6. Sep 27, 2019 at 1:42 PM
    djgynee
    djgynee [OP] Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    i could be wrong but Southern California specifically the inland valleys has a lot more sunny/ excessive heat days. For about 4 months we rock 90-110 degrees.
    although supposedly the extreme cold does the same.
  7. Sep 27, 2019 at 1:43 PM
    djgynee
    Southern California
    I do believe he went to the Interstate Factory where they displayed an car battery at 7 different stages of Deterioration
    Well this thread is getting good helpful feed back
  8. Sep 27, 2019 at 1:45 PM
    djgynee
    Southern California
    Now this is getting interesting. :popcorn:
  9. Sep 27, 2019 at 1:48 PM
    ChrisH06
    ChrisH06 Member
    Christian
    South Orange County, CA
    2018 DCSB TRD Sport 4X4
    My battery just died today. 2018, 21k miles.
  10. Sep 27, 2019 at 1:58 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    2016, 22k miles, garage/2 amp battery tender, not daily driven, stock battery is showing a little discharge around the ground post but works fine.
  11. Sep 27, 2019 at 5:39 PM
    kullin
    kullin Well-Known Member
    Scott
    Denison Tx..
    2015 Toyota double cab
    None Yet :)
    Toyota like any manufacturer goes to battery manf. and requests bids for batteries from companies at a specific price point... Companies build these batteries cheap to get the bid hoping they will make the warranty period just like the do at Walmart.. Johnson Controls also makes Walmart Batteries and many others under different names..
    BSFord likes this.
  12. Sep 27, 2019 at 6:59 PM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Where did you find this tidbit?
  13. Sep 27, 2019 at 7:00 PM
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    This is an accurate statement.
  14. Sep 27, 2019 at 7:05 PM
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    Your "discharge" is probably due to the tender. Hope you don't leave it on all the time. The battery simply needs to be topped off then the tender should be removed.
  15. Sep 27, 2019 at 7:06 PM
    #35
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    "All" is a pretty strong statement, but not too out of line.
  16. Sep 27, 2019 at 8:20 PM
    #36
    FRE1809
    FRE1809 Well-Known Member
    Long Island,N.Y. ; USN ( Ret.)
    It was in the news this past summer.
  17. Sep 27, 2019 at 8:58 PM
    #37
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    My truck didn’t start today. It was a bad negative connection (just had to clean the terminal) but i’m at a year and a half in in SoCal. Might need to keep an eye on this. Sadly, my job doesn’t really allow for being late or time off
  18. Sep 28, 2019 at 3:18 AM
    #38
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Is the stock charging system adequate for an AGM battery?
  19. Sep 28, 2019 at 5:46 AM
    #39
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    Yes
    shakerhood likes this.
  20. Sep 28, 2019 at 7:37 AM
    #40
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I thought the whole idea of a tender was to maintain a battery when it's not in use for some extended period, not simply charge it. Leakage around a post is due to gases escaping because the seal has become compromised which can happen for many reasons including manufacturing defect, heavy vibration or other mechanical stresses on the terminal such as beating the connector on with a hammer. These failures are usually covered under warranty without much resistance by the retailer.
