2019 Citrus WMA - Annual Fall Camp & Ride 10/18-10/20
Discussion in 'Florida' started by Rattletrap66, Jul 29, 2019.
  1. Oct 21, 2019 at 9:24 PM
    #161
    Rattletrap66
    Rattletrap66 [OP] (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Found a dead frog under that soggy ass carpet :laughing:
    TacoTRD78 likes this.
  2. Oct 22, 2019 at 4:02 AM
    #162
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    One additional note on the new config...
    Those 36s smoothed the washboard trails right out. I could see the washboards, but I barely felt them and the rear end stayed planted without dancing around like it did before.
  3. Oct 22, 2019 at 5:20 AM
    #163
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Gah!
    :annoyed:
    Damnit I missed it.
    :pout:
    Haven't been very active on here, new job is eating my life.
    Aside from maintenance I haven't done much to the Tacoma either.
  4. Oct 22, 2019 at 5:23 AM
    #164
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Whatcha doing for work? The annual meet will prob be sometime in Feb.
  5. Oct 22, 2019 at 5:34 AM
    #165
    Stormtrooper_08
    Stormtrooper_08 If two wrongs dont make a right, try three
    Orlando, FL
    White '08 TRD Sport Prerunner SR5
    4" Maxtrac spindle lift, adjustable bilsteins up front set at 1.75", 2" blocks and pro comp aals in the rear. 33" Cooper STT Pros.
    I don’t suppose anyone got a picture/ pictures of my truck, did they?
  6. Oct 22, 2019 at 5:34 AM
    #166
    Key-Rei
    Key
    Florida
    Non destructive testing inspection.
    allenfab likes this.
  7. Oct 22, 2019 at 5:45 AM
    #167
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I remember doing that to a 86 Bronco II, had to walk 3 miles out with a foot of muddy water in my new truck. Removed everything like you did, hosed out the carpet on the driveway, then hung over the hedges to dry. By sunset they were dry as a bone, and no smell. I left it out the remainder of hunting season that year, just using floor mats.
    Good luck with your clean up.
    Rattletrap66[OP] likes this.
  8. Oct 22, 2019 at 6:04 AM
    #168
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Welcome to the club
    Key-Rei[QUOTED] likes this.
  9. Oct 22, 2019 at 6:12 AM
    #169
    allenfab
    Todd
    Lakeland, FL
    That's funny, I experienced the opposite. The rear suspension seemes like it couldn't keep up as good as it use to. Idk if it was the shocks cavitating, extra unsprung weight, the shocks being further away from the tire now because of the extra width (lessening their effectiveness), or just the fact that 63's suck. Who knows
  10. Oct 22, 2019 at 8:06 AM
    #170
    TacoTRD78
    Stuart,fl
    Cool what method ?
  11. Oct 22, 2019 at 10:24 AM
    #171
    Taco No Baka
    Lee
    Tampa, FL
    I also didn't get as much axle wrap as I thought I would, but I imagine that will show itself on higher traction surfaces if I don't get the traction bar on before that.
    Maybe it's time to either four link the rear and build yourself a baffled aluminum gas tank, or if you're not feeling it just yet, upgrade to a tuneable shock. I have a feeling it's the unsprung weight that's the issue, but I'm dumb as owl shit as far as that stuff goes, so it's just a feeling, lol. Tuning shocks sounds like something you could futz around with for years trying to get them just so...and then you change something and have to start all over again. :frusty: :D
  12. Oct 22, 2019 at 1:12 PM
    #172
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    are you coming? we missed ya
  13. Oct 22, 2019 at 1:13 PM
    #173
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    thanks! all done and next step is to sound deaden it
    DarkMark340 likes this.
  14. Oct 22, 2019 at 3:16 PM
    #174
    allenfab
    Todd
    Lakeland, FL
    You don't notice axle wrap until you pin it with a traction bar installed, trust me. Night and day.
    Though I am anti-linked rear suspension, I have been wanting to complement the radflos up front with a set of smooth-bodies for the rear. 4 wheel underground has a tune specifically for Chevy 63s, I just have to pony up the ~$600 or whatever it is for them. Also, while I'm at it, I'll probably outboard them since I have the room now with these axles. Still need to install rear bumps too....
  15. Oct 22, 2019 at 3:25 PM
    #175
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    I got a few on the Go Pro. Not sure if it's what you're looking for, but I'll post them once I download them.
  16. Oct 22, 2019 at 3:30 PM
    #176
    TacoTRD78
    Stuart,fl
    Thanks man Im going to try and make it.
  17. Oct 22, 2019 at 7:19 PM
    #177
    Taco No Baka
    Lee
    Tampa, FL
    Sounds like a good place to start. You still might end up needing to tune them though. IIRC, you modified the spring rate on your 63s and you still have a bit more unsprung weight with the 1 ton axle, but the Radflos should be tuneable if you aren't happy with them.
  18. Oct 23, 2019 at 3:49 AM
    #178
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    It would be for 4wd models only if remember right it just works off of the abs but Thomas used to swear by it
  19. Oct 23, 2019 at 6:19 AM
    #179
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Totally unrelatedish, but my brother and I are taking our kids camping out there this weekend, if anyone didn't get to go, or didn't get their fix last weekend!
    NABeast likes this.
  20. Oct 23, 2019 at 7:02 AM
    #180
    Key-Rei
    Key
    Florida
    All methods!
    Well, not quite.
    Primarily VT, MT, PT.
    We do a little ET and UT.
    RT and NR gets outsourced.
    CWI training starts as soon as I pass my MT and PT LvII which should be next month, building hours to meet ASTM now.
    Got my LvII for FRP inspection.
    :D
    Recently been playing with an apparently rather expensive makes stuff glow In the dark machine. Good stuffs! :thumbsup:
    Taco No Baka likes this.
