2019 Citrus WMA - Annual Fall Camp & Ride 10/18-10/20
Discussion in 'Florida' started by Rattletrap66, Jul 29, 2019.
  1. Oct 23, 2019 at 8:56 AM
    #181
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Thats awesome where are getting all the training?
  2. Oct 23, 2019 at 4:49 PM
    #182
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    I might ride on Sunday. Is trail 19 open? I haven’t been for a few months.
  3. Oct 23, 2019 at 5:03 PM
    #183
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    I've heard yes and no. No idea though
    NABeast[QUOTED] likes this.
  4. Oct 23, 2019 at 5:08 PM
    #184
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    You'll be in Citrus this weekend? I should be out that way.
  5. Oct 23, 2019 at 5:09 PM
    #185
    Key-Rei
    Key
    Florida
    Technically I'm not at leave to say but it is UNIVERSALLY known. :rolleyes:
  6. Oct 23, 2019 at 5:11 PM
    #186
    Key-Rei
    Key
    Florida
  7. Oct 23, 2019 at 5:16 PM
    #187
    JeffBoyardee
    Jeff
    Seminole, FL
    I used to work at a foundry/machine shop that did quite a bit of NDT for the castings. I stayed away from the foundry side though.
  8. Oct 23, 2019 at 5:18 PM
    #188
    Key-Rei
    Key
    Florida
    Can't say as I blame you there.
  9. Oct 23, 2019 at 5:31 PM
    #189
    JeffBoyardee
    Jeff
    Seminole, FL
    Yes, we"ll be out there. Silver Tacoma and a white 4runner.
  10. Oct 23, 2019 at 5:38 PM
    #190
    Key-Rei
    Key
    Florida
    What days?
  11. Oct 23, 2019 at 5:45 PM
    #191
    JeffBoyardee
    Jeff
    Seminole, FL
    We"ll be there the whole weekend. Friday night to sunday
  12. Oct 23, 2019 at 5:52 PM
    #192
    TacoTRD78
    Stuart,fl
    I have been a FPI for close to twelve years started in a Aerospace company and now work for a land Turbine company
    Key-Rei[QUOTED] likes this.
  13. Oct 23, 2019 at 6:05 PM
    #193
    Key-Rei
    Key
    Florida
    FPI, Florescent Penetrant Inspector?
    Man that stuff is stupid sensitive. We use Magnaflux stuff. Several excavations later if there's still an existing indication you're going to see the penetrant.
  14. Oct 23, 2019 at 6:34 PM
    #194
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    19 is closed from 2 down through 8/10A. Trail cams up in the trees too.
    I guess they are going to grade or fill it?
  15. Oct 23, 2019 at 6:40 PM
    #195
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    F*ck. Well that sucks, thanks for the info. So whats the fine for running without a license plate out there? lol
    Trident904 likes this.
  16. Oct 23, 2019 at 6:57 PM
    #196
    JeffBoyardee
    Jeff
    Seminole, FL
    That damn mud gets everywhere. Even on the license plate!
  17. Oct 23, 2019 at 7:05 PM
    #197
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I never thought of that, my truck will be covered with mud, and the back will just have a dusting. Lol. Time to change that.
  18. Oct 23, 2019 at 7:19 PM
    #198
    JeffBoyardee
    Jeff
    Seminole, FL
    Ass to ass mud burnouts.
  19. Oct 23, 2019 at 10:31 PM
    #199
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Negative. Last weekend it was closed between 8 and 6. If you come in on 6 and head north, there's no signage indicating 19's closed. We ran it north from 6 to 4 and saw no signs prohibiting vehicles. Can't say as I really looked but there might not have been any signs going south from 6 either. They might only have it closed one way since they probably think the corner won't get rutted out any worse by people going south. But yeah, on the corner of 8 and 17, there are signs up closing 8 to the west of 17.
    Edit: They might be going to do some logging along 19 as well since I did see several large pines that were being held up pretty much by their tap root. Made me kinda nervous going by them since it looked like a stout breeze might topple them. They would probably need to grade a few places out to get their logging equipment in there from trail 8 since the other trails headed west to 17 are quite a bit tighter than 8.
    Rattletrap66[OP] and NABeast like this.
  20. Oct 24, 2019 at 1:31 AM
    #200
    TacoTRD78
    Stuart,fl
    Yeah I was wondering if you were still working there. I noticed they were hiring.
