2018 Tacoma TRD Sport Magnaflow Stainless - Falken AT3W - Dobinson GTS 2" Lift
Discussion in 'Product Reviews' started by Mack7n, Jan 20, 2019.
  1. Jan 23, 2019 at 4:00 PM
    Coolbeverage73
    Coolbeverage73 Well-Known Member
    Kevin
    2019 Tacoma OffRoad in Quicksand
    This is a great post....I know this may be pushing it but since budget is front of mind for most guys can you list out of pocket costs for each project: exhaust, tire upgrade, and suspension? Thanks
    eevaldes likes this.
  2. Jan 23, 2019 at 4:46 PM
    Mack7n
    Mack7n [OP] Well-Known Member
    Josey
    Old Town, ME
    2018 Tacoma TRD Sport DCSB 6M BBP/2018 T4R TRD Pro Calvary Blue
    Good call, I'll add it right now.
    **Prices added. Friend I gave $200 to do it, as well, he's dating my little sister, and it helps em**
  3. Feb 7, 2019 at 7:45 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Wish I had known about the GTS suspension before I bought the 5100s. Looks like I'm switching out after the summer....
  4. Feb 7, 2019 at 3:26 PM
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    What coils did u go with to get the 2”?
  5. Feb 7, 2019 at 3:28 PM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    They come with coils specific to the set.
  6. Feb 7, 2019 at 3:40 PM
    JARStacoma
    Alaska
    On their site each set has a specific lift height based on load. I am curious since he looks like he is stock up front what size coil he went with.
    C59-314 says 2” med load put to 100 lbs. 3” lift stock.
    C59-302 says 1.6” light load.
    I am thinking 314 as I have sliders but that’s all. I would like at least 2” but def. don’t want 3”.
  7. Feb 7, 2019 at 3:50 PM
    JARStacoma
    Alaska
    Ok. I see that if you order the kit, as you said, whatever coil they include should give the 2”’s. I was just curious what that coil was. Thanks.
    CoastieRon likes this.
  8. Feb 7, 2019 at 7:39 PM
    Mack7n
    Josey
    Old Town, ME
    I went with stock weight (as I have no plans right off to adding anything for weight in the front) if that helps.
  9. Feb 7, 2019 at 7:54 PM
    JARStacoma
    Alaska
    Thanks. Just trying to figure it all out. It says on the dobinson sight that stock weight springs only give 1.6”. Moving up to next coil to medium it says 2” with 50-100lbs. I do have sliders and wonder how much weight that ends up being up frontsince the sliders are not all in the front.
    How are the blocks in the rear? Any issues? Ride quality?
    Thanks for the feedback.
  10. Feb 7, 2019 at 8:46 PM
    Mack7n
    Josey
    Old Town, ME
    I don't believe these are straight from Dobinsons Site, as far as the coils. They're from Mainline Overland. I did get a 2" lift in the front w/whatever the springs are they sent me (part of their Kit) @eevaldes might have a better answer as far as that goes. I wouldn't worry about the sliders, as it's even weight, and doubt it'd effect much. I'm thinking more of Bumper, Winch, etc on the nose of the truck being the bigger culprit here.
    Blocks are tapered so it tips the rear end up a few degrees to take the harsh angle off the drive shaft. 0 issues so far. No vibrations anywhere, smooth as all can be driving. Ride quality is a mix of Sport and Offroad IMO. It definitely soaks up the bumps much more than the sport does, but has the nice stiffness the sport has in corners vs sport/pro (my 4 Runner Pro leans in corners, vs my Tacoma not so much) I took a 58 mile trip the other day, all Back Logging Road here in Maine, ice/snow covered dirt roads. I enjoyed every bit of it (remember, I'm on 10ply tires also, so they're less forgiving than 4/6ply tires, and heavier too).
  11. Feb 7, 2019 at 9:40 PM
    JARStacoma
    Alaska
    Great! Thanks for the info. I used to have 265/75/16 ko2 10 ply but switched to falkens in the same size but p rated. Thanks for the input!
  12. Feb 7, 2019 at 10:00 PM
    Mack7n
    Josey
    Old Town, ME
    No problem. You shouldn't have any issues then at all. my 265/70R17's are slightly bigger than what you're running and I only get rubbing if the wheel is turned about 3/4 of the way, and I slam into a bump. I've only had it happen once since the suspension lift, and it was a hard hit. The P-Rated tires are slightly smaller (13/32 vs 18/32 Tread Depth) So just over a 1/4" smaller than mine.
  13. Feb 8, 2019 at 5:56 AM
    eevaldes
    eevaldes Well-Known Member
    Eric
    2017 Quicksand Tacoma TRD sport
    MLO GTS Suspension, Dobinsons Front bumper, Warn Winch, Harrup rear e-locker, EVO Corse wheels, Baja Designs LP9 lights, Rhino Rack Backbone Pioneer, Norweld Deluxe Tray
    Hey,
    The 314 coils on the Tacomas give about a 2.5” of lift. The 302 coils provide a true 2” of lift which also looks great. Just depends on how you want it to look.
    Hope this helps!
  14. Feb 8, 2019 at 6:06 AM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    is there a spring for 1.5" lift?
    eevaldes[QUOTED] likes this.
  15. Feb 8, 2019 at 8:28 AM
    #35
    eevaldes
    Eric
    Dobinsons offers the C59-300 coil which offers 1.25' of lift. That would be the only other option.
    CoastieRon[QUOTED] likes this.
  16. Feb 10, 2019 at 10:59 AM
    #36
    nachotruck
    nachotruck Member
    2017 DCSB TRD Off Road Silver
    So does the GTS kit use all Dobinson’s components? I’m not sure I understand the difference from the Dobinson’s kit other than the color.
  17. Feb 11, 2019 at 6:03 AM
    #37
    eevaldes
    Eric
    Hey!
    We partnered with Dobinsons when we were looking to develop our GTS kit and it turned out great. The kit includes black Dobinson twin tube shocks and struts and MLO red coils also manufactured by Dobinsons in Australia. We’re also using their leaf springs, bushings, and Ubolts as well. Our coil springs were chosen based off the spring rates and lift we wanted for our customers.
    We love the color combination and how much the kit improves the on and off road performance of the Tacoma.
    Price is the same. It really just depends on which colors you prefer.
    I hope this answers your questions!
  18. Feb 11, 2019 at 3:51 PM
    #38
    nachotruck
    nachotruck Member
    That’s great. GTS is on the top of my list. Thanks for the info!
  19. Feb 12, 2019 at 8:35 AM
    #39
    eevaldes
    Eric
    Awesome! Let me know if you need anything.
  20. Feb 13, 2019 at 9:33 PM
    #40
    JARStacoma
    Alaska
    Purchased a set of coils, struts and shocks this past Friday. Super stoked to finally make the decision. Thanks to @eevaldes for the excellent customer service. Will post up when installed. Won’t be for another few weeks. Thanks to @Mack7n for your review. Definitely helped in my endless search for what I was looking for.
    Mack7n[OP] and eevaldes like this.
