2018 Tacoma TRD sport 102,000m blown engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTacoTuesday, Jan 25, 2025.
  1. Jan 25, 2025 at 3:56 PM
    #41
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    In my 32 years as ford engine mechanic, never seen an overheat cause severe catastrophic internal bearing, piston, or any metal parts that would been imploded causing metal debris through the engine / oil system to get sucked up into oil filter pleats....
    Lots of questions need to be answered, but your statement is a reach......
    STEELeR43 likes this.
  2. Jan 25, 2025 at 4:12 PM
    #42
    eurowner
    eurowner Duke Sky
    Scoty
    How are you reading engine oil temperatures?
    IIRC, the V6 doesn't have an engine oil temp-sending unit.
    3JOH22A and Chew like this.
  3. Jan 25, 2025 at 4:55 PM
    #43
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    More likely in severe overheating, blown head gasket, crack cylinder head, cracked engine block, engine oil white, oil looks like chocolate ice cream.
  4. Jan 25, 2025 at 5:01 PM
    #44
    slater
    San Diego
    Lets wait for the outcome, if we ever in fact get updates to the end of the saga....
    If I were him & theres no red flags that the writer, manager, tech, shop foreman can easily make him aware of prior to authorizing any teardown....
    theres no reason to not push forward with the teardown, its normal warranty protocol....
    In order for the tech to get toyota to authorize an engine replacement, need to be torn down to determine cause, extent of damage, what's needed to be replaced to repairs, toyota evaluates cost cap & if repair exceeds a set limit or if damage is extensive, Mr Tacotuesday gets a nice rebuilt long block....
    Win!!!!
    Do some maint while theyre in there, hoses, belts, etc.....
    Have a nice day...
    Chew and Fireball 00 like this.
  5. Jan 25, 2025 at 6:59 PM
    #45
    Fireball 00
    Fireball 00 Mountain air is the bomb, where’s my wax?
    Ga
    2023 V6 4x4 Db cab celi-silver taco, 00 taco 2.7 4wd auto (aka.rusty-taco..R.I.P), 03 2.7 auto prerunner project!
    Hope this pans out for TTT, & I hope he has a good update soon too for us! Now seeing stories like this with low miles makes me kinda gun shy/edgy you know, I just recently bought a 2023 3.5l and I just turned 19.5k on her…..
  6. Jan 25, 2025 at 7:18 PM
    #46
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    2017 122,000 miles says:puke:
    BillF1564 likes this.
  7. Jan 25, 2025 at 7:19 PM
    #47
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    There are so many variables here . It wasn’t bought new by the OP. Who knows what the first owner did
    Even though it was bought at a dealer you never really truly know. Something could have happened that compromised something, and 85 k later they item failed . Was the truck tuned ? Did the oil filter leak from an oil change and the dealer put everything back and told the first owner everything was fine ?
    Again who knows
    mikesixtysix, Chew and Fireball 00 like this.
  8. Jan 25, 2025 at 8:54 PM
    #48
    Fireball 00
    Ga
    Yeah, I’m feeling ….ditto!
  9. Feb 9, 2025 at 9:33 AM
    #49
    TacoTacoTuesday
    TacoTacoTuesday [OP] Member
    Jordi
    2007 Tacoma 2.7L
    Update:
    What Happened:
    My engine failed due to what the dealership confirmed was a manufacturing defect. The he had their lead mechanic and Toyota Warranty sent separate inspectors:
    They said the piston on Cylinder 4 stiffened up and started rubbing against the engine block, leading to failure.
    I have always been meticulous with maintenance, so this wasn't due to neglect no overheating, no oil starvation, and regular service was done on time (had to send them 42 scanned pages of receipts)
    Warranty Coverage & Repairs:
    The repair is fully covered under warranty.
    Instead of replacing the entire engine, the dealership is doing an on-site rebuild with a new engine block and necessary internal components.
    Big issue: I have no ETA on parts, so I don't know how long it’ll be without my truck.
    Questions I Have:
    1.Possible Causes? Since the dealership confirmed it was a manufacturing defect and not maintenance-related, what could cause a piston to seize like this?
