2018 Tacoma TRD sport 102,000m blown engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTacoTuesday, Jan 25, 2025.
  1. Jan 25, 2025 at 10:42 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    https://www.tacomaworld.com/threads/need-assistance-locating-radiator-fan-relay.813750/
    t0p_d0g and Jesse H like this.
  2. Jan 25, 2025 at 10:43 AM
    Vinman02
    Vinman02 Well-Known Member
    Vince
    2019 Tacoma TRD
    Levelling kit
    There’s no way the previous owner did any damage to the engine that would last another 88k miles before self destructing. If there was a pre-existing issue when the OP purchased the truck it would have shown itself long before 102k miles on it.
  3. Jan 25, 2025 at 10:44 AM
    TacoTacoTuesday
    TacoTacoTuesday [OP] Member
    Jordi
    2007 Tacoma 2.7L
    Yes plenty of engine oil. No leaks and I had just had trans fluid + oil change 2k miles ago. And i had all the other fluids checked by dipstick and if the guys dont like what they see they change it or send it in. Like I said I really was trying to make this thing last.
  4. Jan 25, 2025 at 10:46 AM
    TacoTacoTuesday
    Jordi
    2007 Tacoma 2.7L
    I didn't know that, i thought the 2016+ were all manufactured in Mexico thanks for info.
  5. Jan 25, 2025 at 10:47 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Trucks are assembled in Mexico, but the parts come from all over. The 2GR-FKS comes from Alabama and I believe maybe one other location but I think Alabama is the primary location. I don’t recall.
  6. Jan 25, 2025 at 10:52 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    If you actually do oil analysis with Blackstone and pay extra for TBN testing you'll find that for many users skipping a 5k mile oil change (OP's stated intervals) won't be pushing things considering 10k miles is well within factory recommended intervals.
    My truck under extreme conditions (short trips and cold starts) is still good for 7k miles.
    So back to what I was saying, a few neglected oil changes won't lead to catastrophic failure and similarly excessive oil change intervals won't prevent catastrophic engine failure if during the assembly process there was a part that wasn't installed correctly or machined properly or a mistake occurred in the casting process etc.
    Fresh oil is good maintenance but it takes a lot of neglect to cause failure.
  7. Jan 25, 2025 at 10:54 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    High trans temp is the default message when the engine stalls. Software quirk. I had a Volant intake tube coupler fall off the throttle body 7 times over two wheeling trips; each time the engine stalls from the gross vacuum leak, the high trans temp message appeared. 99 problems but at least your transmission ain't one.
    Most likely cause is oil leaked out from an improperly installed/damaged filter cap. An "old timer" mechanic may not handle the cartridge filter design delicately. It doesn't take much torque to tweak the plastic and cause a slow leak. I'm on my third filter cap. How much oil was in the engine when it failed?
    Canadian Caber likes this.
  8. Jan 25, 2025 at 10:55 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  9. Jan 25, 2025 at 10:56 AM
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
  10. Jan 25, 2025 at 10:58 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    BillF1564 and Canadian Caber like this.
  11. Jan 25, 2025 at 11:01 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Your engine should not have detonated that young, but it did. It's not a reflection on how you took care of it or how it was built. Car engines are pretty complex little buggers and sometimes shit happens. Good luck getting it repaired
  12. Jan 25, 2025 at 11:01 AM
    TacoTacoTuesday
    Jordi
    2007 Tacoma 2.7L
    I don’t think that did it for me this time but will update when full teardown is done. I live in a very cold climate + always check oil temps when driving on the gauge. This was very sudden with no previous issues or failures. But I’m not an expert I was just trying to be meticulous with maintenance and care.
  13. Jan 25, 2025 at 11:04 AM
    TA2016
    Oregon
    Yes, very true for engine and powertrain. Just clarifying for the OP in post #24 that there was a time when some 3rd Gens were assembled in Texas.
