2018 Tacoma SR5 V6 oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phoenixpiole, Oct 7, 2018.
  1. Oct 7, 2018 at 8:00 PM
    phoenixpiole
    phoenixpiole [OP] Well-Known Member
    2018 Tacoma DCSB SR5
    Hi All,
    I just completed my first on change on my 3.5 V6 Tacoma and I’m wondering if any of you have had a hard time getting the correct amount of oil back in the engine. My truck has the tow package thus the manual calls for 6.2 quarts with filter however I’m finding I have to put in 6.3qts to get just below the full line on the dipstick which I find strange. I swapped the oil filter housing for an aluminum one so I don’t know if that’s what’s causing it to require slightly more or not or if perhaps residual oil is lingering in the valve train and / or filler neck and the small adjustments are just not showing up on the dipstick.
    Here’s what I did step by step:
    1. Completed the oil change, completely drained oil from the pan and filter housing and replaced filter and reinstalled the drain plug
    2. Refilled oil with 6 quarts to start with, started and ran the engine to operating temp and shut down, removed the dipstick and allowed the oil to drain back into the sump
    3. Checked the oil level and it read about a third to a quarter of a quart low.
    4. Added .2 quarts per manual recommendation and found the leve was still slightly below full, did not restart the truck at this point.
    5. Added .1 quarts and the dipstick is now reading right at full maybe marginally less than full.
    I’ve double checked and triple checked for leaks and I can’t find anything, maybe I’m being a bit OCD about it but if the manual calls for 6.2 quarts that’s what it should be exactly. Right???
    What do y’all think? Please share your experiences.
    Side note: I allowed the dipstick tube to drain back with the dipstick removed for 10 minutes or longer each time before rechecking the oil level thus the oil isn’t wicking up the tube or causing false readings, I’ve read folks having problems with this in the past but that’s for another discussion.
  2. Oct 7, 2018 at 8:13 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I use 6.2 and its all good, I usually wait till the next morning to check oil to give everything time to settle.
  3. Oct 7, 2018 at 8:16 PM
    Stitaco
    Stitaco Member
    Phoenix,Az.
    18 Trd off road
    None
  4. Oct 7, 2018 at 8:17 PM
    phoenixpiole
    Thanks for the quick response, yeah I’ll check it out tomorrow morning and see where it ends up, if anything I’ll be barely over.
    shakerhood[QUOTED] likes this.
  5. Oct 7, 2018 at 8:18 PM
    phoenixpiole
    Yeah it’s a Toyota OEM part, doesn’t appear any larger than the plastic one that was on there.
    shakerhood likes this.
  6. Oct 7, 2018 at 8:26 PM
    Stitaco
    Stitaco Member
    Phoenix,Az.
    18 Trd off road
    None
    That’s good then- don’t worry about the level just put the 6.2 that the manual says. I manage a Express maintenance department that services at least 500 Toyota vehicles a week and have been to class with Toyota instructors that informed us about the 0w20 oil. Actually the Tundra with the 5.7 calls for 7.9 quarts but when we pull dipstick it usually shows it being slightly low but we leave it alone
  7. Oct 7, 2018 at 8:29 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You're being really picky, in reality if the oil is within the low and full hash marks it's fine. Half a quart won't make any difference.
  8. Oct 7, 2018 at 8:59 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I would put in the recommended amount, run it and then check when cold. You will probably find it closer to correct. But, the engine could care less with a tenth of a quart missing.
    phoenixpiole[OP] likes this.
  9. Oct 8, 2018 at 5:59 AM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    6 quarts and your good. No need for .2 quarts honesty. As long as it’s between the hash marks you’re fine.
    usmc2msu, trazerr and Beer:30 like this.
  10. Oct 8, 2018 at 6:13 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Yep, this right here ^^^^^
    6 qts and call it good.
  11. Oct 8, 2018 at 6:51 AM
    phoenixpiole
    This is probably going to sound overly paranoid but would there be any issue with there being 6.3 instead of 6.2 quarts in there?
  12. Oct 8, 2018 at 6:53 AM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    No
  13. Oct 8, 2018 at 6:53 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    OP, you are overthinking this.
  14. Oct 8, 2018 at 6:58 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    I like living on the edge I only put 6 quarts of oil back in and not 6.2 :mudding:
    suaveflooder and Bowhuntercoop like this.
  15. Nov 29, 2018 at 12:25 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    For anyone doing there own... a trip to local toyota parts for 2 OEM filters, crush washers, 64mm filter housing cup wrench, and 7 quarts of oil was $59.
    Pricing out the same on Amazon was $89.
    Plus I don't have to wait 2 days for shipping.
