2019 Bed Storage Compartment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EdubTRD, Feb 1, 2019.
  1. Nov 2, 2019 at 6:19 PM
    #41
    RustedRon!
    RustedRon! Active Member
    Ron
    2019 Tacoma double cab trd sport
    Added front receiver.
    Yeah, that's a good idea, I just want something a little more than adhesive to hold em on. I've already starting cutting and gluing some rubber. just gonna make my own. Thanks for your input!!
  2. Nov 2, 2019 at 6:43 PM
    #42
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    Search for "bed cubby caps for sale"
    (I don't know how to copy and paste the thread.)
    I finally installed mine last weekend. They seem solid. You need something like this to keep all the mud and water out of them.
  3. Nov 2, 2019 at 6:57 PM
    #43
    Ainapo
    SW WI
    MT+LB=sport
    ... I also sealed the drain holes in the bottom plugs and ran a bead of RTV around the lip of the cubbies (and the outlet plate) before re-installing.
    shakerhood likes this.
  4. Nov 2, 2019 at 10:06 PM
    #44
    Hurley_man
    Hurley_man Well-Known Member
    Las Vegas, NV
    16 DCSB OR 4x4
    Traded my 2012 sport for the 16
    Lol
  5. Dec 11, 2019 at 10:21 PM
    #45
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    I never knew it existed at all. I'm not sure if I saw it for the first time at the dealer or when I got home, but non-locking OEM type boxes are just a theft magnet and a hole in my bed where I didn't need one. The aftermarket driver's side box solutions just create an expensive larger hole in a place where a hole probably should not be. My small stuff stows in a .50 cal ammo can that lives behind the back driver's side seat.
    Tullie D likes this.
  6. Dec 11, 2019 at 11:17 PM
    #46
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I use a Dewalt tool box and a trunk organizer. . :thumbsup:
    The bed storage box has a couple of cheap ratchet straps.
  7. Dec 13, 2019 at 2:08 PM
    #47
    EdubTRD
    EdubTRD [OP] Well-Known Member
    Eastern NC
    2005 White SR5 2.7 Access Cab
    To each his own. Having a locking tail gate and locking camper shell deter theft from that ”hole” fairly well. As far as a hole being where a hole probably should not be, that’s the whole point of adding extra storage instead of wasted space. It’s like that wasted dead space framed in under the stairs in a house, it’s much more useful when there’s a door to access it for storage.
    Sure I could use an ammo can or something similar in my back seat but once again, that’s useful space for other stuff. Plus, I like to keep that area clean and clear. Anyways, the more storage options you have the better in my opinion.
    1st world problems I suppose...
    smplstc, igod69m, Boghog1 and 2 others like this.
  8. Dec 13, 2019 at 2:34 PM
    #48
    Tullie D
    Tullie
    Wilson, NC
    I have a 30 cal ammo can on the driver's side for short term firearm storage. The lock is keyed the same as my house key, so I always have it handy.
  9. Dec 14, 2019 at 9:16 AM
    #49
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    2021 Tacoma DCLB SR
    That drivers side storage cubby is very useful for putting in a 7 pin trailer wire hook up. It keeps it out of the salt here in the north east. I have used that cubby just for that for the last 11 years.
  10. Mar 25, 2020 at 4:00 PM
    #50
    mOjO_Taco
    mOjO_Taco Well-Known Member
    Mesa, AZ
    2020 TRD 4X4 OR Cement
    None yet
    My 18 had the left side compartment but now my 20 doesn’t. Does any bod know that I was to get the tuffy box...could I cut the panel to install it? Thinking of installing an ARB air compressor in there.
  11. Apr 13, 2020 at 6:11 PM
    #51
    TacoTaco-BurittoTaco
    TacoTaco-BurittoTaco Well-Known Member
    James
    Georgia
    2023 TRD Off-Road DCSB
    Stock
    I'm waiting to find out the same thing for my 2020.
  12. Aug 11, 2020 at 11:32 AM
    #52
    Flying-Taco
    Flying-Taco Well-Known Member
    Are the measurements of the hole identical on the left and right sides? If so, take out the passenger side one and use that whole to measure off the drivers side?
  13. Aug 11, 2020 at 2:46 PM
    #53
    Flying-Taco
    But the aftermarket Husky ones are $250, and deeper. Still expensive for what they are, but at least they are metal, bigger and lockable.
  14. Aug 12, 2020 at 5:08 AM
    #54
    Paulndot
    Paulndot Well-Known Member
    2020 TRD Off Road
    I think it was mentioned in here, but my memory sucks and I'm too lazy to look, so here it goes: Has anyone looked into 3D printing one? It'll be a fraction of the cost, and all the extra drain holes you want, or no drain holes, or dividers, or anything else you can think of can be printed in there.
  15. Aug 12, 2020 at 12:11 PM
    #55
    Flying-Taco
    I agree, but at least its cheaper than the Factory option.
  16. Mar 10, 2021 at 8:27 PM
    #56
    mwrood
    mwrood Well-Known Member
    2021 Voodoo Blue TRD Premium Sport
    Anyone happen to know the name for the metal threaded “nuts” that are inserted into the bed liner for the cubby to screw into?
  17. Sep 18, 2021 at 2:33 PM
    #57
    LongRon
    LongRon Member
    2019 White DCLB TRD Off-Road
    Anyone know the inside dimensions of the box? Can’t find a reliable source.
    Looking for options to mount a 5# fire extinguisher out of the elements on my ‘19 and this looks like it could be just big enough.
