2018 Tacoma battery life
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djgynee, Sep 26, 2019.
  1. Sep 28, 2019 at 10:27 AM
    #41
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Lol, lied. Battery was done on my 2018. 40,000 miles and daily driven only. No accessories and stock radio
  2. Sep 28, 2019 at 12:10 PM
    #42
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Yeah, and the tenders usually have automatic float mode so it doesn't over charge. I had the same tender on my motorcycle for about 2 years without issue. It has the original 10 year old battery. I would not be surprised if vibration was the cause of my ground terminal getting loose. It's definitely not because of the tender.
  3. Sep 28, 2019 at 12:51 PM
    #43
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Works fine for mine Sams club AGM
    Funny it is not listed on the web site but they stock the right one in the store, $161 total
    24F-AGM Group Size 24F 710 CCA
    shakerhood likes this.
  4. Sep 28, 2019 at 1:37 PM
    #44
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Not a third gen owner, but I returned an Interstate to Costco a while back that only went a couple years in my wife's car. They replaced it, and lo and behold the second one started to crap in a year and a half. I looked inside, and it was pretty low on water. I capped it off with distilled water and charged it up, and it's been fine for about 5 months so far. I wonder if they are just spitting them out so fast, the water level is low and they aren't fully charged?
  5. Sep 28, 2019 at 5:50 PM
    #45
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    The problem with most tenders is that they continue to push power into an already charged battery. I agree with the seal failure possibility and it has been my experience that the gases produced from constant over charging escape via the path of least resistance. As far as warranty coverage is concerned, that's outside of my area. Most tenders are simple and cheap with little over charge protection. A decent brand is a Ctek.
  6. Sep 28, 2019 at 7:04 PM
    #46
    Mayonayze
    Mayonayze Well-Known Member
    Mine lasted around 50k. When it died, got a bigger/better battery. All good!
  7. Jan 18, 2020 at 12:23 PM
    #47
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    My '05 battery lasted 7 or 8 years. '18 battery 15 months, same usage. MIL's '16 RAV4 looks about ready for it's 3rd battery...
    How does the Toyota reimbursement work? I'd rather source my own battery this time.
    My '97 could sit for a month in the winter and start without drama. Looks like another Plus in the "1st Gen-Best Gen" column.
  8. Jan 18, 2020 at 12:41 PM
    #48
    dljohndrow
    dljohndrow Well-Known Member
    Dave
    2025 Tacoma TRD
    My 2018 sets in my driveway and gets started once a week at the most. Battery is still going strong.
  9. Jan 19, 2020 at 8:47 AM
    #49
    IkemanTx
    IkemanTx Well-Known Member
    Isaac
    2017 4X4 SR5 Tacoma
    I must be livin right...
    my ‘17 Tacoma is still runnin like a top on the original battery at 55,000 miles.
  10. Jan 19, 2020 at 9:28 AM
    #50
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If your current battery goes bad when the dealerships are closed or during an emergency you can buy a replacement and send the receipt to Toyota, the address is in the manual.
    oconnor[QUOTED] likes this.
  11. Jan 19, 2020 at 9:53 AM
    #51
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    Bought my truck in January of 2016. About two months ago, I went out to go start it to go to work, and nada. Thought maybe I left a light on or something, so I put the charger on it for several hours, voltage was still down around 10v.
  12. Jan 19, 2020 at 11:32 AM
    #52
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Does the 3gen alternator charge around 14.3 volt???
  13. Jan 20, 2020 at 3:21 PM
    #53
    jerkwithkeyboard
    Nope. but there is a mod that you can do to change that. i haven't but its in hear somewhere how to do it.
  14. Jan 20, 2020 at 3:30 PM
    #54
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I thought that was 2gen only since voltage is regulated by the ECU on the 3rd gens.
    MGtaco2.7 and 714reyesj like this.
  15. Jan 20, 2020 at 4:01 PM
    #55
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    So, unless you do the mod it won't fully charge a AGM battery? Definitely shortens the life of a AGM battery then.
  16. Jan 20, 2020 at 4:04 PM
    #56
    danmtchl
    danmtchl Well-Known Member
    Dan
    Bakersfield
    2019 Tacoma TRD Double Cab Sport 4x4
    My wife’s old 2006 Impala SS, needed a battery every year in July for some reason, usually when it’s well over 100 degrees outside
  17. Jan 20, 2020 at 7:53 PM
    #57
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Heat is harder on wet cell batteries than sub zero.
  18. Jan 20, 2020 at 7:58 PM
    #58
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    What mod are you referring to? The only mod I'm aware of for 3gens is a new alternator. Unless I missed a thread somewhere. And yes, if your alternator is not putting out sufficient voltage, this can shorten the life of an AGM. A monthly (or after a significant discharge) top off with a proper charger/maintainer will mitigate that.
