2018 Tacoma overheating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MORTBIKE, Sep 8, 2020.
  1. Sep 11, 2020 at 7:06 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yes. There's a reason places like death valley have signs telling you to shut off your AC for the next 20 miles or so. Granted, it more applies to older or larger vehicles, but we don't live in a world where we can defy physics.
  2. Sep 11, 2020 at 7:08 AM
    RedWings44
    Michigan
    Not to mention come here to complain about their problems to see if anyone has had similar experiences or hopefully find a solution.
  3. Sep 11, 2020 at 7:17 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ambient temps WILL have a Direct effect on running temps
    that needle gauge has a broad range
    the engine is going to have diff temp ranges when ambient temps are 80....95......over 100 degrees
    if its the same run each day & U have checked it out........fluids are up no worries
    if U r passing thru keep an eye on gauge
  4. Sep 11, 2020 at 8:11 AM
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    The operating temperature zone on the gauge has a range for a reason. If the needle isn't going into the red or the engine isn't overheating (spewing coolant) then its probably working as designed.
  5. Sep 11, 2020 at 8:19 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    I have a 2020 pro was running warmer then what I liked. I installed a 180 degree stat. Problem solved. However I do not live in a real hot climate area. [NY LOL.] But I noticed this summer when temps got up to 95, temp gauge would climb. When I hooked my scan tool up when engine temp was climbing temp was 224, to hot for my liking. Engine runs hot enough to go into closed loop now. Per scan tool never goes over 205 after stat replaced.. So for now I am leaving it as is.
    Big tall dave likes this.
  6. Sep 11, 2020 at 8:37 AM
    ROAD DOG
    FEW
    224 is toooooooo hot
    the driving environs ?????
    ambient temps
    engine load
    towing
    terrain
    all or a combination can raise the operating temps