    2.What Maintenance Should I Do Now?Since the engine is already out, I asked the mechanic what else might be worth replacing while labor is low. Heres what I’m considering:
    Cooling System: Water Pump, Thermostat, Radiator Hoses
    Engine Accessories: Serpentine Belt, Tensioner, Motor Mounts
    Seals: Rear Main Seal, Exhaust Manifold Gaskets
    Transmission & Drivetrain: U-Joints, Transmission Mounts
    Fuel System: Injectors, Fuel Rail Cleaning
    Exhaust System: Inspect and replace anything needed
    Anything else worth doing while it’s apart?
    3.Any Advice on Dealing with Delays?
    I don't have an ETA on parts. Has anyone dealt with this before? Should I push the dealership for a loaner?
    Any insight would be appreciated!
    Fireball 00 likes this.
  10. Feb 9, 2025 at 10:16 AM
    #50
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    The piston “stiffened up”? Must be a Toyota technical term. Curious what the manufacturing defect was, and how this caused the failure.
    As for other repairs/replacements, maybe that rear coolant pipe. Toyota may not be too keen on other misc (customer requested) repairs, unless recommended by the tech. IDK
  11. Feb 9, 2025 at 10:29 AM
    #51
    TacoTacoTuesday
    Jordi
    2007 Tacoma 2.7L
    Im also curious what this mean exactly, but that’s what written on the report I have access to. I’m trying to figure out if they will let me speak to the tech directly.
    I’m going to pay out of pocket for extra services that I mentioned above. To hopefully future proof my truck for another 100k
  12. Feb 9, 2025 at 10:54 AM
    #52
    Fireball 00
    Ga
    yeah, if it’s possible I would do the same things ….I'm just weirded out about the whole (stiffened)/ seized up piston thing at 100k that basically thrashed the cylinder wall. It’s good though the dealership is fixn it sucks on no e.t.a though. Keep up the updates though I’m deff watching this one…
    Chew likes this.
  13. Feb 9, 2025 at 11:04 AM
    #53
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It just so happens, that I speak bullshitees, so I can translate for you: "we don't know, but cylinder 4 is bad"
    eurowner, CB350G, RustyGreen and 2 others like this.
  14. Feb 9, 2025 at 11:19 AM
    #54
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    It means: wrist pin bushing failed. If it's bad enough, it will break the connecting rod at the small end. Might have happened if the connecting rod was initially installed backward.
    eurowner, Fireball 00 and t0p_d0g like this.
  15. Feb 9, 2025 at 12:25 PM
    #55
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Just a little tidbit of info; Toyota does not sell long block assemblies and has to pretty much be pieced together. I hope the Hell you get a good tech to assemble the engine!
  16. Feb 9, 2025 at 3:39 PM
    #56
    TacoTacoTuesday
    Jordi
    2007 Tacoma 2.7L
    I guess there’s only one tech in my area that can do this and the dealership that I towed it to had guy with the right skills & experience. But yeah that is a concern that I have. I’m praying
    Fireball 00 and Delta09[QUOTED] like this.
  17. Feb 9, 2025 at 4:24 PM
    #57
    mikesixtysix
    mikesixtysix Well-Known Member
    North Jersey
    2018 TRD Pro
    good thing its covered, that's a relief. i wonder what the cost of a new motor is, versus a rebuild, versus finding a used one to drop in
  18. Feb 9, 2025 at 4:39 PM
    #58
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    As others have mentioned, “new motor” isn’t really a thing. You can get a short block for 3500, heads for $1200 a piece, cams, valves, followers, etc, but there is nothing to buy to make it all new. So I guess the cost of new would be the sum of all the parts you’d want to be new. Used motors with reasonable mileage seem to be around 3-6K. Rebuilt motor isn’t really a thing, unless say you replaced the block but kept the heads or something like that. Most reused parts are reused as is, if they need any amount of fixing they are usually replaced.
    mikesixtysix[QUOTED] likes this.
  19. Jun 26, 2025 at 3:20 AM
    #59
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    I would wonder if a wrist pin retainer failed to keep the wrist pin in place.