    TacoTacoTuesday[OP] likes this.
  14. Jan 25, 2025 at 11:28 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Any part any time can fail . Unfortunately if it’s the wrong type of part that falls off and drops into the wrong part of the engine , any engine from any company will self destruct . Just like I have seen parts fail that fall into a corner somewhere and because of that nothing happens except that part being broken
    Total luck of the draw. I also seen parts drop into bad places of a running engine and literally miss everything and end up in the oil pan
    Chew, na8rboy and Canadian Caber like this.
  15. Jan 25, 2025 at 11:39 AM
    #35
    Burrrr
    Burrrr Well-Known Member
    KY
    2017 DCSB TRD Sport
    All modifications below: FUNCTIONAL: LINE-X Undercoating Alu-Cab Contour Canopy ICON Stage 3 Suspension Kit (Tubular UCA) Prinsu Cab Rack Prinsu Top Rack (Mounted to Contour Canopy) Prinsu Rack 44" Side Rail WeatherTech DigitalFit Floor Liners (Front and Rear) Victory 4x4 Armrest Interior Molle Panel (VTCCIMP-3G-PC) Cali Raised Bed Molle System (Rear Panels; Both Sides) Vantrue N4 Pro 3-Channel Dash Camera (Hardwired) WHEELS/TIRES: SCS BR6 17x9" -38mm Nitto Ridge Grappler LT285/70R17 C 116/113Q LIGHTING: Diode Dynamics SS3 Max (Yellow SAE) Fog Lights Diode Dynamics Stage Series 30" Stealth Light Bar Kit (White; Driving Optic) Diode Dynamics SL2 Pro High Beam LED Lights Diode Dynamics 921 XPR LED Reverse Lights Diode Dynamics HP5 LED Map Light (x2) Diode Dynamics SMF2 LED Vanity Light (x4) Baja Designs LED Dome Light RovrLab Baja Designs Flush LED Dome Light Conversion AUDIO: Receiver/DSP: Sony XAV-9500ES Speakers (Powered by JL Audio JD400/4): Kicker Tweeters (Subaru Part # H631SFJ101) Kicker 46CSC6934 (Front Doors) Kicker 46CSC674 (Rear Doors) Subwoofer (Powered by JL Audio J2 500.1): JL Audio SB-T-TACDCG3/10TW3 (Stealthbox)
    Wow if you were only covered up to 100K that'd have been some absolute dogshit luck. Glad to hear you're covered up to 110K. Hopefully it all gets taken care of swiftly and you come out of this in a better position than before it all happened.
  16. Jan 25, 2025 at 11:41 AM
    #36
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Ohhh I hate these types of threads as this could be any one of us. Unfortunately luck of the draw. The rest of us can take comfort in that these engines and transmissions are generally proving to be very reliable due to the sheer number on the road. Approximatly 1.8 million 3rd gens were produced. Reports of many over 200-400K miles. Not all were 3.5L tho.
    My then new 1992 3.0 blew head gaskets twice. Both in and out of warranty. Covered by Toyota both times. Truck still went on to serve me very well and reliably for 14 years.
    OP, hopefully they quickly get to the bottom of this and have either a repair or replacement asap.
    mfalbojr, RustyGreen and Chew like this.
  17. Jan 25, 2025 at 11:59 AM
    #37
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    I get few missed oil changes will not cause catastrophic engine failure. But Op Tacoma has 102k miles, something cause major engine failure.
  18. Jan 25, 2025 at 12:18 PM
    #38
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It sounds like an unfortunate mishap sorry for your problem hopefully it will get repaired under warranty without any expense to you.
  19. Jan 25, 2025 at 3:43 PM
    #39
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    29k in repair bills? I’m going to call BS on that one.
    Jsevert2023 and STEELeR43 like this.
  20. Jan 25, 2025 at 3:48 PM
    #40
    BLtheP
    Plano, TX
    18k of that was for an engine.
