2019 3rd Gen Transmission Nightmare
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DosTheTacoma, Jun 23, 2020.
  1. Jun 23, 2020 at 7:08 PM
    #141
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    I read that wrong, ignore me
  2. Jun 23, 2020 at 7:16 PM
    #142
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    No worries bud. :cheers:
  3. Jun 23, 2020 at 7:52 PM
    #143
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    OP, if you are still here don't sweat it. There are a few things you can try and keep in mind.
    First disconnect the battery for a while, then reconnect it and drive it like you want it to drive, don't baby it. If you drive like a grandma, the tranny will learn that and drive like it. The learning aspect of the tranny is always watching, and the results of doing this usually result in frustration of it not driving as you would like eventually.
    S mode is your friend. S5 will fix many of the issues known to plague some owners. S does away with the learning aspect and locks out 6th gear. Difference between 5th and 6th is probably about 400 RPM at highway speed. Both are still overdrives.
    You can also use ECT mode to hold gears and improve throttle response. S mode and ETC work wonders.
    You can always turn to the aftermarket for a reprogramming of the computer, OVTune.
    Trading in your vehicle, regearing, or aftermarket solutions are hardly required, but if you try all the options available that you have already paid for and still hate it, move on to the next step you are willing to take.
  4. Jun 23, 2020 at 8:11 PM
    #144
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Hand calculated, I always do, just cause. Oddly my Tundra is very accurate, hand calculations and the display are within a few tenths.
  5. Jun 23, 2020 at 8:16 PM
    #145
    SouthernFried
    SouthernFried Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    My 2020 auto seems perfectly fine. These automatic transmissions are designed to shift up/down to get the best gas mileage possible. The only solution to your “problem” is trading it in for a manual or for another truck all together. I think it’s all in your head man. When I’m driving, I’m not sitting there and obsessing over and listening to when my transmission is shifting. Frankly, I don’t care. Now, if the transmission was needing to be rebuilt or replaced because something was actually wrong with it, that’s a whole other issue.
    Junkhead, zoo truck, JNG and 3 others like this.
  6. Jun 23, 2020 at 8:20 PM
    #146
    Grindstone
    Grindstone Requires Adult Supervision
  7. Jun 24, 2020 at 6:34 AM
    #147
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    yes its been covered since 2016, any infos pos. or neg. have already been ran thru a billion times already, which leaves only threads that are intended to be used as a dog whistle to start a flame war confrontation with the intent on getting people banned, its really obvious at this stage.
    Chew, Chris_The_Red, JNG and 2 others like this.
  8. Jun 24, 2020 at 6:38 AM
    #148
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Get rid of that dog ASAP
    BillsSR5 likes this.
  9. Jun 24, 2020 at 6:53 AM
    #149
    BillsSR5
    bill
    2014 SR5
    that dog wont hunt(SEARCH BUTTON)
    VirusCage[QUOTED] likes this.
  10. Jun 24, 2020 at 6:57 AM
    #150
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Same here, i was a bit discouraged with the trucks performance when under 1k miles on the odo, but after that everything started to work just as good as on my gen1 tundra. Currently get a stead 22.5 mpg with a mix of city and highway driving. Couldn't be happier how smooth and deliberate this transmission performs.
  11. Jun 24, 2020 at 6:58 AM
    #151
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    Helsinki syndrome....
  12. Jun 24, 2020 at 7:02 AM
    #152
    BillsSR5
    bill
    2014 SR5
    only known cure
    n6vmo[QUOTED] and Chris_The_Red like this.
  13. Jun 24, 2020 at 7:19 AM
    #153
    Taco1701
    William
    GA
    That's impressive man. I never came close to that with my Tundra. The computer on my 2020 Tacoma has been pretty accurate thus far. The Tundra was usually off by about 1.5 mpgs. Not that it really matters, since I do the same as you and hand calculate everything.
  14. Jun 24, 2020 at 7:25 AM
    #154
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    elduder likes this.
  15. Jun 24, 2020 at 7:31 AM
    #155
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Post #16 will take you there, there's an endless supply
