2018 vs 2021 Transmissions (aka Dead Equine Flogging)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KY_Rob, Dec 30, 2020.
  1. Dec 30, 2020 at 7:22 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I would assume so, yes.
    Lt. Dangle likes this.
  2. Dec 30, 2020 at 10:51 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Pure entertainment.
  3. Dec 31, 2020 at 12:24 AM
    Burica
    Burica Raptor Deracinator
    Texas
    The transmission has always been fine same with the V6 engine. Both strong as a moose and reliable.
    The issue has always been the parameters set for the software of the ECU which controls the shifting.
    With tsb-0092-20 it’s a non issue for 2019-2020 and the 2021s automatically have the new ECU parameters.
    Trucks are jackrabbits now
    Gearheadesw[QUOTED] likes this.
  4. Dec 31, 2020 at 12:33 AM
    ToyoVL
    ToyoVL Well-Known Member
    I wonder if I install a 2021 ECU module to 2016-18 trucks and they'll drive like 2021. Transmissions, engines for the 3rd gen for 6 years are the same, just the ECU modules are different.
  5. Dec 31, 2020 at 12:40 AM
    Burica
    Texas
    I wouldn’t think the software would be backward compatible to the technology and mechanism of those years.
    Better off writing Toyota and demanding a TSB reprogramming same as the 2019-2020 Tacoma trucks.
  6. Dec 31, 2020 at 12:50 AM
    Burica
    Texas
    Oh man... Are you familiar with the problems of the 2019-2020s?
    You say your truck keeps in the 2K-2.5K rpm range? That’s good.
    The problem we had was the truck was programmed to always find 1100 rpms and sit there.
    If you want the powerband range then that is what S-Mode is for. Put it in S-Mode 3 and ride that powerband at 45+ mph.
    S-Mode let’s you get the powerband at any speed you like.
  7. Feb 16, 2021 at 1:47 AM
    verlaryder
    verlaryder Well-Known Member
    2020-21 4 cyl auto tranny shifts nicely now too and engine power is up compared to a 2017 I drove. The 4 cyl no longer feels lethargic and underpowered.
